Question about GoVideo Televison & Video
The dvd door doesn't open - GoVideo Televison & Video
    Guru:
  • 1,894 Answers
Plug out the player for 5min from wall power and then plug in.
else you wil have to open the player and push it out manually.
Posted on Sep 04, 2008
  • 1 more comment
  • dewan nafees ahmed Sep 04, 2008
    plug out the player for 5min from wall power and then plug in.
    sorry. due to some slow connection it got posted twice.
    look for a pin hold near the player door.
    if present you can use a safety pin to push a lever which you can feel with help of pin.
    if the lever is pushed it the door is pushed out by force.
    try this and post back the results
    thank you
    keep the replies and results posted.
    that will help us to guide you better.
    thank you
    good luck
    Master:
  • 726 Answers
mahgupyour a twit thats not a good ansew u *******
Posted on Sep 07, 2008
  • 4,234 Answers
The DVD will be mechanically locked in place if the load sequence has completed. Any attempt to force the unit open will break the gears or jump some teeth which will prevent hte unit from working properly. Unplugging the unit should reset the unit to the "home" position. If eject does not work at that point, post here if you can hear hte motor attempt to work. If you hear nothing, there are a couple of possibilities, none of which are simple for the homeowner. If you hear a whirring, the loading belt may be slipping. If that is the case, gently lift on the clamper and hit eject, that may release enough tension to allow the unit to unload. The clamper is the center disk that magnetically clamps the disc to the table that spins.
Keep us posted on your progress.
Dan
    Genius:
  • 2,035 Answers
If the DVD door does not open then try to press manual switch eject if this does not work then try on the remote even this fails then unplug the unit form mains for 30 min and power it on try again if this fails ,there some DVD model with small pin hole next tray .insert a this thick wire then trey will open , this could the result of the hard ware failure you need to get it serviced by the company if its under or get it in local DVD player repair center...
Good luck...
    Brigadier General:
  • 5,158 Answers
Are all the lights on ?
  • 87 Answers
Turn off power and start
94 VW Golf Rear cargo door won't open
you might have hit hard to close the door. open door pad n try to open the gate
May 14, 2013 | 1994 Volkswagen Golf
Dvd door doesn't open
if there is a small hole on the panel of your dvd drive push a straightened paper clip inside until you feel it press down this will open up the drive
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrative tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
hope this helps
Sep 24, 2012 | Computers & Internet
Won't spin
Hello
The loading mechanism to your player is faulty. It doesn't engages the disc in to place perfectly. Replace the loading mechanism.
Mar 07, 2012 | Lite On LVW-1105HC DVD Recorder
Door doesn't open
Try to reset the DVD. Unplugged it for 24 hours... If it doesn't work it need service because the internal rotating part need replace.
Jan 18, 2012 | Apex Digital AD-1110W DVD Player
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
Computer BIOS recognizes the SATA DVD Rewriter but Windows XP does not. The drive opens the loading door but it does not appear in the Windows XP explorer (My Computer).
Windows XP doesn't nativey support SATA. Check in BIOS to see if your motherboard supports sata to IDE emulation.
Comment back if you need further assistance.
Aug 17, 2011 | LG GH24LS50 Super Multi DVD±RW (±R DL) ...
The door of my Toshiba sd-6100 dvd player will not open. There's a dvd inside and it will play but it will not eject. How can I open it manually?
Try unplugging the DVD player from the outlet for 2-3 minutes to reset the unit. If this doesn't help, the player probably needs to be serviced.
I hope this helps.
(if the unit is out of warranty, you could try opening the case and removing the DVD drive. There should be a manual ejection button hidden on the front of the drive. Unfortunately, doing this to get your DVD out voids the warranty, if it is still under warranty. Each manufacturer puts this button in a different place. On computer drives, the faceplate has a hole to indicate the spot. The ejection usually takes some force with a straightened paperclip (or small allen wrench).)
May 12, 2011 | Toshiba SD6100 DVD Player
DVD door will not open and eject DVD. It says it's opening on the screen but it does not open. DVD is stuck in there
Hello
Either its loading belt in the DVD mechanism, or its loading motor has damaged. It is common that the loading belt will get loos of break. Loading belt is a small belt fasted between loadin motor to loading gear mechanism. Replace the same first. You have to open your TV and pull out the DVD mechanism outside for repair. If replacement of loading belt doesn't help, loading motror is faulty, and should be replaced. OK.
Apr 24, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
Televison & Video Logo
211 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
