Question about HP LaserJet 3330 All-In-One Printer
Can you help?
I have the hp 3330 plugged directly into my Dell laptop with Windows 2000 and as it boots up, it attempts to load settings then it goes to a blue screen in DOS and it goes so quick I can't read what it says. This makes it go in a loop to restart and do it all over again.
Can you help?
  • HP Expert
  • 141 Answers
This has nothing to do with your printer. this sounds like a pc motherboard. good luck!
Posted on Sep 20, 2008
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
Will pass bios but then will not load windows, will not boot from CD, will not boot in safe mode. Tried reinstalling windows, will not, I can't start so can not use system restore. Will not boot using the...
step 1. open up the case and locate your hard drive
step 2. carefully remove the cables and power to the hard drive and remove it
step 3. goto your local office depot, staples, walmart or radio shack and buy a nice new hard drive somewhere around 250 gigs should be plenty for you,
step 4. now that yopu have a nice new hard drive put it in the spot where your old hard drive was in the conputer and plug both cables back into the new hard drive, after this is done put your case back on and start the computer up with your windows cd in the cd rom drive and reinstall windows. :) hope this helps
Oct 13, 2009 | Dell XPS M1530 Laptop
Boot from CD
Try going into the Bios setting and setting the boot order sequence with the CD as first booting device.
Jan 08, 2009 | Microsoft Windows 2000 Professional for PC
Did you fix the Dell Insipirion 9200 video problem?
This sounds like your video settings could be set improperly, did you attempt to boot up in safe mode and then change your display options? Sometimes you need to monkey with windows to get it to accept new video settings, try removing the video display from the control panel, if this has been done and you can't correct the issue a reload may be in order or at worst case you may have a malfunctioning video card
Nov 19, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 monitor display problem
Well it is most likely a issue with the Video driver as you are able to boot to the safe mode.I would suggest going back to the safe mode and deleting the present driver for the video from the device manager.before you restart the system just download the latest version from the support.dell.com so that you can reinstall it.Also check in the graphic properties which screen is set to be the defuat.Incase still not working i would suggest reinstalling the operating system before replacing any hardware.
Jan 03, 2008 | Dell INSPIRON 6000 CENTRINO...
HP LaserJet 3330 All-In-One Printer Logo
Seeker5211
Seeker5211
