Question about HP PSC 1610 All-In-One InkJet Printer
Remove and checl color cartridge
This error appears on my printer and won't allow me to print.  I put in a new cartridge but still have the same error message.  Suggestions
  • townsedan Sep 25, 2008
    Mine come up with "Remove and check color cartrige" I have done this and I have even changed the cartrige with a new one and still get the same message???? Is this thing now a boat anchor??? Any help would be great.
    Thanks
  • Anonymous Oct 07, 2008
    I have followed HP web sit advised before posting my problem as I can read and cleaning the contacts inside the printer didn't help in any way shape or form. I have now stopped using HP and my printer has been turned into a boat anchore for those great fishing days!
    Novelist:
    Scholar:
  • 111 Answers
The problem most likely is with the electrical contact between the color cartridge and print carriage. Even if you've replaced the cartridge, if the contacts on the carriage are still dirty, it won't make a good connection with the new cartridge and the error message will still appear.
Fortunately, the HP web site has a solution posted at the following link:
Cleaning Cartridge and Print Carriage Contacts
Good luck.
Posted on Oct 07, 2008
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
Error message "remove and chech color cartidge". I removed and replaced it several times and the same message appeared. I used a new cartridge and the same messade appeared. What can I do now?
you either have a cartridge that is empty or it is damaged, remove both print cartridge and try and put them in again. Unplug the power cord, insert it and start again
Sep 09, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Hp psc 1210xi all in one printer says refilled cartridge is defective. HP says printer remembers cartridge serial number, counts number of prints executed & after certain number of prints, won't...
Well, if the electronic circuit on the cartridge has blown, you have no other alternative then to buy a new cartridge. You can remove the cartridge and gently wipe the cartridge contacts. Turn off your printer, wait for a few min, then turn it back on. Put the cartridge back.
If that doesn't work,
  1. Open the cartridge access door.
  2. Remove either cartridge (not both).
  3. Close the cartridge access door.
    • If the computer message is Print Cartridge Error , then the print cartridge that is still in the printer is the problem cartridge.
    • If the computer message is NOT Print Cartridge Error (instead, it says that the cartridge you have removed is ...Either missing, not detected, or incorrectly installed ), then the cartridge you have removed is the problem cartridge.
There is a cmos battery in the printer, and, yes, when you remove it, the printer forgets everything (serial number, number of copies, etc). I have found a clip, but it says it only works for some HP printers. You can try that, but I am not sure that will help solve your problem.
Jan 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
Dell 720 won't print color, color ink cartridge missing
check to see if the color cartridge has the plastic tab on the cartridge. Remove and reinsert cartridge.
Sep 13, 2009 | Dell Inkjet 720 Printer
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Lexmark 5150 - Error 0502
    1. On your PC, go to Start, Programs (Windows XP: All Programs), Lexmark series.
    2. Select the Solution Center.
    3. When the Solution Center appears, click on the Maintenance button.
    4. Select the option to Install a new print cartridge. The carrier should slide over at this point and allow you to insert and/or remove cartridges.
    5. Make sure the correct cartridges are installed inside the printer first, then inform the software which cartridges have been installed. Note: This applies also to installation of a single cartridge.
    6. Print the Print Alignment page to ensure the print quality is satisfactory.
    7. Close the Solution Center.
    Jan 07, 2008 | Lexmark X5250 All-In-One InkJet Printer
    HP PSC 1610 All-In-One InkJet Printer Logo
    79 people viewed this question
    Seeker5211
    Seeker5211
