Question about Cameras
Praktica BC3 shutter not winding on - Cameras
  • 1 more comment
  • billkirkby Sep 04, 2008
    With the back open I can see the shutter go up when I wind the leaver forwards .It then goes down as I let the leaver return
    Is the adjustment under the top or the bottom cover.I have repaired several F.S.U.rangefinders ,but never a SLR ,
    I have fitted a new battery
  • Cameras Master
  • 19,396 Answers
Your camera shutter is mainly mechanic with only an electric winding control, for the rest the fault does not seem to be a logic problem.
You need to take apart the camera Follow instructions here on how to disassemble the camera to access the winder.
The user on the website was fixing a similar problem on a jammed winder, and found out that a small tab was missing.
To move to next page use command Nächste >> at the bottom of the page. There are detailed disassembly instructions.
Posted on Sep 04, 2008
    Genius:
  • 2,028 Answers
I'm going to have to agree with short shadey, and say take it in for servicing. I've been in one of these before, and the extremely small gears have even smaller pivot pins they ride on. These pins are plastic, which doesn't help matters at all, and they have a tenancy to slip out slightly and jam up, especially if the camera was jarred or bumped around. You would be surprised at how slight the jarring can be in order for the gear to jump out.
  • Cameras Master
  • 6,487 Answers
Try checking this link it may helo with your concern http://www.praktica-b.org/index.php?view=article&catid=38%3Areparatur&id=50%3Adisassembly&option=com_content&Itemid=54
Hope that helps........
  • 421 Answers
Yes and you also need the redirect the pizeo cystal for the bunitier to reactuate and reformatize i read this in Maanita's book of wishfull thinking lol, its so funny the answers these people give out to try and win your vote to make a quick buck.... i would go ahead and filldle with the lever, sounds like it may have stripped a small gear or something to that effect, it would save you a headache to drop it off at a camera shop and they could possibly fix it on the spot for you, they are pretty reasonable on pricing as well good luck -jeff
    Genius:
  • 1,269 Answers
Make sure battery is fully charged. Also try to use a different battery.
    President:
  • 1,952 Answers
The connection between lever and shutter should be adjusted
    Genius:
  • 1,142 Answers
Try to hard reset the unit first and then try.
  • Maanita Chadha
    Maanita Chadha Sep 04, 2008
    you need to release the static energy accumulated in the components of the mainboard
    for that you need to remove the battery and then hold down the power button for 60 seconds and then release. that should take care of the issue.
Blank roll of film
Two possible problems:
1. Film did not wind on. 2. Shutter not opening.
Easy to test with camera back open. Load a film and fire the shutter a few times each time with winding on, to see if film is winding correctly, at the same time you should be able notice if the shutters are firing, eight of them in succession makes a bit of noise.
Nov 09, 2010 | Lomo Oktomat 35mm Film Camera
My Praktica LLC mirror locks up and won't return. The shutter stays open partly or fully.
do you have exact model - this maybe bulb which allows the shutter to stay open for as long as the shutter release is pressed - or mirror lock setting - for macro work to avoid any camera shake when the mirror moves - by locking the mirror
Mar 30, 2010 | Photography
35mm slr praktica bca shutter problem.
1) Open the top cover.
2) On the film advance gear, the shutter winding lever is attached to it.
It has screw adjustment there. Unscrew the screw ( not all the way out ) You will need to adjust the wind travel and make the length of the wind lever ( made of spring steel) shorter and tighten the screw.
Mar 06, 2010 | Photography
PRAKTICA DVC 5.1 HD problem
Practika 5.1 digicam goes on for just 2 seconds only then it goes off. when I switch it with a record button pressed it displays: PREF RESET DONE PLEASE REBOOT. I don't know how to reboot.
Oct 09, 2009 | Cameras
Old Practica SLR camera shutter not working
I have a practica mtl 50 with a couple of extra telephoto lenses if interested.Very good working comdition.
bob
r_nichols@hotmail.co.uk
Sep 06, 2009 | Nikon F2AS Photomic 35mm SLR Camera
Black rubber strap by Oris Bc3
CALL FELDMAN WATCH COMPANY IN LOS ANGELES CA ON PICO BLVD.
SPEAK WITH JAMIE ..IT'S CHEAPER TO GET YOUR ORIS PARTS FROM A AUTHORIZEED DEALER THAN BUYING OVERSEAS THE MARK UP IS ALMOST 200% WITH THE SHIPPING INCLUDED . LAGJR
Nov 10, 2008 | ORIS BC3 40mm Rubber 40mm Rubber Strap...
Wind / shutter issue (2nd try to post)
It sounds like there is a problem with the frame counter in the film back itself. Try operating the camera with the back removed and on multi-exp to check the shutter functions.
Aug 10, 2008 | Mamiya Photography
Praktica 901
Hi, try to push small thing below /its says push to rewind.
Feb 16, 2008 | Photography
Cameras Logo
152 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
