Question about Garmin Rino 530 GPS Receiver
Down load waypoints to map
I have purchased Maptech software and want to download way points to the map from my 530. I have not been able to do this, any suggestions?
There are two import/export systems in the software, I found the second for direct down loads of GPS devices.
Works great!
hinw
Posted on Sep 05, 2008
How do I save a new waypoint on my garmin 76cx?
Hi!
From your User's Manual Page 7:
You can create waypoints using three methods. Press the Enter/Mark key while at a location, create a waypoint on the Map page or you can manually enter lat/lon coordinates.
TO MARK YOUR CURRENT LOCATION
Press and hold the ENTER/MARK key until the Mark Waypoint page appears. A default three-digit name and symbol will be assigned to the new waypoint. To accept the waypoint with the default information, simply select OK.
To change any information, select the appropriate field and press ENTER to open the on-screen keypad. After entering and confirming the information you wish to use for the waypoint, select OK.
CREATING WAYPOINTS USING THE MAP
On the MAP page, use the ROCKER to move the pointer to the map item you wish to mark.
Press and QUICKLY release ENTER/MARK to capture the pointer location and open the information page for the map item.
Select SAVE. If there is no information for this point, a prompt will appear saying "No map information at this point. Do you want to create a user waypoint here?". Select YES.
If you require a User's Manual, you can view/download it from:
http://www8.garmin.com/manuals/GPSMAP76Cx_OwnersManual.pdf
Hope this is helpful to you.
Good Luck!
Feb 27, 2011 | GPS
Chat session ended by mistake. I need help with getting my Garmin GPSMAP 60 CX up and running. 1. I have successfully loaded Trip and Waypoint Manager on the computer 2. I have the unit hooked up to the...
You cannot load maps to the unit using the Trip and Waypoint Manager software. That software only does what it's called - it transfers routes and waypoints. To install maps onto your GPS, you will need Mapsource, which normally comes with the maps. Once it's installed on your PC, you hook up your GPS with a mini-USB cable, choose which maps you want transferred to the unit, and then the Mapsource software will knit the map segments together and transfer them over to the unit. Hope this helps.
Jan 06, 2011 | Garmin GPSMAP 60CS GPS Receiver
WE HAVE PURCHASED A ETREX GARMIN BLUE IN COLOR AND ARE WANTING TO KNOW HOW TO GET DOWN LOADS FOR MARINE WITH OUT PAYING FOR THE CD OR DOWNLOAD
You need Garmin MapSource (Trip and Waypoint Manager) and a data cable. Then for free maps visit the murky internet sites and beware of what you download. I would not bother with a topo or marine maps on a grey screen GPS anyway as the colour maps will not be easily understood on a grey screen.
Aug 28, 2009 | Garmin eTrex Legend GPS Receiver
Upload waypoints via laptop
Quite honestly, this is not worth the trouble. It easier to re-enter the waypoints manually. If you want to try it, you need to get some GPS connection software from someone like: http://www.gpsu.co.uk/. You cannot do it with your PC and cable alone. Good luck.
May 15, 2009 | Furuno NavNet vx2 1920C GPS Receiver
I am recovering from re-installation of my Dell XPS Windows Vista hard drive by Dell. I used Maptech version 7.03 Installer. I understand from an earlier Maptech technical forum (June 15, 2000) that I...
Try going to control panel > Add or Remove programs > Maptech terrain navigator. If it's not there, Go to Search and search for maptech. Then in the results look for an uninstall. If it's not there, look for a maptech folder and look inside that for an uninstaller.
Please rate, thanks!
Apr 24, 2009 | Maptech Terrain Navigator (Alabama)...
Cannot save waypoint on my magellan triton 200 gps.
Assuming you have installed the latest firmware. When you are on the map screen, just click on the center button and do a create a Waypoint and pick current location.
Or push the MENU button .. choose CREATE a WAYPOINT and when you GPS is on and has locked in on the Satellites . then create the Waypoint.
Mar 09, 2009 | Magellan Triton 200 Handheld GPS Receiver
I have no CD software but i want to install online software, pls
There is no software for your etrex GPS to install on your computer. You can, however, purchase Garmin maps to install onto your GPS. When you purchase this mapping software, it will include a copy of Mapsource, which is used to upload and download tracks and waypoints to your unit.
Mar 04, 2009 | Garmin eTrex Vista GPS Receiver
Topo maps a mess of meaningless lines
Sorry for late reply. You need to select an area on your topo map prior to downloading it. For example, if you plan to go to Algonquin Bice Lake (access point 4), then you need to select the map around the area (starting from) Kearney upto the Magnetawan Lake and beyond. Mark waypoints from the put-in to the campsite on Bice Lake (best to compare of the topo and Algonquin canoeing map). Then you can click Transfer, click Send to Device (GPS 76cs should appear) to download it. On the GPS, enter the Find Waypoint button and you should be able to see those waypoints. Good luck for your next trip.
Aug 03, 2008 | Garmin GPS 76 GPS Receiver
SD Card slot Garmin nuvii 260
I have found that waypoints, routes and directions work only when I load it on the unit itself as opposed to the SD card. The SD card works more like an expansion slot for pictures or maps.
When you open up Mapsource you'll see the map on the right and the pane on the left, above the pane there are 4 tabs (Maps, Waypoints, Routes and Tracks). As you select a map or create a waypoint, route or track. It will put a number in parenthesis which will increase in numbers as you add an item corresponding to each category, for example if you create a waypoint. So once you have done that, click on the TRANSFER tab in the Menu selection bar and choose SEND TO DEVICE. A window will pop up that will say...Device: with a drop down menu if your Garmin unit has an SD card in it, if not it will just show the Garmin unit. Then right below that there will be a section that says WHAT TO SEND with 4 check boxes that will say Maps, Waypoints, Routes and Tracks. Make sure that you have selected the Garmin unit, not the SD, and the waypoints, routes or tracks you want to send. I hope this solves your problem or at least points you in the right direction...
Jun 20, 2008 | Garmin nuvi 200W GPS Receiver
I've got a garmin E-Trex Vista CX and Mapsource software. After creating routes & waypoints (for Ben Nevis, Scafell Pike & Mount Snowdon) when I download these to the GPS unit each subsequent...
The contours are not coming from the routes and waypoints, they are coming from the mapping software. You must load all the map segments at once to your unit. You can upload routes and waypoints separately and they will not erase the other ones already on the GPSr unit.
Apr 21, 2008 | GPS
Garmin Rino 530 GPS Receiver Logo
52 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
