Question about Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 205 Problems aquiring stellite
My Garmin Nuvi has a lot of difficulty acquit=ring satellite signal.
I spoke to sales-rep at Garmin and told me there could be a problem with my windshield that is blocking the signal???
Can any body tell me what to do?
  • 1 more comment
  • dicu Sep 05, 2008
    My Garmin Nuvi 660 in acquiring satellite signal.started to work intermittently, and finally does not acquire the satellites any more, even after resetting the unit. A saleman told me that a chip is bad. I would like to know how to open the case of this nuvi 660, in order to find hopefully the schematic in order tho repair it. Thanks!
  • Anonymous Mar 09, 2009
    The only times I have used my Nuvi 205 have been to make 560 mile trips about 4 times, and every time it worked perfectly. Other than these trips, I would store the system away. 2 days ago I turned it on to use on the same type of trip, and it won't acquire satellite anywhere I go. Obviously, I have done nothing to cause the damage, so would anyone know how the problem could have been caused or how to fix it? Also, where can I locate the help number to call?
  • moezaw1961 Mar 11, 2009
    I too own the Garmin 660 and getting lost satellite communication error.
    Per other forum contributor, sensing diode gone bad and Garmin knew about this situation. However I do not have warranty since I have the GPS for over a year and half. I can add the external GPS antenna to solve this problem but if I can replace the diode would be great.
    I am also looking for schematic.
  • 446 Answers
Usually gps are automatically sensing the signal, with clear view without and sometime even with minimal obstruction like trees windows etc. there is no other way your gps could not acquire signal unles it is having a problem .
all gps thesedays have 10-20 meter accuracy, it is only a receiver, this model particularly have the highest signal.
in other words i suggest you reset your unit from the bottom and see if there is any improvement, replace the unit
cheers
Posted on Sep 04, 2008
I have a Garmin Nuvi 1300. When I power the unit on, it says aquiring satellites. It never locates a satellite. Any ideas?
If your using it in your car and your car has tinted windows, the window tint may contain a metal oxide (most common on newer cars) which interferes with the signal. Try holding the unit next to an open window. If that works you may need to get an external antenna from garmin that you can attach on the outside of your car.
May 25, 2011 | Garmin nuvi 1300 Car GPS Receiver
Garmin 200w has trouble aquireing satellites?
Go to the Garmin dot com website and follow prompts to download the software and the firmware and software updates - they are free.
Jun 12, 2010 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 205 continues to state Loss Satellites
If your Garmin NUVI 205 can be recognized by your computer when plugged in, I recommend you backup your favorites.
Then I suggest a hard reset. This correct some problems.
Finally, replace the firmware and system software using webupdate. Replacing the firmware should allow it to find more satellites more quickly and keep them more successfully after the update.
I hope that helps.
Mar 14, 2010 | Garmin nuvi 205W GPS Receiver
My husband travels 5 days a week (regional sales manager) and LIVES by his Garmin Nuvi 205. It is only 5 months old but now when he turns it on, the map will not come up on the screen. It is picking up the...
Good morning Vickie. With a device this new, I would suggest you have a conversation with the Garmin folks, e-mail or on the telephone. Here is the link: http://www.garmin.com/garmin/cms/site/us click on support and make your choice.
I don't think you can repair this yourself.
Thanks for your interest in FixYa.com
Feb 22, 2010 | Garmin nuvi 205 GPS Receiver
My garmin 205 seems to have lost its fix. Its position is out by about 100m, tracking established roads but to one side or other then loses roads altogether then gets totally lost. Is a map update...
Whenever these devices start acting up, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device. There have been numerous fixes to the firmware to allow the Garmin 205 or acquire satellite signal faster, and to be more accurate with your location.
I hope that helps.
Feb 08, 2010 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 200w not getting any signal....
I recommend trying the hard reset and the newest webupdater (March 31, 2010) and se if you get better results.
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Feb 08, 2010 | Garmin nuvi 200W GPS
N ot able to aquire a satellite signal for two
have you downloaded the "HotFix" software update for the problem from Garmin yet? if not u will need a mini USB cable (avil on ebay for $5) and then register the GPS at this site www.mygarmin.com and select support or downloads and follow instructions..
Oct 01, 2009 | Garmin nuvi 255W GPS Receiver
Since my last time i used garmin nuvi 260 it cant find a signal
Try going outside with a clear veiw of the sky, since it cant aquire a satellite its simulating the last place where you were. Try canceling the route and see if it connects with the satellite.
Jan 08, 2009 | Garmin nuvi 260W GPS Receiver
Dont Aquire Satellites
Ditto.. even after updating FW...
Jun 14, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 310 satellite aquire problem
I have a Garmin Nuvi 350. I solved the problem by purchasing a Glisson GPS antenna that plugs into the external GPS connector on the Garmin antenna.
Apr 04, 2008 | Garmin GPS
Garmin Nuvi 660 GPS Receiver Logo
1,254 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
