Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Replaced fuses & they keep blowing
We replaced the fuses in our tv because it would come on ( green light ) & go right back off. Then we replaced the fuses & it worked.Then we turned the TV off & it would not come back on & it also keeps blowing the fuses.What could be the problem?
  • Ed Taveras Sep 25, 2008
    I have same problem, changed the stk chips still not fixed. any info will be welcome
  • 446 Answers
There could be a shortage in any of the dc line that cause the fuse to blow up again, either overloading or chortage will cause this, try to see for any sign of other componenet failure, wires that has been bended and cripped, transistor that has been twisted or alike
cheers
Posted on Sep 04, 2008
Brack lights wont light up on my 1988 ford ranger we keep blowing fuse and put in new brake switch
If you keep blowing the brake fuse than you have a short in the system. Unplug the brake switch. Install a new fuse. If it did not blow than the problem is after the brake switch. Next unplug the turn signal switch, then plug the stop light switch back in and press the brake pedal. Did the fuse blow. If not than the wiring is good in between the two switches. With the turn signal switch disconnected use a jumper wire in between the light green wire (power from the brake switch) and the orange with light blue wire (power to the right brake lamp). If the fuse blows than there is a short in the right side brake circuit between the plug in and the rear socket assembly. If the fuse does not blow than jump from the light green wire to the Light green with orange wire (power to the left brake lamp). If the fuse blows than the problem is in the left hand brake wiring circuit.
Sep 04, 2013 | Cars & Trucks
Keep blowing the main fuse.
To which circuit section did you replaced the fuse? Main power retulator? Just understand, the fuses are used to protect the circuit and TV from any short circuit or over voltage. Without any one of these, no fuse will blow up. If it was due to over voltage, the set should work after a fuse replacement. But here, the fuse blow up again, means, there is some thing shorted component/s. Check which component is shorted, and replace it, before replacing an other fuse. One more thing to say is, never insert a fuse other than specified. The voltage and ampere specification to fuse, will be marked at the circuit board, very near to the fuse clamp. Insert a fuse of same rating only. Using other fuse, rated higher ampere rating, might make things worse.
May 27, 2013 | Mitsubishi WD-73827 73" HDTV DLP TV
1998 Chevy Silverado 1500 Brake light fuse blew, replaced, fuse blew again, replaced relay and fuses. both under hood and in side fuse panel. Fuses keep blowing on turn signal and brake lights. Checked...
you obviously have a short to ground on one of the wires to the back (if it was the front the brake shouldn't blow the fuse). the most common problem is usually in a trailer light harness. if you look under the drivers side rear of the truck, down under the tail light there will be a plugin junction. pull this plug-in apart and see if the fuse still blows. if it does then the problem is forward of that connector, if it doesn't then the problem is behind that plugin. be sure to check for "green death" (electrical corrosion) at all joints especially any trailer hook ups.
Oct 25, 2012 | 1999 Chevrolet Silverado 1500
Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
Jun 12, 2011 | Pioneer Televison & Video
Pioneer SD533HD5 repair, blown STK's or bad power assy?
Go back recheck everything 6amp fuse in middle of power supply board that will blow, also solder everything that looks like poor connection pioneer always has a lot of cold solder jionts.CK all pico fuses they are green,yellow look like resistors but are fuses.
Jun 15, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Diagnosis 23
Protection cutting in can be caused by many different things, at least half a dozen.
Most of the time on a Mit, this is caused by the conv sys blowing a fuse that operates it, which is the same power supply that keeps the unit on. When that fuse blows, the voltage from the power supply that keeps the set on disappears.
The 5A fuses that keep the plus and minus 24v rails going are little green things that look like resistors, but are actually "IC protectors". They can be replaced by regular 5A fast blow fuses, GMA type (also known as F type - small, and hopefully pigtail, for soldering to the bad fuses. Parallell one or both of them onto the blown little green things after testing each with a VOM, which can be done easily in circuit while the unit is unplugged.
If either of those 5A fuses are blown, chances are you'll need to replace their conv ICs as well.
Mit's will work with their conv ICs disco'd - you'll have no conv correction, but the set will work and you'll see an uncorrected picture. At that point it's a shoe-in that the conv ICs are bad and need to be replaced.
Mr Bob
www.imageperfection.com
Jun 13, 2008 | Mitsubishi VS-50607 50" Rear Projection...
E.E.C fuse keeps blowing in 1991 Ford Explorer
sounds like you got a short try tracing harness to see if theres anything visible
May 26, 2008 | 1991 Ford Explorer
Push Power button, green light goes on for a few seconds then nothing....
I would suggest taking a look at the power module if that can be replaced. The Fuse blowing may have only been the beginning of the problem. Any recent issues with under or over voltage in your home?
Jan 20, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
215 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
