Question about Angeles Bye-Bye Buggy Stroller
Angeles Bye-Bye Buggy Stroller 6 Seat
My front wheels shake and shimmy . It happens when it is fully loaded and also only a few kids. Hard to push like this, what should I do?
  • Anonymous Jan 12, 2009
    I want to replace all of the wheels and tires! we have replaced bearings and repaired the wheel/tire one too many times! Where can I order new wheels and tires?
  • Connie Glasner May 11, 2010
    Hi Diane,
    I am with Angeles and I am sure I can help you with your problem if you could just supply me with a little bit more information.
    1) Is your Buggy a 4 passenger or 6 passenger.
    2) What is the approxmate date you purchased your Buggy.
    3) Do the front wheels have thin tires (1 1/2" width tire) or fat tires (4" width tire)
    I look forward to working with you to resolve your problem.
    Connie Glasner
    Quality Assurance
    Angeles Corporation
    cglasner@angeles-group.com
Instructions on how to fold
Kindly follow the steps to below to fold the stroller:
  • Use the ball of your foot to push down on the brake lever, located near the rear wheels of the stroller. Gently push on the stroller to confirm that the brakes are set. Grip the front edge of the stroller's canopy, if present; pull the canopy back towards the rear of the stroller.
  • Push the tabs securing the ends of the harness straps to the harness buckle. Pull the straps aside and remove the child from the stroller.
  • Kneel down next to the stroller's front wheels. Locate the locking mechanism set in between both pairs of front wheels. Use the locking mechanism to disable the swivel feature on the front wheels.
  • Pull the stroller's seat back down to the lowest position; some models may feature locking mechanisms located on the sides of the stroller or built into the handlebar. Lift any latches securing the sides of the stroller in place.
  • Push the handles of the stroller downward. Push the rear section towards the front of the stroller until the device is fully folded. Clip the storage latch located on the side of the stroller to the side of the handlebar.
Apr 24, 2016 | Baby Gear
How can I fold?
Kindly follow the steps below on how to fold the stroller:
Apr 16, 2016 | Baby Gear
When in 'swivel' mode front wheel turns wildly making it difficult to control and even stops the buggy when the wheel 'stick' at right angles to the buggy
In normal use, the front wheel needs to swivel freely - then this stroller's drive is easy and manageable with one hand (we know from extensive use with 2 kids and shopping on board).
The front wheel normally can not collide with the car. If the wheel assembly / lock is not correctly inserted, it can lock / unlock uncontrolled: try to disengage and mount the front wheel unit again.
Unsufficient tire pressure can also detoriate the drive.
Dec 20, 2015 | Regal Lager Phil & Teds Sport Buggy Double...
How do I let the stroller down?
    Kindly follow the steps below to fold the stroller:
Sep 09, 2014 | Evenflo Aura Traditions Travel System...
We have a tire that is broken can you please tell me where to get a replacement tire?
hi have you tried here
http://www.angelesstore.com/index.php/component/option,com_virtuemart/Itemid,80/category_id,9/page,shop.browse/
Oct 26, 2010 | Angeles Bye-Bye Buggy Stroller
My stroller on the back right hand side feels like
Hi
Visit www.buggypitstop.co.uk/ quick and expert advice plus can fix it for you at a reasonble price.
thanks
Apr 29, 2010 | Angeles Bye-Bye Buggy Stroller
My quinny buzzy 4 is hard to fold
If you lock the front wheels and lower the handle bar to the lowest postition first, this will make the chassis as small as it can be. Remove the seat/car seat or carry cot if this is on the chassis.
Then, stand in front of the chassis, with the front wheels between your legs.
Push down the grey rectangle button on the left hand side, then pull toward you the right hand rectangular button then push this button downwards,
Then, withnthe two buttons still pushed in, with your full body weight, push the chassis downwards the floor until fully folded.
I hope this helps.
Mar 25, 2010 | Quinny Buzz Three Wheel Stroller
Safe tech tripple stroller
On my stroller there is a little plastic piece just above the front wheels.  If you push it to the left it will lock the wheels.  Push it back to the right to unlock the wheels.  You may have to push a little hard to move it.
Oct 22, 2008 | SafeTech Triple Jogging Stroller
My jogging stroller shakes
Well, i'm not positive in this, seeing how I never had kids, but while jogging are you pushing down harder on the stroller? or you could look for smaller wheels to put it on, but then again you might have'ft to bend over to do it, and if the handle which you push is tall that has to do with force viberating the stroller
Nov 29, 2007 | Baby Gear
Baby Gear Logo
226 people viewed this question
Top Angeles Baby Gear Experts
Dorel UK
Dorel UK
Are you an Angeles Baby Gear Expert? Answer questions, earn points and help others
