Question about Samsung Digimax A402 Digital Camera
Turn camera on, light flashes and then turns off
  • Anonymous Dec 19, 2008
    I turn the camera on, the green light flashes once, then it goes out, but the camera does not come on
I have a samsung A402 and didn't get any instructions with it.
i don't know how to turn off my flash or how to reset my camera cause there is so many icons on the screen and i cant get ride of all the icons
Posted on Oct 04, 2008
Turn off light
what type of camera or model you are using ?
when the camera is set to automatic mode by default the flash flickers as it calibrates the amount of light needed to capture the picutre
try to set the camera on manual settings
or if you set the camera timer on once you click the shutter button the timer will then count down and a light will blink so turn of the timer
Mar 28, 2014 | Cannon Cameras
While trying to take pictures of my son's Friday night football games, the pictures come out super dark when I use the flash. If I turn the flash off, the pictures are light, but all blurry. How can I fix...
The flash is only good up to 10 feet....are you that close? If not, turn off the flash and turn up the ISO to make the camera more sensitive to the lower light levels.
Oct 09, 2010 | Samsung L200 Digital Camera
How do I turn off the red eye light onnikon D70s
To turn off red-eye reduction mode, pop up the flash, then hold the flash button down while turning the command dial on the back of the camera to select the desired flash mode.
The same light is also used for focus assist. To disable that, you'll have to go into the menu system.
Jan 22, 2010 | Nikon D70s Digital Camera
Flash on camera not working lg viewty
hi, even i have the same problem, probably i don't think the flash doesn't work, but even i didn't know how to use it. however, the instruction manual says there are 3 options in flash, they are auto- that is it turns flash automatically on when it turns on. red eye reduction that is it says it will flash twice to reduce red eye but i never see the flash on and the flash off, that is it will not turn on and usually whenever you exit the camera the flash will default to turn off mode. you will need to switch the flash back. hope you understand.
Jan 20, 2010 | LG KU990 Viewty
Manual light & exposure settings
if you are using flash lights on the art work, please follow the following steps
  1. turn off your flash in cam since it bypasses the external flash and makes the picture look different.
  2. turn your light settings to either automatic or "flash light or arc light".but do not set them to incandescent light!!!
  3. turn your macro to on status if you are going to take a close up shots, but please note that close up shots work great in natural sunlight than at flash lights...
Sep 13, 2009 | Fuji FinePix S2000hd Digital Camera
Flashing Red Light....
The flashing "boat" in the middle of the viewfinder just means the button battery is dead. Camera will still work. It's the little pull-out light grey plastic thing that's next to the heel of your right hand when you're using the camera normally. You need a CR2025 cell.
Jan 27, 2009 | Canon XL1S Mini DV Digital Camcorder
Red light continually flashes, and won't take picture
Set the camera to anything except no flash. Turn it off. Take out the battery. Wait 5-10 seconds. Put the battery back in. The flash should now work until you turn the camera off again (and then you must remove/replace the battery to get the flash working again).
The flash requires some kind of "master reset" to work. Haven't found a permanent solution to this.
Mar 05, 2008 | Casio EXILIM ZOOM EX-Z850 Digital Camera
I can't remember how to turn the flash back on to auto flash?
  folloe these steps
camera<settings <Flash< turn it on .    or camera<more<flash<turn it on
Oct 16, 2007 | Sony Ericsson K750i Cellular Phone
Pictures reddish or orange
Although normal room lights (tungsten lights) appear white to our eyes, their light is actually much "warmer" than daylight, giving a reddish or orange color to pictures. This happens with digital and film cameras. To prevent or lessen this reddish or orange color: If your digital camera has a selectable White Balance mode (check your camera's User's Guide) and you are not using the camera or external flash, set the White Balance mode for "Tungsten" light. If your pictures are reddish even when you use the camera flash or external flash, the room lighting is overpowering the flash. Try setting the White Balance mode for "Tungsten" and continue to use the flash. If your camera does not have a selectable White Balance mode, use the camera flash or external flash when taking pictures in lighting that makes your pictures turn out reddish or orange. If you can, turn down or turn off one of the room lights (without making the room too dark), or move your subject so that it is not being hit directly by the room lights. If you can, when taking pictures in the daytime, try opening any drapes that might be covering windows. Letting in natural daylight improves the color quality of the lighting.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Samsung Digimax A402 Digital Camera Logo
216 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
