Question about Creative Labs Zen V MP3 Player
Display not working
On my mp3 player,display is not working,while i am able to listen the music,but not able to see the menu and options
  • nookins Sep 22, 2008
    display not working -works sporadically - plays but I can't select - help
    Scholar:
  • 64 Answers
You need to run the Recovery Mode here is a link to Creative Labs website that will walk you through it...
http://support.creative.com/kb/ShowArticle.aspx?url=http://203.211.142.197:80/srvs/cgi-bin/webcgi.exe/,/?st=357,e=0000000000342903798,k=6058,sxi=1,varset=ws:http://us.creative.com,case=4794
Good Luck and let me know if this helped
cbinny1
Posted on Oct 21, 2008
Samsung YP-U3 mp3 player display is DEAD..won't
Probably the display is off. Go to Settings and change 'Display Off' setting to 'Display On'. I have attached a link to a PCMag review of your player to help you.
Samsung YP U3
Dec 18, 2014 | Audio Players & Recorders
Tip
How to Change the Display Settings for your MP3 Player |
You can personalize your music player by changing the appearance of your background. This will also help you to read the screen while making the icons easier to see.Follow the instructions below to change the display settings on the device.
Instructions:
Things You'll Need:Owner's manual,mp3 player
1.Turn on your MP3 player and use your keypad to select "Setup." Push the center button on your keypad to highlight "Display" on the Setup menu.
2.Use the keypad to scroll though the languages on the Display Menu. Push the center button on your keypad to choose one.
3.Scroll down the menu to the "Brightness" options. Press the right arrow on your keypad to increase the screen's brightness, or press the left arrow to dim the screen.
4.Scroll down to the "Wallpaper" selection on your Display Menu. Use the arrows on your keypad to scroll through the different backgrounds for your MP3 player.
5.Change the icons on your MP3 player. Scroll down to "Appearance." Use the arrows on your keypad to scroll through the different icon choices.
Tips & Warnings:
Make your own background by downloading photos from your computer.Dim the brightness in low light situations to save battery power.
on Feb 10, 2011 | Audio Players & Recorders
What do I do to Eclipse fix mp3 when it diplays "Disk Error!" upon attempting to play music?
Presumably the error is caused by a hard disk drive? In which case the hard disk will need to be checked. If there are options to do this use them. Otherwise the drive might need to be replaced.
If you bypassed the normal way of putting music onto the drive, then it might have corrupted the drive.
If there is an option to reformat the drive that might work. Or if there is a factory reset, that might correct it.
If you have music stored on the drive, which is not found anywhere else, then I think it will have been lost for good.
May 27, 2017 | Eclipse Audio Players & Recorders
What should I do when Elcipse mp3 displays "Disk Error!" upon trying to play music?
The players laser reader has burned out, your best option is to replace the deck.
Apr 05, 2017 | Eclipse Audio Players & Recorders
OK PEOPLE!! have asked this same question over and...am getting the run around...please don't make me continue asking for help with this question. its a sandisk mp3 mini clip, and this issue is getting any...
Use SanDisk MP3 Players
SanDisk is an electronic device manufacturer that creates various types of MP3 players under the SanDisk Sansa product line.
The SanDisk MP3 players range in storage capacity, starting at 512mb, and are intended to operate on the Windows operating system.
Most SanDisk MP3 players also include a built-in video player with a color screen, an FM radio tuner, and a memory flash card slot to expand the MP3 player's storage capacity.
Use SanDisk MP3 players to take your computer's MP3 library with you and listen to music wherever you go.
1. Verify that your computer meets the operating specifications required to sync the SanDisk MP3 player with the PC.
All SanDisk MP3 players require Windows XP or later; Windows Media Player; and a USB 1.0 port. A USB 2.0 is important if you want high-speed music syncing.
2, Check that the SanDisk MP3 player has a full battery charge.
All SanDisk MP3 players have a rechargeable lithium ion battery, and some SanDisk devices have a replaceable battery.
The battery icon on the top right-hand side of the SanDisk MP3 player's screen displays the current status of the battery's charge.
If the battery is low, recharge it before using the SanDisk player for the first time.
To charge, connect the player to your computer's powered USB port using the included USB cable.
The SanDisk player's screen will display a yellow charging icon.
Unplug when charging is complete.
3. To turn on the SanDisk MP3 player for the first time, unlock the "hold" switch on the top of the MP3 player by sliding it so that the orange tab does not appear.
Then, press the "power button" once.
Wait for the SanDisk MP3 player to respond.
The thumbweel of the player will flash a light and the screen will turn on to display the player's menu options.
Turn off the SanDisk player by holding down the player's power button for two seconds.
Wait for the screen to display "Goodbye" before releasing the button.
4. Practice resetting the SanDisk MP3 player to solve critical software errors and to fix the MP3 player if it freezes.
To reset the player, hold down the power button for fifteen seconds.
This resets the MP3 player to its original factory settings and can help resolve any problems you encounter while using the SanDisk MP3 player.
5. Connect the SanDisk MP3 player to your computer using the included USB cable.
Once the computer has sensed the connected device, the SanDisk player's screen will display "Connected" and the SanDisk Portable Media Player will be listed under Other in your computer's My Computer window.
6. Add music to the SanDisk MP3 player.
Double-click the Portable Media Player listed in the My Computer window.
Double-click the Music folder.
Select the MP3 files that you wish to load onto the MP3 player and drag them into the Music folder.
The player will load them into its internal memory and make them available for playback once the device is disconnected from the computer.
7. Sync your MP3 song playlists from Windows Media Player to the SanDisk MP3 player.
Create a playlist in Windows Media Player and connect the SanDisk MP3 player to your computer (see Step 5).
Once its connected, Windows will display a dialog box. In the box, click "Sync digital media files to this device."
In the next window, click Set Up Sync. In the menu, click Personal Playlists and then select the playlists that you wish to transfer to the SanDisk player.
Click the Add button then push the Finish button to transfer your Windows Media Player playlists to the MP3 player.
Aug 09, 2013 | SanDisk Clip Audio Players & Recorders
Totally dark scree!!!
sir, it think the problem is only with the display of your mp3.since you are able to listen to the music, i think you need to change the display of your mp3. it will be available in any reputed mp3 store.
May 28, 2009 | Creative Labs ZEN V Plus MP3 Player
Sansa clip 4 gb wont turn on
You probably already did this, but here is the proper method to change the backlight timer:
1. Press Menu button to return to the Main Menu.
2. Move to Settings and select it.
3. Select Display.
4. Select Backlight.
5. Press |<< or >>| button to select desired backlight timer.
-Tha mp3 Doctor
Feb 26, 2009 | SanDisk Sansa Clip MP3 Player
Zen v plus
have you tryed rebooting at bottom lefthand corner with pin.
Aug 21, 2008 | Creative Labs Zen V MP3 Player
Errorrrr
1 Press and hold the Play button while powering on your player.
2. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Dec 22, 2007 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs Zen V MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
