Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Water Dispenser Shooting Out Water (KitchenAid Superba)
Water just started shooting out of the water dispenser and could not be stopped except for when the power was disconnected to the entire refridgerator. Any idea how to fix this? Also, is there a way to shut the water supply off to the ice/water dispenser (Valve somewhere).
    President:
  • 1,462 Answers
Check where water inlet is and water inlet is connected direct to the inlet valve - normally a double valve ie one water inlet and two water outputs. just disconnect wires from valve, making a note of where they go and tape them up
Posted on Sep 04, 2008
Kitchenaid Superba water dispenser randomly activates once or twice daily, without any pressure on the dispenser bracket. If I pull on the bracket, the leak stops. The spring does seem to be functioning,...
This is going to be a tricky one even for me to solve but going by what you say that the dispenser is randomly activating sounds like a keypad problem (item 20 in photo) inside the dispenser control panel found here=> 2224064T Front Cover Assembly Can you confirm your model number for me? It may take a little of Q&A until I am sure of the problem. Sea Breeze
Aug 21, 2013 | KitchenAid Superba Architect KSCS25INSS...
The water dispenser stopped working but the ice dispenser still works just fine on my KitchenAid Superba KSRG25QFB side by side
First Question, Have you changed the water filter???needs to be done every 6months. dirty water filter can keep water from flowing through system......also nasty to drink.........
Jan 09, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Water Dispenser not working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Aug 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba 42 side by sside water dispenser
usually when i get a kitchen side by side i trouble shoot the wtr valve first by using a cheat cord that applying volatge directly to the vlave to see if it opens but usually the wire harnes under frezeer breaks the wires so my money is on the wires under the frezerr door cut the sleve off and chec the wires one by one the one to the water is broken
Oct 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Side by side daewoo american frige freezer
Many possibilities, calcium build up broke loose and a granule is stuck under valve, pivot screw loose or missing, rubbe seat hard or cracked, first see that vale accuater ( the thing you push your glass against is un obstructed and moving freely, then try rapidly opening and closing, to dislodge any thing. If that doesn't work shut off water and disconnect, past ice maker valve, blow
back ward with clean compressed air ( 5lbs psi ) while holding dispenser valve open. Reassemble and test. this should do it , if not start looking further.
Sep 07, 2008 | KitchenAid Superba Architect KSCS25INSS...
KItchenaid Superba KSRB25QABL water dispenser
Chances are is a bad water valve.  The water valve is on the back of the fridge at the bottom.  You will see the water line going into it.
Oct 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
273 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
