I need a belt kit for a carver td 1700 tape deck where would i find one
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Can't get a signal from my Turntables to record on my tape deck. I'm running turntables through RX 206 Amplifier and don't understand the RCA ins and outs.
Connect them to a receiver with a phono preamp.
Posted on Apr 12, 2009
SOURCE: I have a Pioneer CT-W302R
belts and instruction for measuring can be found at studiosoundelectronics.com
Posted on Mar 11, 2011
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
How can I get belts for a stereo double cassette deck model number TD-W83 and where?
You just need to measure the diameter in MM of the old belts. You don't have to be too precise. Then put these words into google. "Cassette drive belt XXmm". Belts are universal so pick the nearest one to your measurement.
Mar 09, 2015 | Audio Players & Recorders
Perhaps, my message has already sent, but I am unable to check. I purchased a set of two new belts vor my Harman Kardon TD420 tapedeck but don't know how to install them. The larger belt (square) is...
Older cassette decks used belts from the motor to the capstan, another from the motor to an idler assy. or tape reels (FF & RR) and another belt driving the mechanical tape counter.
Sep 08, 2013 | Harmon Kardon Harman Kardon Td 420
JVC TD-V661 CASSETTE TAPE DECK UNWINDING HALF WAY
Often caused by a belt slipping or a pinch roller that is worn and does not apply enough pressure to the tape.
Mar 25, 2013 | Audio Players & Recorders
How to replace drive belts in a yamaha K500
It is a simple matter of getting the Service Manual, then obtaining the belt kit from Marrs Communications belt supplier and then determining how to get the belts into the mechanics of the deck,
If you are not a Tape Deck Technician, then this may seem like an insurmountable task as the transport need to come out or at least open access to it's rear to take of thrust plates and parts of the mechanism that is required to get the belts into the unit. As a Tape Technician of 40 some years, I can tell you that there may be other things in the deck that also need attention like tires on reel table or other idlers, other small belts not supplied in the kit and the oiling of the Flywheel and capstan bearing. If you JUST put belt in you are doing half a job and the deck still may not run at the correct speed. There is also technical equipment needed to set speed as well as test tapes. New belts almost always require that the speed is set to the reference standard of 3KHz or 3150Hz depending on what test tape you have. This kind of work can take over and hour and some machines depending on design can take two. Calibration is done to a deck by any of the good Technician I have worked with. This is currently my full time business so if you need my help, I am available.
I have a lot of belts in stock- I have been doing this for 40 years so far.
skywavebe@sbcglobal.net E mail.
Aug 24, 2012 | Audio Players & Recorders
JVC TD-W718 double tape deck capstan belt
Probably the wrong belt. It is also possible that your old belt had stretched and the machine was playing slow. Check with a recording of instrumental (not vocal) music.
If you have a little screwdriver you can adjust the motor's speed via the little hole on the back of the motor.
I suggest a plastic screwdriver so you don't short something out.
Using a tuning fork or electronic tuner or musical instrument will help you get the speed right.
Jun 07, 2012 | JVC Audio Players & Recorders
I need a users manual for a JVC TD-W805 tape deck.
Hello
The user manual you ask for will be very difficult to get from net. I've the user manual for TD-W354 DOUBLE DECK. It will be same for TD-W805. If you are interested to get it, send your Email address to me by Fixya. I can't send it to you by this window as, it does not allow me to upload PDF files by it. If you send your email ID, I'll send a copy of it to you by return mail. OK>
Nov 13, 2011 | Audio Players & Recorders
Need capstan belt for reel to reel -tascam-dx-44,pls help.
The model is not a DX44 as that is a dBx unit attached to either a Tascam 44 or 40-4. The tape deck model would need to be determined and when that is done go to Marrs Communications and order the belt kit for that machine and you will get the capstan and counter belt.
http://marrscommunications.com/tascam-cassette-kits
Oct 09, 2010 | Tascam Audio Players & Recorders
Play button no response fast forward and rewind work
THE capstain belts need changing to operrate the tape lifter mechanism
Dec 03, 2008 | JVC TD-W118 Single Cassette Deck
60 people viewed this question
 Grubhead
Grubhead
