Question about Samsung Televison & Video
Samsung LE22S86 does not have good dvd images
Hi!
just bought this flact lcd screen second hand but it has no users guide or drivers for pc monitor use. TV reception is good but when connected to our new phillips dvd player or to our sony dvd player the images are opf poor quality. Have tried via scarts and the red- yellow - white pins leads.
Seems to be a setting within the screen itself perhaps?
  • sharonemille Sep 04, 2008
    Thanks Jerbhill!
    Have done that - I can connect the dvd to the lcd tv via a scart lead and/or the r-y-w pin leads but either way of connecting up means that the played dvds aren't as good quality as they were on old portable tv! And I am allowing for better quality images from the 19" new flat screen.
    Is is because there is an analogue (older dvd player) & digital (new lcd tv) conflict? Can this be got round by using as hdmi scart or have i got to buy a new dvd player? The phillips one I have now is less than 2 years old and one of the slim region-free ones.
    Really glad of help and thanks again
    Sharon
  • sharonemille Sep 05, 2008
    Thanks - now I know what's wrong.... and how to fix it! Really appreciate your help :-)
    Problem Solver:
  • 10 Answers
If you go to the samsung website for uk at www.samsung.com/uk/ you can search for that model and download the manual in pdf format. If my link pastes OK, here is where you want to go:
http://www.samsung.com/uk/support/download/supportDown.do?group=television&type=television&subtype=tftlcd&model_nm=LE22S86BD&vType=L&mType=UM&dType=D
good luck.
Posted on Sep 04, 2008
  • Herb Sep 05, 2008
    If the dvd player is analog, then that will be the problem. The nice thing about high definition is that it shows more data...that is also the problem as it shows how big the pixels used to be and that gives you a grainy picture from analog video.
Samsung LCD S27B350H blinks during 45 minutes after power on
The backlight is failing, or you have some other power supply problem
Sep 21, 2012 | Samsung S27B350H - SyncMaster S27B350H -...
My screen is totally black and will not turn on the computer but the green light is on???
Most likely a screen problem. Are you able to try another monitor with your PC? If a different monitor works, then the problem is your monitor. Most LCD monitors have a rather short life span (well, much shorter than the heavy old CRT monitors). But whichever kind of monitor you have, it seems to be getting power but is unable to display an image.
If your monitor is an LCD monitor, then the problem could be the backlight. If you take it to a computer repair shop, they should be able to replace the backlight - if it's cost effective to do so. Without knowing more about your monitor it's difficult to judge what the best solution might be. Sometimes it's cheaper and easier to get a second hand screen from Ebay rather than fix an obsolete LCD screen. On the other hand, if you bought the monitor within the last 12 months and spent a lot of money on it, it may well be worth getting it fixed.
Oct 10, 2010 | Computers & Internet
Screen shows no image when hooked up to my pc either as primary monitor or as secondry... The screen works I just have no image.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Free Service manuals: http://elektrotanya.com/?q=showresult&megnev=SAMSUNG&megnev2=713&kategoria=&kat2=all
May 10, 2010 | Samsung SyncMaster 713BM 17" LCD Monitor
Screen shows no image when hooked up to my PC either as primary monitor or as secondry... The screen works I just have no image.
You may have failure in the backlight inverter circuits, power supply, lamps. First thing to look will be the capacitors in the power supply section, look for caps with bulging top/seal. See example of failed SAMSUNG monitors here: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net/
Post back what you see inside so we can guide you further.
Mar 23, 2010 | Samsung SyncMaster 713BM 17" LCD Monitor
Samsung 931B Monitor Screen will not stay
jane657, Hi there. Will you stop pushing the On/Off button on your lcd/fpd. It's Broke. Period. End. Finito!!! You will not fix it. However there is one test that you should do to determine hoe bad the problem is. You will need to reconnect the 931B to a known good pc that has been fully booted and has the WIN-DESKTOP or IE fixya web page showing. quickly connect the931B to the wall outlet and the PC. Turn on the monitor!!! Yes, I know it will only come on for a second..After the screen goes to BLACK, Shine a bright flashlight onto the screen at different angles, 1-2 inches from the screen. Let me know if you see something even though the screen is black. Anyway here are your options as a consumer/user. 1. Check if unit is under warranty. 2. Check withh Samsung to see if they have a SWAPOUT program. You send them your monitor+$40-$90 and they return a refurbished same model to you with a 30 day warranty. 3. Trade in for new monitor. 4. Check with local TV/Monitor repair guy who knows all there is to know about cold-cathode-fluorescent-tubes, their power-source(inverter type) and lcd monitor power supplys (SMPS) 5. Repair on your own. Not recommended for amatures with no solid state troubleshooting skills and no instrumentation for support. Bye for now. I'm louie12fix on fixya or lmistyrel@ aim.com
May 14, 2009 | Samsung SyncMaster 931BF LCD Monitor
When i turn on my monitor it shows my desktop then shuts off after 10 seconds...never stays on
elainenemeth, Hi, Tell me more! How old is this LCD monitor? Is it out of warranty? Did the "SHUT-DOWN-IMMEDIATE" problem occur without warning? Did the BenQ display a "perfect" image the day before? Did you actually count----1001, 1002----1010 and then it shut down, after pushing the monitor on button. Did you do the "flashlight" test? With monitor connected to a "known-good", fully booted pc with Win Desktop displayed, TURN ON the monitor! Did it display the desktop for 1-2-10 seconds ? What did you see or not see when you pointed the flashlight at different angles about 1-2" inches from the now dark (black) screen? Get back to me with your results. I will offer the best advice possible to you as a consumer/user of LCD/FPD monitor. I'm louie12fix on fixya or lmistyrel @ aol.com Bye for now.
Apr 17, 2009 | BenQ FP71G 17" LCD Monitor
Monitor Problem
1. Try using a different media player like k-lite windows media player classic or GOM player.
2. Is the lcd set at it's native resolution ? Set it to native resolution.
3. Has the driver for the lcd been installed and does it show up properly in device manager ? Install the lcd driver if applicable.
4. What are your system's specs, especially graphic card ?
5. Has the latest graphic card drivers been installed ? Install latest drivers.
6. Does using VGA or DVI make any difference ?
7. You would've probably already checked windows media player settings.
Hopefully some of these will solve the problem.
Dec 22, 2008 | Samsung T190 19" Widescreen LCD Monitor
I have 2 samsung 710N LCD monitors that are exhibiting the same symptoms. When they are powered on, they display fine for about 10 seconds, and then go completely black. If you turn them on and off again,...
hi
I am a technician-informatic. I have repaired about 40 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it on eBay.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Mar 19, 2008 | Samsung SyncMaster 710N 17 in. Flat Panel...
ACER LCD monitor no image, appears white color only
Quickly go to the Acer website and check FAQ's and while there also find out how to get an RMA to return it. My guess is you have a bad monitor. At $200 roughly for a replacement I would hustle. I am assuming you got nothing but a white screen but did get video on your TV.
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
Televison & Video Logo
116 people viewed this question
Henry  Thomas
Henry Thomas
