Question about NEC MobilePro 800
Some errors What do I do when I get one of the following errors when using a Mobile Pro with a Compact Flash Card or ATA PCMCIA Memory Card? * Storage Card folder is not displayed when you insert a PCMCIA ATA card and/or a Compact Flash card. * Warning message: Unidentified PC Card Adapter * Warning message: Storage Card Warning
Where can I find this file: MP8Pcm.exe ?
Thanks-
God Bless,
Ed
Posted on Mar 13, 2009
    Master:
  • 903 Answers
Download the ATA PCMCIA/CF-Card update drivers* (file name MP8Pcm.exe) from ftp://ftp.necsam.com/pub/versa/mobilepro/. Click on the link to download. After the files are extracted, follow the installation instructions in Readme.txt. *This module requires 40KB of internal RAM memory. If the MobilePro has been Hard Reset or Main memory has been erased due to main/backup battery low, this module should be re-installed.
Posted on Sep 15, 2005
2 Suggested Answers
SOURCE:
  • 903 Answers
SOURCE: Some errors
P3400I
Sir,
In My HTC P3400i the start menu containt application and setting are removed how to get them back.
Please provide solution.
URGENT.
Mar 19, 2009 | HTC S710 Smartphone
What does Windows Vista error 0x00000005 mean?
Applications that are reading file allocation table (FAT) based storage devices at the time of a resume may receive the following error message from the file system: ERROR_ACCESS_DENIED (0x00000005) This occurs although the file has appropriate sharing and access permission.
Examples of storage media that frequently use the FAT file system on Pocket PC 2002 are the PCMCIA PC Card ATA, the Compact Flash (CF) Storage Card, and the Secure Digital (SD) Memory Card.
This behavior is observed when using Pocket PC 2002 Adaptation Kit Update 4 (AKU4) and later.
RESOLUTION:
Applications can handle this situation by detecting the specific error code while reading a storage card file, and then retrying for a short period until the device is ready. The following is an example C code fragment that demonstrates this concept: while ( !WriteFile( hFile, achBuffer, dwBytesRequested, &dwBytesReturned, 0 ) &&
( ERROR_ACCESS_DENIED == GetLastError() ) )
// Access Denied: Maybe the file system is not ready yet.
tries++;
if ( tries > 4 )
break;
Sleep(500);
// It has been a few seconds. The file cannot be accessed.
You can use the same approach for other programming languages. For applications that access the storage card through middleware libraries that do not provide direct access to the file system, you may have to implement transactional or block verification methods to get reliable data transfer across a suspend resume.
Mar 09, 2009 | Microsoft Windows Vista Home Premium with...
Hi usama
Look on EBay for one. You might find one on there. You might be able to get away with using a 64mb compact flash card with a pcmcia adaptor as well as a SD card. It can't be any bigger than 64 mbs.
Search under Ricoh memory cards.
They use PCMCIA as well. If you don't have a notebook with pcmcia you will have to get an adapter card for PCI use on a desktop.
Sep 12, 2008 | Office Equipment & Supplies
Bicu firmware update
You can check on copytechnet.com on how to get it. Heres what I know about it as a copier technician.
Ricoh provides the firmware upgrades to their technicians. The firmware has to be decrypted using a special program the runs about $300 from a company in Germany. Its a proprietary archive file that gets decrypted and put onto a pcmcia memory card. You can find them on EBAY. It has to be 64mb in order for the copier to read it. I tried using a compact flash memory card connected to a pcmcia card and I didn't have any luck using it. The utlility program can lock up the notebook computer as well if it isn't setup right. You can get a pcmcia card reader for a workstation as well. Ricoh used to make those for that particular reason.
What version is it at right now?
Aug 23, 2008 | Ricoh Aficio 1013 Copier
Acer aspire 7004 flash card slot
Your computer doesn't support compact flash cards. Your SD slot is a 5-in-1 card reader, supporting Secure Digital (SD), MultiMediaCard (MMC), Memory Stick® (MS), Memory Stick PRO? (MS PRO), xD-Picture Card? (xD). The big slot is for PCMCIA devices.
Jul 12, 2007 | Acer Aspire 3000 Notebook
Some errors
Sep 15, 2005 | NEC MobilePro 770
Updates for the PCMCIA and Compact Flash Card controllers
Some MobilePro units have exhibited the following symptoms when using Compact Flash Cards or ATA PCMCIA Memory Cards: 1. Storage Card folder is not displayed when you insert a PCMCIA ATA card and/or a Compact Flash card. 2. Warning message "Unidentified PC Card Adapter". 3. Warning message "Storage Card Warning" displayed. To fix these issues: If you have a MobilePro 750C without a ROM upgrade, download the file MP75Pcm.exe from support.necsam.com. For a MobilePro 750C with upgraded ROM, use the file MP75RPcm.exe. After the files are extracted, follow the instructions in the Readme.txt file.
Sep 14, 2005 | NEC MobilePro 880
Sep 14, 2005 | NEC MobilePro 750
Compact Flash card compatiblity
I don’t know why you PDA can not read your card but I found some infrmations about parts which are compatible with e800. As far as I know this types are compatible with e800. Compact Flash Memory Card 1GB (PX1076E-1NME) Compact Flash Memory Card 512MB (PX1075E-1NME)-Type I Compact Flash Memory Card 256MB (PX1074E-1NME)-Type I
Sep 08, 2005 | Toshiba e800 Pocket PC
NEC MobilePro 800 Logo
126 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
