Question about NEC MobilePro 770
Connection problems
What should I do if connection problems exist on the internal modem of the MobilePro 770?
    Master:
  • 903 Answers
Attach the AC power cord or adjust the power saving mode so the unit does not go into "standby" mode. This is caused by the unit going into "standby" mode when data is being transferred.
Posted on Sep 15, 2005
SOURCE:
Wireless internet on NEC mobilepro 770?
dail up or get the serial port cable and run through another pc just a heads up mine has pocket internet explorer and most web pages won't load right.
Feb 28, 2009 | NEC MobilePro 770
Erro 647 when trying to connect 770 to desktop with windows xp
I had the same thing happen to me.. The site below will fix you up just follow all the steps.. Some things are worded slighty different in XP so just use common sense for those things..
Just make sure to set your Computer as HOST when it asks.
Also I could not find the mobile devices or something like that tab in Windows XP but it still worked.
http://www.pocketpcfaq.com/wce/21/windows2000.htm
Apr 05, 2008 | NEC MobilePro 770
NEC MobilePro 770
These are older devices, and Lihium-Ion batteries degrade from the date of manufacture. You will most likely need to follow instructions (easy to find on the internet) to "fix" the battery. It needs two new cells.
Oct 03, 2007 | NEC MobilePro 770
Lower fidelity voice recording capability
MobilePro 770 units with a serial number before MC-B004P3US-033 may have a lower fidelity voice recording capability. This may cause voice recognition software to not function properly. This issue is not experienced with new units.
Sep 15, 2005 | NEC MobilePro 770
Connect to a Windows Terminal Server
Yes. You need to install the RDP client software which can be downloaded from Microsoft. Procedure to install the RDP client on a MobilePro 880: Note: Steps 1 and 2 need to completed if you have not installed the Service Pack One for MobilePro 780 and 880. 1. Perform a "Hard" reset on the MobilePro 880. 2. Install NEC Service Pack 1: http://support.neccomp.com/kbtools/faq/mobilepro/mp1.asp 3. Make sure the Device Name is set to something other than "Handheld PC". 1. Start-Setting-Control Panel-Communications 2. Change Device Name to a Unique Name that is not currently being used on your network. 4. Establish a Partnership with a Host using active sync. 5. Disconnect the MobilePro from the host. 6. Install "hpcrdp.exe" on your host. It can be down loaded from Microsoft: 1. Go to http://www.microsoft.com 2. Select "Search microsoft.com" under the Search tab. 3. Type "hpcrdp" in the search box and depress Enter. 4. Look for the search results titled "Terminal Server Download for Windows CE". 5. Double click on the article and follow the link and at bottom of the Terminal Server License agreement you will find the link to bring down the RDP client. 7. Establish an Active Sync connection between the host and MobilePro 880. 8. The RDP client software will be installed on the Mobile device. 9. Install a NE2000 NIC (or any NIC that you have the MIPS CE drivers for) into the Mobile Pro 880. 10. Set up network and attach to your existing network. 11. Set up a RDP session: 1. Start-Programs-TerminalServerClient-Client Connection Wizard 2. Enter Description connection. 3. Server Name or IP address. 4. Next 5. Enter user name, password and domain if you want to logon automatically. 6. Next 7. Finish If your terminal server is set up correctly you should be able to connect as a Client.
My MobilePro 770 intermittently stop responding at startup
With the Owner information screen or passwords enabled, it is possible that a deadlock condition can occur as the Graphics, Windowing, and Events Subsystem starts up. The only work around at this time is to disable the owner information screen in Settings/Control Panel/Owner and/or to disable Passwords in Settings/Control Panel/Passwords. This information is also found at Microsoft site at: http://www.microsoft.com/technet/ Article ID: Q260315
Update files be installed
The MobilePro 770/800 update files should be installed in the following order: 1. MP77_UPDATE 2. CE_SP1 3. SCHANNEL.DLL Memory usage: The three patches use approximately 2,155 KB of storage and 418 KB of program memory. Patch Storage memory Program memory None (hard reset) 323 KB 1,435 KB MP77_UPDATE 1,016 KB 1,784 KB CE_SP1 2,380 KB 1,895 KB Schannel.DLL 2,478 KB 1,917 KB Available (free) 13,874 KB 14,436 KB
UPDATE.CAB
NEC Computers has developed this update file to address several service issues with MobilePro 770 and 800 handheld personal computers. To assure proper operation, NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing this file according to the installation instructions. * Download MP77_Update.CAB for MobilePro 770 and 800:ftp://ftp.neccomp.com/pub/Catalog/4058/MP77_Update.asp * View Installation Instructions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Installation * See Contents of MP77_Update.CAB: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Contents * Read Additional Frequently Asked Questions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#FAQ Installation Instructions for MP77_UPDATE.CAB for MobilePro 770 and 800 First, download MP77_UPDATE.CAB to either your HOST or MobilePro system. It must be manually loaded onto your MobilePro by either using a dial up connection, PCMCIA Flash card, or from a connected PC before continuing with the installation. To install the MP77_UPDATE.CAB file, follow these steps: Note: An out of memory error message will be displayed if you attempt to install this file twice. 1. Back up your MobilePro data and configuration using the Microsoft ActiveSync backup procedure. For details on using ActiveSync, see your MobilePro User's Guide. 2. Perform a Soft reset on your MobilePro. Note: Performing a Soft reset does not erase your data. It simply cleans up the memory and refreshes the system registry. 3. Copy the MP77_UPDATE.CAB file to you MobilePro desktop. 4. Install the file by double tapping the MP77_UPDATE ICON with your stylus. For proper installation, you MUST accept the default location - \Program Files, by clicking OK. 5. Perform a Soft reset on your MobilePro. 6. Once the update file is installed, NECC recommends that you use the ActiveSync backup procedure to again back-up your system. This time your backup will include the update file so you can restore both your data and the update file should either ever be erased. Contents of MP77_UPDATE.CAB for MobilePro 770 and 800 This file installs updates to the following built-in MobilePro drivers: * StartUI: This driver eliminates a memory leak that reduces user resources. * Bitmap files: Replaces an incorrectly sized bitmap file that can cause the unit to lock up if either "the power on password" or "Display Owner Notes features" are enabled for use. NOTE: NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing MP77_UPDATE.CAB according to the following instructions. NOTE: During Installation of this file, you must accept the default installation directory or the updates will not be effective! For assistance or further
Sep 15, 2005 | NEC MobilePro 800
UPDATE.CAB
NEC Computers has developed this update file to address several service issues with MobilePro 770 and 800 handheld personal computers. To assure proper operation, NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing this file according to the installation instructions. * Download MP77_Update.CAB for MobilePro 770 and 800: ftp://ftp.neccomp.com/pub/Catalog/4058/MP77_Update.asp * View Installation Instructions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Installation * See Contents of MP77_Update.CAB: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Contents * Read Additional Frequently Asked Questions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#FAQ Installation Instructions for MP77_UPDATE.CAB for MobilePro 770 and 800 First, download MP77_UPDATE.CAB to either your HOST or MobilePro system. It must be manually loaded onto your MobilePro by either using a dial up connection, PCMCIA Flash card, or from a connected PC before continuing with the installation. To install the MP77_UPDATE.CAB file, follow these steps: Note: An out of memory error message will be displayed if you attempt to install this file twice. 1. Back up your MobilePro data and configuration using the Microsoft ActiveSync backup procedure. For details on using ActiveSync, see your MobilePro User's Guide. 2. Perform a Soft reset on your MobilePro. Note: Performing a Soft reset does not erase your data. It simply cleans up the memory and refreshes the system registry. 3. Copy the MP77_UPDATE.CAB file to you MobilePro desktop. 4. Install the file by double tapping the MP77_UPDATE ICON with your stylus. For proper installation, you MUST accept the default location - \Program Files, by clicking OK. 5. Perform a Soft reset on your MobilePro. 6. Once the update file is installed, NECC recommends that you use the ActiveSync backup procedure to again back-up your system. This time your backup will include the update file so you can restore both your data and the update file should either ever be erased. Contents of MP77_UPDATE.CAB for MobilePro 770 and 800 This file installs updates to the following built-in MobilePro drivers: * StartUI: This driver eliminates a memory leak that reduces user resources. * Bitmap files: Replaces an incorrectly sized bitmap file that can cause the unit to lock up if either "the power on password" or "Display Owner Notes features" are enabled for use. NOTE: NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing MP77_UPDATE.CAB according to the following instructions. NOTE: During Installation of this file, you must accept the default installation directory or the updates will not be effective! For assistance or further
Turn off the modem speaker
To mute the MobilePro 900’s speaker volume, do the following: NOTE: This procedure will have to be performed for all existing and future dial-up connections. * 1. Open Remote Networking by tapping “Start” ? “Programs” ? “Communications” ? “Remote Networking.” * 2. Highlight your dialup connection by tapping it once. Tap “File” ? “Properties.” * 3. Tap the "Configure" button. * 4. Tap the "Call Options" tab. * 5. Enter "M0" in the "Extra Settings" box. (This is capital letter followed by the number zero without any spaces or quotation marks.) * 6. Tap “OK” to close the device properties window. * 7. Tap “Next” and then “Finish” to complete the Dial-up Connection wizard.
Sep 14, 2005 | NEC MobilePro 900 Handheld
NEC MobilePro 770 Logo
273 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
