Question about Dell 922 All-In-One InkJet Printer
Spaces in printed lines
At intervals there are spaces across the page in the middle of printed lines. I cleaned the contacts with alcohol on the printer and the ink cartridges. The check print pages after adding new cartridges are okay, meaning no spaces in printing.
  • mataylor3343 Sep 04, 2008
    All types of printing; text, graphics, etc. all have spaces at regular intervals (1 to 2 inches). They appear as horizontal spaces (separation) in the middle of words all the way across the page. These separations do not appear on the test pages.
  • ariel santos
    ariel santos May 11, 2010
    it is quite difficult to imagine so as what kind of spaces you are reffering to, in print test pages there were only few lines in the to determine the actual prob, however what kind of application you are trying to print? is is text, photo or mixture?
  • 446 Answers
Then the problem is in cartridge replace them asap, no other way around it,
cheers
Posted on Sep 04, 2008
Line spacing
What brand is your printer?
Jan 09, 2014 | Epson Stylus NX200 Printer
Poor print quality, but only on certain lines
Pull out the cartridges. Wet a q-tip with alcohol and clean the foil contacts that are in the spaces that the cartridges just occupied. Use a flashlight to better see what you are doing. See if that helps.
And what kind of lines are you getting on the printout? Vertical?Horizontal? Those could be ink that is on the feed rollers.
Jul 17, 2010 | HP Officejet 6310 All-In-One InkJet...
Problem with Canon MX700 printer: For the past
Look inside at the clear strip that runs across behind the carriage. With a light you should see grease or ink spots at the same area where the skips appear on your page. Clean the spots off with a Q-tip damp with alcohol.
Feb 08, 2010 | Office Equipment & Supplies
When printing photo's on my Cannon Pixma MP 500 there are lines horizontally across the photo at 4mm intervals. I have tried head cleaning and alignment to no avail. I have tried both Cannon original ink...
It's probably a blocked jet in the print head but could also be a page registration issue. Try gently wiping the print head with a cotton bud dipped in an alcohol based cleaner
Nov 28, 2009 | Canon Office Equipment & Supplies
Rainbow line across the middle of the page
Possible print alignment issue.
Check the toner and then go to properties of printer.
Clean heads etc and then print test page.
Wizard should assist to troubleshoot
Jul 13, 2009 | Samsung CLP-510 Laser Printer
Printout blank
this is problem with cartigdes only just installed new one and see.
Oct 17, 2008 | HP PSC 1210 All-In-One InkJet Printer
Printer Problems-Hp Deskjet F380
It isn't really 'printing' a white line but rather NOT printing at all. These are generally called 'voids' in the copier trade.
About the only thing that can cause this is the momentary loss of contact of a 'common' electrical pathway.
Removing the the cartridge, you will find a pattern of contacts, normally on the back of the cartridge.
Try using a cotton swab moistened (not dripping) with rubbing alcohol to scrub the contacts and reinstall after it is dry again. You can safely wipe any remaining moisture away with another swab.
If the loss of contact is caused by any contaminents, this is enough to remove them.
Avoid touching the nozzle area to prevent other problems.
This may not apply to you but this kind of problem can be caused by tobacco smoke which produces a sticky film often causing electrical problems in paths handling low currents.
May 12, 2008 | HP DeskJet F380 All-In-One Printer
Dell 922 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
