Question about Palm Treo 650 Handheld
Treo 650 new user - SD memory needed for MP3?
If I wanted to transfer approx 500 songs, what size SD memory is best? 128mb, 256mb, 512mb?
  • 3 Answers
Hello, welcome to Brighthand. Definetely 512 MB or 1 GB. For a 128 Kilobits rate (quality), 1 MB = 1 Minute. Of course you can lower the bit rate, but you will have lower quality.
Posted on Sep 15, 2005
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
Memory
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
Types of sdram
PC66 SDRAM
PC66 SDRAM is the original module speed of SDRAM. PC66 SDRAM was the earliest version of SDRAM and therefore came in a number of smaller megabyte sizes than later versions. Most early motherboards were rated for PC66 SDRAM. The available sizes are 32MB (megabytes), 64MB and 128MB.
PC100 SDRAM
PC100 SDRAM was released after PC66 SDRAM and runs at a higher speed. It has the same number of pins as the earlier memory module and is capable of utilizing the same RAM slot. The only difference when installing this SDRAM in compatible computers with older systems (PC66 slots) is that the SDRAM will run at a slower speed. PC100 RAM comes in sizes such as 32MB, 64MB, 128MB, 256MB and 512MB.
PC133 SDRAM
The last generation of SDRAM is PC133. The PC133 memory provided a speed upgrade and comes in larger sizes than previous generations of SDRAM. PC133 modules are backward compatible with older SDRAM slots. The PC133 memory, however, will be forced to run at the slot's slower bus speed (PC66 or PC100). The memory comes in sizes like 128MB, 256MB, 512MB and 1024MB.
Mar 03, 2011 | Computers & Internet
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
Sep 30, 2010 | Nikon D60 Digital Camera with 18-55mm lens
I need to know how much ram my motherboard will be able to run without burning up? I have an Emachines t1090 w/ Windows XP, 900MHz Intel Celeron Processor, 128MB SDRAM, CD-ROM 48x Max. CD-Drive, 20GB Hard...
The max for your system is 512MB. You have two memory slots and one has a 128MB chip so if you want 512MB, you need two 256MB chips and throw away the 128MB.
At Newegg, a 256MB chip is $42+ shipping of $1. I'd consider getting a new computer instead.
I don't think memory upgrade will tax your system cooling.
Sep 09, 2010 | E-Machines T1090 PC Desktop
Simply upgrade to more memory
G-Skill is what I put in all my custom built computers.  Search newegg.com and you will find what youare looking for.  You want PC2700 DDR.
Mar 12, 2009 | Computers & Internet
Want to buy more RAM..
Your dell dimension takes DDR ram. These are the specs:
Supported pin types: 184 pin DIMM (regular desktop DDR ram)
Supported memory types: DDR PC2700 or DDR PC3200
Supported speeds: 333mhz or 400mhz
Supported stick sizes: 128mb, 256mb, 512mb or 1gb.
MAXIMUM MEMORY ALLOWED: 2gb (2 x 1gb sticks)
If you buy two of these you will max out for ram and give you the best performance::
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1558844&CatId=1600
Dec 24, 2008 | Dell Dimension 3000 PC Desktop
SD card
wahoo!just been rummaging the internet and i have found that these cameras will only take up to a 1gb memory card!so just get a smaller size card
The camera has 16 MB of internal memory. Memory capacity can be expanded with 16MB, 32MB, 64MB, 128MB, 256MB, 512MB up to a maximum of 1 GB SD or MMC cards.
Hope it helps!!!
Jun 23, 2008 | Kodak EasyShare C330 Digital Camera
Memory card problems
C-Series : Optical zoom lens cameras with sliding lens cover Product name xD-Picture Card *1-7 SmartMedia
3V(3.3V) CompactFlash Type M+ / M Type H Standard C-990ZS - - - X
2MB - 128MB - C-990 ZOOM - - - X
2MB - 128MB - C-960 ZOOM - - - X
2MB - 128MB - C-920 ZOOM - - - X
2MB - 128MB - C-900 ZOOM - - - X
2MB - 32MB - C-500 ZOOM X
256MB - 2GB X
256MB - 2GB X
16MB - 512MB - - C-480 ZOOM X
256MB - 2GB X
256MB - 2GB X
16MB - 512MB - - C-470 ZOOM X
256MB - 2GB X
256MB - 2GB X
16MB - 512MB - - C-460 ZOOM X
256MB - 1GB X
256MB - 2GB X
16MB - 512MB - - C-450 ZOOM X
256MB - 512MB X
256MB - 512MB X
16MB - 512MB - -
http://www.olympusimage.com.sg/pr/notice/1176786_707.html
check up at this website
Sep 22, 2007 | Olympus Camedia C-450 Zoom Digital Camera
EM-500 memory question (new user)
You can use any brand whatsoever. If you are concerned about compatibility - a genuine problem with some manufacturers - you might consider buying from a retail outlet & test it out on the device itself. Casio uses either Toshiba or Hitachi cards so that would be your best bet.
Sep 06, 2005 | Casio Cassiopeia EM-500 Pocket PC
What size of flash memory card do you recommend me using with my PENTAX digital camera?
The answer depends on your personal needs and your budget. Memory cards are available in many sizes 8MB, 16MB, 32MB, 64MB, 128MB, 256MB and 512MB. The larger the card size, the more storage space and the greater the cost. One recommendation is to select a card that allows you to take images without having to worry about changing cards or downloading images very often (one of the advantages of digital photography). Among the most popular are those in 64MB, 128MB or 256MB sizes. You may want to purchase a second card to use as a back-up or replacement card that can be used if you run out of space on the first card or to use when the first card is unavailable (you may be downloading or printing images from the first card.)
Aug 30, 2005 | Pentax *ist D Digital Camera
Palm Treo 650 Handheld Logo
56 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
