Question about Indesit Washing Machines
Indesit wm12x dial keeps clicking. 8 flashes of red light but no action after washing, will not spin
SOURCE: indesit wm12x
look into the filter of the pomp ..clean it and restart the machine
Posted on Sep 12, 2007
kjmac
  • 97 Answers
SOURCE: Indesit W123 - 8 Flashes Error Code
thats a problem with your heater, or the heater relay on the main pcb. best off replacing heater first as its the cheapest option.
hope this helps
kj
Posted on Nov 07, 2007
  • 1294 Answers
SOURCE: Filter on indesit washing machine
Push panel right or left side. Unscrew or turn anti-clock wise, according to your model. Be prepared for some water. Pull this out and clean, refit carefully. Of course it is meant to be removed and cleaned periodically, according to usage. Rate me pl.
Posted on Dec 01, 2007
  • 1294 Answers
SOURCE: Indesit W101 Washing Machine
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 31, 2007
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Posted on Feb 27, 2008
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
My dial keeps clicking round on my indesit wm12x, have ordered a new part, do you think this is the problem.
I doubt it will solve the problem, as the part you are referring to is a selector switch and not the timer, the problem is more likely to be a faulty control unit.
Nov 19, 2010 | Indesit W 83
Manual for intergrated indesit wm12x washing machine
To obtain the instructions for washer, go to,
WWW.INDESITSERVICE.CO.UK
In the menu on the left click on Indesit user manuals, then enter the model number in the search box, and down load the instructions to your printer or hard drive.
Please rate my solution.
Thankyou.
Jan 13, 2010 | Indesit W 123 Front Load Washer
Indesit Washing Machine WM12X... Were Should The Water Level Come 2 On A Wash Cycle..
The water level will never go above the lower part of the door bowl. Can you be a little more specific on your question?
Regards
Sussex Engineer
Oct 22, 2009 | Maytag MAH6500 Neptune Front Loading...
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Indesit wm12x wont finish cycle just clix through dial,can u help me ?
i suspect that you may not be draining water,if you watch the light flash it will flash at 1 sec interviles it will then stop for approx 3 secs and then start flashing again at 1 sec int,if you wait for it to stop for aprox 3 secs.when it start flashing again count how many flashes til it stops again for the 3 sec,thats is your fault code,if it is 10 or 5,then its will be your pump blocked or inop.
Apr 05, 2009 | Indesit W 123 Front Load Washer
Help!! Indesit WM12X - cold wash only
Yes, they are easy enough to replace, but you need to test them with a multimeter to see if they are faulty..
There could be other things wrong.
Nov 22, 2008 | Indesit W 123 Front Load Washer
hope this helps
kj
Oct 26, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
78 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
