Question about Sony DVP-S360D DVD Player
Sony RDR-GX360 won't respond to any buttons on unit or remote. Only function that works is power button. Disk tray won't even open.
  • Sony Master
  • 8,457 Answers
Try unplug,replug the unit back like about an hour later for the unit for resetting itself back to factory setting.If getting the same result the unit might have a shorted motor drive for the disc tray.Or shorted control panel on the unit itself.Well,this thing a basic DVD player only wright?If u can tries take it aparts and check out tries to repair it ur self that great.If u tries the shops,not worth it.Trash it.These basic DVD player only are very cheap now.U can get one brand new like $40 dollars.
Posted on Aug 11, 2011
SOURCE:
Hi I have a sony dvd recorder gx360 that will not work with my remote. When try, it displays dvd 2 on front of the panel. I think its locked, how do I unlock it?
You have got the wrong remote code!
I have copied this from the manual....
Set the command mode for the remote so it matches the command mode for the recorder you set above. Follow the steps below to set the command mode on the remote. A Hold down ENTER. B While holding down ENTER, enter the command mode code number using the number buttons. Command Mode DVD1 - number button 1 DVD2 - number button 2 DVD3 - number button 3 C Hold down both the number buttons and ENTER at the same time for more than three seconds.
The correct "default" for the remote is DVD3!
The full manual is available free on this website:
http://www.manualslib.com/manual/228795/Sony-Rdr-Gx360.html?page=23#manual
Mar 08, 2016 | Sony Televison & Video
Sony error codes
I need a sony laser assembly for rdr - gx360 recorder.....where can I get one?
Sep 01, 2014 | Sony RDR-GX360 DVD Recorder
Rdr-dc100 locked
The child lock is on. Press the power off until just the time shows in the display. Then press and hold the stop button until the display shows "unlocked". You should be able to open the tray now.
Feb 19, 2012 | Sony Televison & Video
I have a sony rdr-gx 360 with no remote and tey are very expensive to replace. can i get a universal remote for this?
Many universal remotes will operate (with some limitation) most SONY products including DVD recorders. You can maybe find a universal remote either on eBay, remotes.com website (or similar addresses) or perhaps your local electronics store has them in stock - and those are relatively cheap to buy off the shelf. It would then be a question of figuring out and entering the right code for it to (minimally) control the unit. The best universals are the all-in-one types although a 4-in-1 works just as well. Elaborate function remotes will cost more than the basic ones.
Feb 21, 2011 | Sony RDR-GX360 DVD Recorder
Sony gx360 stuck on dvd1
press and hold enter on remote... then, while holding the button (more than 3 seconds) press and hold down the number 1. after 3-5 seconds, things should return to normal.
Nov 10, 2009 | Sony RDR-GX360 DVD Recorder
Player stuck on DVD 1
Thank you for your assistance. Apparently this problem was not unique to me. There were other users who had posted this problem and a few people responded with the solution.
Thanks again,
Mark.
Mar 23, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Disc tray will not open
I've not found one, no, but I have managed to strip the machine down, get the disc out and rebuild... I guess this is too late for you but it's simple enough if you're still trying.
Mar 04, 2009 | Sony RDR-GXD360 DVD Recorder
Sony rdr gx360 only responds by displaying "DVD3" to remote cntrl
http://www.docs.sony.com/release/RDRGX360_EN_ES.pdf
Page 23 in the manual. Had the same problem. Press and hold ENTER and 3 for at least 3 seconds. Problem fixed
Dec 17, 2008 | Televison & Video
DvdRDR-GX360
It´s is easy to solve. Your DVD was seted to DVD1. Push enter button plus 1 no remote control.
Now you are able to commnad your DVD and go to System Menu and change to DVD3 again.
After it, don´t forget to backup your remoto control to DVD3. Push enter button plus 3
Dec 13, 2008 | Sony RDR-GX300 DVD Recorder
Sony DVP-S360D DVD Player Logo
375 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
