Question about NEC MobilePro 770
Change the resolution
Can I change the resolution on my MobilePro's Desktop?
    Master:
  • 903 Answers
No. However, you can change the VGA Out from "Display the same image with LCD (640 x 240)" to 800 x 600 or 640 x 480.
Posted on Sep 15, 2005
SOURCE:
How to change screen resolution on acer veriton 3600gt on keybordshortcut
Right Click on any blank space on the desktop and select Properties. When the Display window opens click the Settings Tab. Change the screen resolution. Click Apply then OK.
You can also click Start/Control Panel and look for Desktop or Personalization and Appearance. Click to open the desktop and select the Settings tab. Change the screen resolution. Click Apply then OK.
Apr 28, 2012 | Acer Veriton 3600GT PC Desktop
How do I change the screen resolutions?
On your desktop where all your icons and shortcuts appear, right-click on a vacant area on the desktop. A menu will appear which includes "Change Resolution". Click on "Change Resolution" and select the recommended settings (one of the resolutions should have "recommended" next to it. Once selected, the screen should change. If it is acceptable to you, click Yes when asked and remember to click "Apply" before leaving the screen. Your machine will now be set at the new resolution.
Dec 29, 2011 | Sun SPARCstation 5 PC Desktop
Text changes to very large size all by itself
...try to change your screen resolution of your desktop, just click this site to checkout the procedure on how you adjust the screen resolution of your desktop
http://www.petri.co.il/quickly-change-screen-resolution-in-windows-7.htm
Sep 12, 2011 | Computers & Internet
Resolutions too high,k how to change?
Windows 7:
  1. Right click your desktop, click Personalize.
  2. Bottom left corner, click Display.
  3. Top left corner, click Adjust resolution.
Windows XP:
  1. Right click your desktop, click Properties.
  2. Click the Settings tab.
May 23, 2011 | Computers & Internet
The display only about 5"
Try changing the screen resolution your display screen might be having trouble supporting the resolution you are currently using. If this does not work try updating the video driver for your computer.
To change the screen resolution:
Win XP:
Right click on the desktop -> Choose PROPERTIES -> Click the SETTINGS tab and change the resolution click apply and then ok
Win Vista:
Right click Desktop -> Choose Personalize -> Change the screen resolution click apply and ok
Win 7:
Right click the Desktop -> Choose Screen Resolution -> change it and click apply and ok
If the above steps does not work try going to the sony vaio support site and download the updated driver for your Video Display.
Hope this helps!
Apr 13, 2011 | Sony VAIO PCG-K25 Notebook
Want to improve screen resolution on notebook. make text and pictures clearer (how?)
running vista/win7 -- right-click desktop -> personalization -> display settings -> drag thte slider up.
running winXP -- control panel -> display settings -> drag thte slider up.
if the slider is maxed make sure you drivers are current and "accesability" options defulted
Dec 08, 2009 | Computers & Internet
Sep 15, 2005 | NEC MobilePro 800
No. You cannot change the resolution on any MobilePro Desktops. The VGA out is also fixed and you cannot change the external resolution. Only the MobilePro 770 and MobilePro 800 allow you to change the resolution on the VGA Output.
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
"Backup Battery Very Low"
NEC has identified an issue where the system can erroneously generate the "Backup Battery Very Low" message. There are two possible solutions that will eliminate this erroneous low battery warning message (the first method is the preferred solution, the second method can be used if the update file is not available). Solution I. Install a new version of the driver that controls the battery monitoring circuit. 1. Download the Low battery warning fix to your desktop. 2. Using ActiveSync or a compact Flash Card, copy FixBatt_HPC2K.EXE to the MobilePro internal disk. 3. On the MobilePro, double click the FixBatt_HPC2K icon. 4. When the message "Low Backup Battery Issue" is displayed, tap the "Patch it" button 5. When prompted turn unit over and momentarily depress the Reset button using the stylus. Solution II. Change the default power management configuration. Configure your MobilePro 900 to suspend when the LCD lid is closed on battery power and AC power. To ensure that the device suspends whenever the lid is closed, please make the following changes and perform a soft reset: 1. Go to Control Panel. 2. Open MobilePro Settings. 3. Go to the LCD Suspend/Resume tab. 4. Place a check next to "Enable suspend while on External Power." 5. Click the "Advanced" button and place a check next to "Enable suspend while on External power. 6. Click OK to close the Advanced Setting window and click OK to close the MobilePro Settings. 7. Turn unit over and momentarily depress the Reset button using the stylus. NOTE: Both the software update and power management settings are cleared on a hard reset and must be re-applied.
Sep 14, 2005 | NEC MobilePro 900 Handheld
NEC MobilePro 770 Logo
62 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
