Question about Mitsubishi VS-50703 50" Rear Projection Television
Mitsubishi vs 50703
My 50:" 50703 is black but has sound...if i go to menu the picture is on the right but not in full screen...how can I fix this?
  • Anonymous Jan 19, 2009
    We have the same problem! Help!
  • stevow57 Mar 22, 2009
    We are having this problem too.  We have directtv and can only see a small screen in upper right corner after pushing the menu button.  In this picture, I do see my directv channels and I am able to change them but cannot get the big screen picture back.  It will also turn off after 3 or four minute if I am not working in the Menu.    DVD still works fine.
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi VS-50703 blurry after move
A halo effect usually means the coolant in the CRTs need replacing in the effected color usually blue goes first followed by green. red seems to be less prone for some reason.
Posted on Jan 14, 2008
MikeMaierTV
  • 206 Answers
SOURCE: Black box in the middle of my mitsubishi tv
This is a common problem, some how you have the closed caption on and turned to the text mode. So to fix this scoll through the tv's menu and find the closed caption and tur it back off
Posted on Mar 27, 2008
SOURCE: mitsubishi model vs-5043
I just had this same exact problem. I looked for an answer on here and could not find one. So I took the back off, vacuumed and cleaned everything out with the hose on my house vacuum, cleaned the bulbs and wiggled them around some. Voila !!!! lights on and all is working fine and better then ever. I hope this helps someone fix their problem. Just saved me tons of money and a morning of hassle.
Posted on May 06, 2008
redfury111
  • 100 Answers
SOURCE: Mitsubishi VS-50703 Picture Foggy
Open up the back and look for coolant leaks in the CRT's. If you are curious as to what it is, it's the same type of stuff they use to make antifreeze. If you see something wet, it should feel slippery if you get it on your fingers and rub them together.
Posted on Aug 13, 2008
deltamech
  • 5 Answers
SOURCE: no picture but sound
I had the same problem with the same model. If you pull the cover off the speakers in the front , then the small black panel. looking from the front past your lamps are the 3 main boards, the r/h board has wire jumpers connecting to the center board. The set that is closest to you had a bad/loose/corroded connection on mine. All I did was resecure connection(try moving them with your fingertip) and turn TV on and check.
Posted on Feb 02, 2009
I have sound but no picture
Use your mitsubishi remote and press the menu button which will open up the menu screen and you will see the picture in the upper right. Now you press 1370 then the enter button and you picture will be restored. This is the factory reset for all mitsubishi projection tv's
Dec 03, 2011 | Mitsubishi VS-6043 60" Rear Projection...
Mitsubishi VS 50607 big screen no picture and no sound blue black screen
HELLO. your problem is mostlikely in your singal u are putting to it . where u have it hook up to. or in your setting in your menu. are not right look at where you are put or cable in or ant in and put it on A or B. THEN WITH YOUR REMOTE BRING UP THE MENU AND GO TO SET UP THEN TO SEE IF YOU HAVE IT SET TO CABLE OR AIR.? ONCE YOU KNOW WHAT IT ON SET IT TO WHERE YOU HAVE YOU CABLE OR ANT HOOKED UP TO. (A) OR (B) then run the auto program. and see if it work's hope this help's u . rember to vote for me thank u.
Jun 08, 2011 | Mitsubishi VS-50607 50" Rear Projection...
Hey I have a mitsubishi vs-80803 i have picture but it is a bit bowed on the right side and bottom of picture (black curvature space showing no colors or picture) maybe the convergence needs to be reset?...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 05, 2010 | Mitsubishi VS-80803 TV
Has sound and menu, but no picture
it is in your CRT socket board apply fresh solder or some areas of tv circuit board have cold solder.
Aug 17, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
May 13, 2009 | Mitsubishi VS-50603 50" Rear Projection...
Mar 27, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-4541 too much red
The set is old and the picture tubes are probably weak. you can pop off the front grill, remove the protective panel to expose the picture tube sockets. On the sockets are controls to increase or decrease the intensity of the colors. The red is on the left ,green center and blue right. Go to a B&W picture or turn the color off, then adjust for the best grey screen.
Jan 03, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Televison & Video Logo
130 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
