Question about Canon Cameras
Camera locked up error code (compact flash error)
  • Canon Master
  • 4,738 Answers
Remove the card and look in the slot for a bent pin. If you see one, remove the batteries also. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. Take your time and use as much patience as you can muster (take a breather in between if needed).
It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Posted on Sep 05, 2008
Memory cards are locked but the card is not locked
It's unusual that an A95 would report "card locked" as it uses a compact flash card which is incapable of being locked. Please verify the model of your camera, and the card that it uses.
In the mean time, I'll assume that actually own a different camera that uses SD cards. If so, please see this link for troubleshooting tips for SD card locked problems.
But if you indeed own an A95 with compact flash, the problem may possibly be caused by bent flash card pins inside the camera card slot (take a look inside using a flashlight). If bent pins are found, then see this link for a possible home fix.
Apr 15, 2010 | Canon PowerShot A95 Digital Camera
My camera canon eos rebel xt has an error code cf what does that mean ??? my camera doesn't since that code appeard.
CF probably relates to the Compact Flash memory card. It may be time for a new one. They're very inexpensive and a replacement would be the first step to discovering the problem.
Nov 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Cannot retrieve photos from SanDisk Ultra 11 4GB
Card probably became corrupted. Try running a Memory Card Recovery Program. If that doesn't work take it to a place that'll do that type of thing professionally, a lot of electronics and computer stores do this for a small charge.
http://www.artplus.hr/adapps/eng/dpr.htm    <<<Free Recovery Program
Dec 23, 2008 | SanDisk ULTRA II 4GB Compact Flash Card...
Locked Memory Card
I use a Nikon D300 and have Sandisk Compact Flash memory cards. i ahve not come across this problem but would suggest that you insert the memory card into your camera and reformat the memory card. This should clear any errors in the system BUT IT WILL ALSO WIPE ANY PHOTOGRAPHS YOU AHVE TAKEN when formating the memory card.
Oct 20, 2008 | SanDisk ULTRA II 4GB Compact Flash Card...
Nikon D70, displaying error code 'CHA' when memory card inserted. Unable to format or use memory card. Have tried new memory card, still same problem.
CHA errors indicate a communication issue with the CF card. Your card could be going bad, you could have a broken pin, or any number of other problems.
I'm running into this same problem now. If anyone has a good step-by-step to troubleshoot which of the dozen things this error could be, I'd appreciate it.
For myself, I'm planning to start by trying a new CF card.
Sep 02, 2008 | Cameras
Media selection
have you tried using a different brand?
May 07, 2008 | Fuji Finepix S9600 Digital Camera
"Card Locked" error is false!
Remove card from SD600 camera. Locate sliding switch on side of SD card and move from lock to other (unlocked) position. That ought to do it. Compact flash card is another issue.
Mar 19, 2008 | Canon PowerShot SD600 Digital Camera
Compact Flash Problems
Dynamite,
have you tried to reformat the CF card?  If you deleted the image through your computer and not with the camera, the computer may have removed more than what was needed...
SteveK
Oct 27, 2007 | SanDisk ULTRA II 4GB Compact Flash Card...
Cameras Logo
49 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
