Question about HP Officejet 5610 All-In-One InkJet Printer
Connect the fax
Lost manual....... help, to connect phone to printers.so i can fax...
  • 234 Answers
Please follow the steps mentioned in the link bellow as per your setup mentioned in the Picture:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu50333&cc=us&lc=en&dlc=en&product=441125
Good Luck
Posted on Sep 04, 2008
I lost my instructions to hook up my printer to my computer i have a canon mx310.. i need to know which phone cord goes into the computer and printer?????
I hope this installation/setup guide will help you [Click Here]. If I am right, you don't need a phone cord to connect the printer and the computer, but a USB cable. If it's in case of Fax, you would need the phone cord to connect the line to the printer/fax machine.
If you need further help, let me know.
Good Luck.
Thanks for using FixYa.
Jan 23, 2011 | Canon PIXMA MX310 All-In-One Printer
I have lost my manual for the hp laser jet i need step by step instructions on how to change the speed dial numbers
Here is the Technical Reference Manual for your Printer. As you can see below, your add numers to the Fax Phone Book, within the HP ToolBoxFX.
GOOD LUCK
Fax Phone Book
Figure 2-42 Fax Phone Book screen
Use the Fax Phone Book screen to add and remove individuals or groups on your speed-dial list, import
phone books from a variety of sources, and update and maintain your contact list.
Feb 18, 2010 | HP LaserJet 3050 All-In-One Printer
How to fax with the hp 5610 officejet printer
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab86
Jun 22, 2009 | HP Officejet 5610 All-In-One InkJet...
I lost my manual and would like help in connecting to phone jack
Each phone or dial-up modem or fax machine needs a DSL filter attached to the phone line/socket then each phone or dial-up or fax machine is then plugged into this filter.
The DSL modem does not require a filter.
If your fax is part of the computer's modem then a filter is also required on the line-in on the modem.
The instructions for sending & receiving depends upon your system/dial-up modem (the make & model, is it stand alone or a modem adapter on the expansion slot or built-in on the motherboard) and the software you are using. Cannot help you without these details.
Apr 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
Program Fax-930 brother machine so it answs fax call on 6 rings
Here is the users manual for that;
http://www.fixya.com/support/p170643-brother_fax_930_all_in_one_thermal/manual-1604
Mar 16, 2009 | Brother FAX 930 All-In-One Thermal Printer
Fax cord lost
I think that that is a regular phone line type cable/wire. Check with your owners manual to be sure. If you have misplaced your owners manual then follow this link to download it. http://www.crutchfield.com/S-lYwGyrh5jMw/p_280MX300/Canon-PIXMA-MX300.html Looks to be a regular USB cable to connect printer to computer. If still unable to determine if this is the correct cable call Canon customer service at 1-800-385-2155
Hope this helps. Ratings are very important to us so I want to thank you in advance for taking a moment to rate my response.
Matt
Jan 15, 2009 | Canon MX300 Office All-In-One Printer
Lost manual
There is no much to hook up, you hook up the RJ11 phone connector at the back of the printer to the phone line.
Install printer software onto the computer.
Then connect printer to computer using USB cable.
See here , there is user guide for all x7300 series:
User's Guide
see also
Lexmark X7350 Top 20 Questions
Here also notes on how to set up fax
Lexmark X7350 - fax problem
Sep 08, 2008 | Lexmark X7350 All-In-One InkJet Printer
SET UP
CONNECT POWER CODE TO FAX
ALSO CONNECT TELEPHONE LINE TO ITS POSITION.
THEN RESET YOUR FAX TO DEFAULT SETTINGS
SET AUTO RECEVING .
ALSO IF U HAVE PC WITH MODEM U CAN SEND AND RECEIVE FAX FROM IT.
IF U NEEDD ASK ME.
BYE
Mar 24, 2008 | Lexmark X4270 All-In-One InkJet Printer
Fax connection
Turn off distinicive ring option (menu 0 something)
plug in direct to phone line on connector marked line, put telephone into docket on fax marked EXT.
Nov 15, 2007 | Brother MFC-3240C All-In-One InkJet...
Epson Aculaser CX11NF won't receive faxes
Change your incoming mode from "autoswitching" to "TAM" (TAM is short for telephone answering machine" Press the "Setup" button on the control panel Use down arrow twice to select "FAX SETTINGS" Press the right arrow once The FAX SETTINGS menu appears Press the down arrow twice to select RECEPTION SETTINGS Press the right arrow once Press the down arrow unit INCOMING MODE appears in display Press the right arrow once Press the down arrow until TAM appears in display Press the right arrow once. That should do it for you If I got lost somewhere, it is in your Operator's manual - look in the index for TAM Hope it helped Ed
May 22, 2007 | Epson ACULASER CX11NF All-In-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
19 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
