Question about Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA)
Linksys SPA2102 conflicts with my Router
I connected Linksys SPA2102 and both my internet and phone line work, however when I connect the Router, the internet stops working. What could be the problem?
I have the same problem and I configure my router in PPPoe with my username and password provided by my ISP and now my router is working...
Posted on Nov 05, 2008
Connecting VOIP device without having any router, but wifi intern
hi yvo2000. Sorry, you cant do that. That router (well, the SPA2102) needs a cable from your neighbor's router in order to provide internet to the POTS jacks. Please don't forget to rate my answer if it helped you. Thank you :D
Apr 28, 2010 | Linksys Computers & Internet
Spa942 behind a router/firewall
If you are taking this to a large Enterprise Network, the ports you need for the phone to talk to the internet are being blocked. If you can not control the Router/firewall, you can not do anything about it.
Apr 15, 2010 | Linksys SPA942 IP Phone
I am getting engage tone when connecting linsys
i have Spa 2120 it problem line phone it has get ip address but the phone line is not caming could you help me that problem.
thank you,
Dec 24, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
Ok these boxes can either work or not.
So you have to confirm that your internet connection or box you are plugging into is set for DHCP. If not it will not get an ip and work.
Figure out where the linksys is plugged into which can be and you can try this -
1. plug the vonage box directly into your internet connection without your computer connected.
If it works then you need to go into the box you connected and have it set for DHCP to be ON. if not you will only get one ip for your multiple items you wish to use and only one at a time will work.
Mar 20, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Nov 06, 2008 | Linksys Wireless-G WRT54G Router
Linksys SPA2102 interfearing with winmx/360 sharepro, frequently resetting connection
If your planning to connect the phone adapter behind a router make sure that the following ports are open/forwarded on the router; UDP ports 5060-5061, UDP ports 16384-32767 take note that 5060 and 5051 one are SIP ports and must be assigned to the IP address of that was assigned to by the router to the adapter or the IP that was manually configured on it.
I found a link that could help you check the setting on your linksys phone adapter
Hope this will help you solve your VOiP problem...
Sep 11, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
I have just had a wireless internet system put in how do i make voip calls? I AM A NEWWBEE PLEASE HELP
hey if you r having wireless system then you have to connect your spa2102 to your pc
connect your pc to internet via wireless connection
now you r having lancard on your pc which is free rightnow
connectyour spa2102 to this lan card
and if you r having win xp then go to my network plase
rightclick on it
go to property
you can se local area connection and wireless connection both in this window
right click on wireless connection and go to its property
find internet connection sharing or allow other users to connect internet via this connection/pc
enable it so that your spa 2102 can get internet connection via lancard
Feb 13, 2008 | Linksys SPA-2102 NA Analog VoIP Adapter...
Linksys Phone Adapter with Router Model SPA2102-R Connecting to Internet
from the cable modem or dsl connection, connect to WAN on the linksys device From PC port to the computer. you will have to make sure if all the port or opened. Normally DATAONE will not block any ports but its always adviceable to check if all the potrs are opened. you will have to put your mac code on the modem. If that does not work you might have to clone your device (information transfer from modem to your device) and you should be good to go...............
Nov 19, 2007 | Computers & Internet
Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA) Logo
493 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
