Question about Celestron Optics
Turn on hand held led display
No directions to turn it on
Needed bateries
Posted on Sep 09, 2008
Envelope postal scales by pelouse
go to a tobacco shop or a tobacco pipe shop"head shop",or ebay, Vintage Pocket Hand Held Postal Scale 0 2oz ,or here, Postal Scales Hand Held Scales , or, Items found similar to Hand held pocket postal scale keychain 100 grams... good luck,most staples will not sell them because they are commonly used to weigh drugs.
May 21, 2014 | RTO Pelouze Scale With Remote Display -...
My winding bobbin display will not go off screen. I wound a bobbin and when I moved the switch back to remove the bobbin, the display will not leave the screen. It will not go away even when I turn the...
The machine has a small micro switch under the lid of the machine that is either stuck or bent. Remove the top and look in the area of the bobbin winder and flip the winder to engage and disengage. You should see a swith that the bobbin winder pushes against. That should be the problem, if it is bent you may be able to straighten it out.
Oct 14, 2010 | Janome Memory Craft 4900QC Mechanical...
Hand held scanner to open a box?
If you were to have it open using any barcode, you could build a circuit that uses the beep of the scanner when it reads a barcode.
If you wanted it to only work with specific barcodes it would get far more complicated, you could right a program that displays a white or black box in a corner of your computer screen and just build a simple light detection circuit and tape the CDS Cell of the circuit on your screen where that box gets displayed.
Apr 23, 2010 | Uniden Hand Held Scanner - BC-246T 2-Way...
What is AMOLED screen?
AMOLED screen is the short for Active Matrix Organic Light Emitting diode.
It is highly superior to the ordinary TFT display. It is expensive too.
Nokia 5800 doesnt have it.
N82, N86 models have it.
The picture quality is amazing.
Life like pictures.
Hope this helped.
Jan 06, 2010 | Cell Phones
The hand held unit lights up when turned on, and the telescope "homes" but the LED does not show anything. The voice speaks "Bushnell Northstar" but very quietly. The telescope can be moved by the bottom 4...
Can you reverse the cable end to the hand controller-- a bad cable can cause this. Also low power supply, depleted batteries can also cause this.
Return the hand controller for replacement if batteries and or a new cable do not fix this.
Dec 24, 2009 | Bushnell NorthStar 78-8846 (675 x 114mm)...
Remove blade from sears 4 hp electric lawn mower
Most all electric mowers are held on by a LEFT HAND THREAD bolt because of the direction the motor turns. Try to turn the bolt in what would normally be the tightening direction
Sep 09, 2009 | Craftsman Garden
LG RT-42PX10 plasma - No Display
Power supply on left hand side module. check if heatsinks are cold. possible faulty. fuses and input voltages first check.
Mar 18, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Coleman 15k will not come on
Here is the troubleshooting guide for your unit. Hope this helps.
TROUBLE SHOOTING GUIDE
TROUBLESHOOTING
Symptom Remedy
1. Remote does not turn on system
- Check and replace remote batteries if the display fades while
any button is activated or no display is present. - Point remote towards IR receiver during transmission. 2. System does not turn on, no green LED & no beep
- Check wiring. (see "installation instruction")
- Check modular cable to receiver.
- Check diagnostic LED status in the upper unit control box.
3. System does not turn on even when receiver green LED is on.
- Low or over voltage condition, check diagnostic LED status in the upper unit control box.
4. Fan runs but no cold air.
- Evaporator temperature sensor reaches low limit, defrost mode.
5. System runs continuously in the cool mode
- Remote was set for "I feel" mode and is left in a heated environment (sun etc.)
6. System runs continuously in the heat mode
- Remote was set for "I feel" mode and is left in a cool environment
1. Diagnostic LED (green)
(Note: Located on the control board in the upper unit control box.)
a) The LED is on when the 12VDC is adequate and communications are
present.
b) The LED is flashing fast and steady when in the freeze mode. Evaporator has frozen and the freeze proctection switch is engaged.
c) The LED is flashing slow and steady when the delay on break timer is
activated.
d) The LED is flashing 1 cycle on and off for one second with high or low
12VDC. Check the incoming 12VDC power for OK.
e) The LED is flashing 2 cycles on and off for one second with a
communication problem. Problem with the control board in the unit and the remote.
Hope this helps.
Jeff
Rate me Please!!!
Jul 29, 2008 | Coleman Mach 15 Air Conditioner
Optics Logo
52 people viewed this question
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
