Question about NEC MobilePro 800
Connect to a Windows Terminal Server
Do I need to install any software on the MobilePro system to connect to a Windows Terminal Server?
    Master:
  • 903 Answers
Yes. You need to install the RDP client software which can be downloaded from Microsoft. Procedure to install the RDP client on a MobilePro 880: Note: Steps 1 and 2 need to completed if you have not installed the Service Pack One for MobilePro 780 and 880. 1. Perform a "Hard" reset on the MobilePro 880. 2. Install NEC Service Pack 1: http://support.neccomp.com/kbtools/faq/mobilepro/mp1.asp 3. Make sure the Device Name is set to something other than "Handheld PC". 1. Start-Setting-Control Panel-Communications 2. Change Device Name to a Unique Name that is not currently being used on your network. 4. Establish a Partnership with a Host using active sync. 5. Disconnect the MobilePro from the host. 6. Install "hpcrdp.exe" on your host. It can be down loaded from Microsoft: 1. Go to http://www.microsoft.com 2. Select "Search microsoft.com" under the Search tab. 3. Type "hpcrdp" in the search box and depress Enter. 4. Look for the search results titled "Terminal Server Download for Windows CE". 5. Double click on the article and follow the link and at bottom of the Terminal Server License agreement you will find the link to bring down the RDP client. 7. Establish an Active Sync connection between the host and MobilePro 880. 8. The RDP client software will be installed on the Mobile device. 9. Install a NE2000 NIC (or any NIC that you have the MIPS CE drivers for) into the Mobile Pro 880. 10. Set up network and attach to your existing network. 11. Set up a RDP session: 1. Start-Programs-TerminalServerClient-Client Connection Wizard 2. Enter Description connection. 3. Server Name or IP address. 4. Next 5. Enter user name, password and domain if you want to logon automatically. 6. Next 7. Finish If your terminal server is set up correctly you should be able to connect as a Client.
Posted on Sep 15, 2005
How to solve the mysql error 2003 Can't Connect to mysql server on 'localhost' (10061)
Your client software attempts to connect to a MySQL database instance on your local computer. There is no DB server running locally, hence the error.
Before reinstalling Windows, did you connect to a remote DB server or did you use a local instance?
In former case, you need to configure the DB connection to point to the remote serve. In the latter case, on top of Windows you also need to reinstall the MySQL DB server software locally, and it needs to be started.
Feb 27, 2013 | Sun MySQL
Setting up Terminal Services on Server 2003 at the head office of a client in a workgroup environment, no Domain Controller. The branch office wants to log in through a VPN Router ( Linksys RV042 that has...
Assuming you can connect via Remote Desktop without any issues...
Printing through Terminal services requires that printing be enabled in the Terminal Services Configuration (Client Settings Tab). It also requires that the printer driver be installed on the Terminal server, not the actual printer (as it shows under the control panel) but just the driver. You can install just the driver by going to File/Server Properties under Printers and Faxes ON THE TERMINAL. Install the printer normally on the client machines.
Note: For a printer to work via Terminal services it needs to have a compatible driver (which I believe is called PCL??) So some consumer printers (the ones that only come with Setup programs, not just driver packages) will not work. The majority of HP Officejets and laserjets are fine, as are Brother lasers.
Oct 27, 2009 | Microsoft Windows Server 2008 Terminal...
How can i connect client computers to server where clients have no hard disk.How clients can boot and access hard drive of server?
u can connect with ur client through terminal server. for that u've to server 2003. u can see the steps that how to configure terminal server for that u've to go this link:
http://support.microsoft.com/kb/300847
Sep 25, 2009 | Microsoft Windows Xp Home Edition Sp2...
I am a Computer idiot. How do I instal drivers/apps?
You need to download ActiveSync 3.8 to your XP or earlier computer. It won't run with Vista. You also need a serial port to connect your mobilepro to your computer with the data cord that comes with the mobilepro. You can then sync your computer with your mobilepro.
Mar 10, 2009 | NEC MobilePro 880
Erro 647 when trying to connect 770 to desktop with windows xp
I had the same thing happen to me.. The site below will fix you up just follow all the steps.. Some things are worded slighty different in XP so just use common sense for those things..
Just make sure to set your Computer as HOST when it asks.
Also I could not find the mobile devices or something like that tab in Windows XP but it still worked.
http://www.pocketpcfaq.com/wce/21/windows2000.htm
Apr 05, 2008 | NEC MobilePro 770
Terminal server not responding
Are you receiving errors in the "event viewer"? And if you are what are they?
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Oct 20, 2007 | Computers & Internet
Sep 15, 2005 | NEC MobilePro 770
Windows NT server using RDP client
To resolve this issue download the MobilePro Service Pack 1 and install it on your system: ftp://ftp.necsam.com/pub/Catalog/3959/MobileProSP1.asp
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
Software on the MobilePro system to connect to a Windows Terminal Server
Sep 14, 2005 | NEC MobilePro 880
NEC MobilePro 800 Logo
218 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
