Question about Canon MX700 Office All-In-One InkJet Printer
Canon MX700 network problems
I am trying to use a Canon Pixma MX700 all-in-one printer over my wired network. First I set up the Canon via USB from my Vista Ultimate PC -- no problem. Next I went to the properties page of the printer, selected the "Ports" tab, added a new "Canon BJNP Port," and filled in the static IP address of the printer. No problem. Unfortunately, the test page failed to print. I have tried all these steps on an XP Pro PC also, with the same result. What am I doing wrong?
  • 1 more comment
  • mabell_01 Sep 04, 2008
    Yes, it's the latest Vista driver
  • Anonymous Sep 25, 2008
    I set it up as well but I can't print over the network.
  • Anonymous Mar 03, 2009
    Can some1 guide me how to change the printer's IP address ? Thanks.
Once you have it installed and working on the USB port go to the properties page of the printer.
1) Select the "Ports" tab.
2) Select "Add Port".
3) Select "Canon BJNP Port".
4) Select "New Port".
5) Fill in the IP Address of your printer and select "Next".
Make sure that the Port is checked back in the properties page and select "Apply" and your done. Do a test print and your printer should work on your network. You may still need to fix the settings on your firewall or router to allow access if it does not print.
Posted on Jan 24, 2009
Thanks taftpunk!! I have been trying to figure this out for a client and finally saw this about the canon BJNP port, helped out a ton! now its an easy config for each pc.
Posted on Apr 10, 2009
Im not sure if im right or not but i dont think u can print via network. ive been trying and i can get the printer to scan and send the image to my computer via network but i cant seem to print from the computer. very fustrating
Posted on Oct 26, 2008
  • 1,800 Answers
Do u ve the copatible driver with win vista
Posted on Sep 04, 2008
Canon PIXMA MG6320 works via USB but not wirelessly
first you must have a links sys.
go to your control panel on your computer and go to view network
status and task, there you can see if your are connected if not set up a new wireless connection.
Mar 05, 2014 | Canon PIXMA Office Equipment & Supplies
Canon Pixma MX700 Won't turn on
Hi there :Did you already tried another power cable ?also tried another power source ? Try also another device on the same power source.I hope this information
will help you.
Dec 05, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Print to Canon MX700 via wireless print server (no network)
If you know the ip address of your printer, you can add that manually from add printer wizard copy first driver to your local drive.
Mar 23, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I have a mac ibook G4. I cant figure out how to set up the wifi printing aspect. Where do I find my SSID?
The MX700, although network capable with ethernet, is not wireless capable. If you're going to only use the printer with the ibook, there is little point in setting up an ethernet network. Just run a USB cable from the ibook to the MX700.
Feb 10, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Canon pixma mx700 print default
In your print dialogue box should be a setting to tell printer to print black only
Apr 23, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Im having problems with my canon printer
I'm not exactly sure what causes this problem, but here is what I did to solve it on the Canon MX850.
Go to Canon, search for your printer model (I searched for MX850, but you would do MX700), click drivers and downloads, and download the IJ Network Driver as well as the MX700 series MP Driver.
Install the IJ Network Driver first. It will require the printer be connected via USB, even if you use a network. Then install the MP Driver.
After that I was able to scan to the computer.
Nov 30, 2008 | Office Equipment & Supplies
Can't get Canon PIxma MX700 to work over my wireless
how do you make the print larger...it's coming out miniscule
Feb 07, 2008 | Canon PIXMA MX700 All-In-One InkJet...
How do you set up wireless printing w/the canon PIXMA MX700?
Hi Coach!
Here is a tutorial that will explain most of the basic steps to sharing your printer. It will walk you thru how to set it up.
With the Canon, MX700, on each machine you connect to the printer, you will have to have the driver CD. When XP asks for the drivers, just put the CD, and XP will find it drives it need. This whole process will go smoother, if you use a printer cable and not the USB. If you need the drivers, you can get them on the Canon site.
Good luck,
http://www.pcstats.com/articleview.cfm?articleID=1596
Jan 06, 2008 | Computers & Internet
Canon MX700 Office All-In-One InkJet Printer Logo
5,098 people viewed this question
old marine
old marine
