My graphics card has a DVI-I hook up,my monitor has a DVI-D hook up what gable do i need..Thanks to ALL THAT HELP...
    Scholar:
  • 141 Answers
You can buy a DVI-I to DVI-D adapter at your local home electronics store, or possibly your local computer shop.
Posted on Sep 04, 2008
How do I fix the error no vga input signal no dvi input signal monitor going to sleep
Check if you VGA is properly settled in the PCI slot. Try to take it out, clean the slot for dust.
If that doesn't help, it is well possible that you VGA is not working any more.
Jun 10, 2012 | HP Computers & Internet
I have an Acer Monitor X223w - is it capable of hooking up as a douple monitor to one computer?
Any monitor can be used as the second monitor for a computer. However, your computer's graphics card must have two outputs. Some simpler graphics cards, most on-board video chipsets and all laptops *do not have* two outputs. Please check the back of your computer for two VGA outputs, or one VGA and one DVI output (you can use it by connecting a DVI cable to your monitor, or by plugging in a DVI to VGA adapter).
If your graphics card does not have two outputs, or if your computer uses an on-board video chipset, you can buy another graphics card to replace the one you're using.
Mar 03, 2011 | Acer 22" X223w LCD Monitor
I have an iBUYPOWER Gamer Power 918i desktop computer. I hooked up a monitor using a VGA connection, I'm not getting any output from the monitor. Whenever I turn the monitor on it goes into sleep mode- as...
You may have a couple of problems here, with you saying it`s a gaming PC it most likely has a graphics card installed which will likely only have outputs for DVI or HDMI, VGA is not usually supported on newer cards. What you need to look for is on the back of the PC where you are plugging in your monitor are you inserting the plug vertically, i.e. straight up and down? if so this means you are connecting to the motherboards onboard graphics which will be disabled if you have a graphics card. If you are using a VGA monitor then most likely it is a blue plug on the board you are plugging into, if you have a graphics card then the most common outputs are what is called DVI which is a slightely bigger white plug. You need to look slightly lower down from the plug you are connecting to and see if there are one or two DVI sockets which will be mounted horizontally. If this is the case then the motherboard socket will be disabled, there are a couple of solutions to this though, you can remove the graphics card which will re enable the onboard graphics and allow you to use your monitor, you can buy a monitor with a DVI input or you can buy from most PC stores a DVI to VGA converter which lets you use your existing monitor with your graphics card although the frame rates and refresh may not be so good, the latter is the method I would recommend to get going.
Hope this helps and thanks for using fixya
John
Dec 25, 2010 | iBuyPower Gamer Power 918I Desktop...
When I connect the moniter to the graphic card geforce 6200 it will not show a display at all. connection to the computer using the regular connection it shows
On both the Graphics card and the monitor, the blue connector is a 15 pin DSub VGA video and the white connector is a DVI video.
With the monitor it should default to the 15pin DSub video input.
If you want to use the DVI video input you need to configure the monitor to use the DVI video input. DVI to DVI give the best picture quality.
If you want to go from 15pin DSub to DVI you need a converter cable.
Try conviguring the monitor for a DVI video input.
Jan 30, 2010 | XFX GeForce 6200 Graphic Card
Video card/dual monitor set up
If the card has dual monitor dvi out puts your set if not your going to need a new card
Apr 03, 2009 | Computers & Internet
Radeon R9600/XT GRAPHICS CARD
Yes, they both will act independently if you choose to use it that way or they will show the same picture, one is a DVI output and the other is VGA. Use the ATI’s CATALYST software suite provides the ultimate software required to enjoy the full acceleration of your ATI Graphics Accelerator card. You can use it to separate your Primary video from your Secondary video.
Jan 03, 2009 | Abit R9600XT-VIO RADEON 9600 XT, (256 Mb)...
New HP PC won't show up on monitor
So the problem there is your VGA adapter. Try installing a Graphics card in your motherboard. Check the type of graphics card slot whether it is a VGA or PCI Express slot. Hope this helps.
*Your vote is highly appreciated. Thanks in advance.
Best regards
Dec 26, 2008 | HP Computers & Internet
Can I add another monitor with (dvi) output to this computer?
You will need a graphics card that supports dual DVI modes.
Dec 20, 2008 | Sony VAIO PCV-RS710G PC Desktop
Hooking up a HP L1755 17
What is the way to get the very best picture quality when hooking up my new HP L 1755 Flat Screen Monitor to my E-Machine W3052 which is about 3 years old.First would it be compatible or the best idea to hook up VGA to VGA.DVI to DVI which means buying a new Video card for my Computer so the DVI could be hooked up to my computer, or hook up the DVI to VGA Connector ? Would a DVI Video card be worth the extra costs if I went that route ?This HP L 1755 only has a response time of 25 ms, is that good enough to watch Music Videos or not ? I do not do any gaming.Can you tell me the best detailed step by step way to hook up this monitor to my E-Machine W3052 Computer and which Connector to use ? If I need a DVI Card what would be the Part number or Card I would need to get ? Sorry about all the questions.Any guidance and input would be greatly appreciated since I have a disability and need some help and to be honest I do not have 50.00 for a DVI Video card. Sincerely & God Bless ! Thanks,Diehard16
Feb 18, 2008 | Computers & Internet
Ati radeon 9600 video card
what you have the ATI card hooked up can you see the boot screen? If you can see that you might want to try going into safe mode and making sure your graphics settings aren't set beyond the capability of your monitor. If you can't see the boot screen then your card might be dead.
Apr 28, 2007 | ATI Radeon 9600 Pro 256MB DVI+CRT+TV 8X...
Computers & Internet Logo
David Payne
David Payne
