Question about XFX GeForce FX 5200, Graphic Card
Horizontal blue lines appear on some EMail?
Blue lines appear on left side of screen. What causes the lines? Please advise. Thanks for your time
  • 1,800 Answers
Try to unplug and plug again ur DC. but plug it R8.
Posted on Sep 04, 2008
Thanks, I posted a question regarding a convergence failure earlier. I followed your previous advice and replaced the STK392-110 and STK392-150 chips and the RK62 resistor which was bad, however the...
RK62 in this model is a 2.7 ohm 1 watt resistor (per the Hitachi site).
Let me ask you a few questions--did you check all the protect resistors? Sometimes you get one that looks perfect and is open.
Second, are you trying to adjust with the Hitachi remote in the customer menu or the TECH menu?
If in the customer menu you may need to go into the TECH menu and adjust and save there--if you get into the TECH menu and blue will not adjust somewhere--you probably have a bad resistor somewhere.
This all sounds familiar--I bet I helped you before--
SD TECH
Dec 29, 2009 | Hitachi 51F500 51" Rear Projection...
Convergence lines are SLANTED. Red line is above horizontal center on left side on screen and below horizontal center on the right side of screen. Also left of Vertical center at the top of the screen and...
did you check the six 3.5 pico fuses that are next to the ICs? They will often be open ( blown) when the ICs fail. Also check the two 5 amp IC protectors on the G board as those protect the two ICs so its possible they have blown also a 5 amp pico can be substituted for the two IC protectors.
Apr 26, 2009 | Sony KP-46WT500 46" Rear Projection...
Horizontal blue lines with a slight blue wash in the screen
Its because of Over Voltage of Screen (G2) to Blue CRT.
Take off front lower cover (speaker grill) and unscrew board. There you will need to find Focus Block mounted having 6 control knobs. 3 knobs are for Focus control and 3 are for Screen volts control. Find Blue Screen control knob and turn is Counter Click Wise slightly until bluish shade disappear on screen including few blue horizontal lines.
If you select AV input to adjust that will be fine as you do not need to wait for dark-scene.
Apr 09, 2009 | Sony KP-65WS500 65" Rear Projection...
Samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Dec 23, 2008 | Televison & Video
Blue Screen with thin horizontal white lines
THI IS THE INTERNAL CIRCUTRY FAULT BEST YOU
call the service person and dont try to open it other than in side of TV SET HAVING Hazard of electrical shock be handle most care fully .
and check video board and all.
Oct 19, 2008 | Philips Magnavox 20MS233S 20" TV
H Lines on the left side of the screen
just in case you came across this - it is the light engine! $950 - thanks mits for complete junk
Oct 13, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Sony kp-65wv600 blue arch line on left side
in the menu does it have a convergence menu? try doing that.
Feb 20, 2008 | Sony KP-57WS500 57" Rear Projection...
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
42" philips plasma flat panel television
same problem anyone know what his is please send me an email. real unhappy!!! this tv cost me $900!!!!! rami7344@bellsouth.net
Oct 22, 2007 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Convergence not lining up
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
XFX GeForce FX 5200, Graphic Card Logo
165 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
KG John Justin
KG John Justin
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
