Question about Sharp Notevision XG-C50X Multimedia Projector
Display fault I have about 8 projectors that show some yellow shading when using a white background or content. Most occur in the lower left hand portion of the screen.
  • 2,237 Answers
Either the light filter before the blue lcd is fried or the 2nd fly-eye lens is. take the lamp out and shine a flashlight through the glass in the projector. if you see blackened burn marks on the other side of the glass, the fly-eye lens is burnt and needs replacing (but is currently out of stock). if not, it's the lcd light filter (which is in stock).
Posted on Jul 08, 2009
Pyle troubleshooting
The projector has built in speakers.
Aug 06, 2014 | Pyle Home PRJHD66 1080i Front Projector
NP50 has white vertical stripe down left side of screen
Display is faulty, I would say. Prove it with an external screen.
Mar 06, 2014 | NEC Office Equipment & Supplies
My sony grand wega gives a blue shade on the black background which is the problem
HI, Check the menu set up of the TV. There should be an alignment feature that aligns the blue, red, and green colour projectors. If the blue is out of alignment that is likely why you can see it on the dark backgrounds. The set up normally puts a white cross on the screen and you select each of these colours and then move the cross over the white on with the arrows on your remote. Once all are aligned correctly you shouldn't be able to distinguish between different colours and hopefully this should get rid of your blue shade.
Oct 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
All white is in yellow,but only around the middle area.its like a white shade while watching anything.
the light filter on the blue lcd panel is fried due to excessive dust and heat. unfortunately, you'll have to replace the entire optical engine.
Mar 22, 2009 | ASK Proxima C160 Multimedia Projector
I have a second- hand dell 3100MP projector which I use during church services to project songs and other material. Recently it has been showing a predominalty green image , particularly when showing...
sir
the lamp is not at problem, but the dlp engine is at fault, u may have to replace it.since u bought it 2nd hand,it is not worth changing the same as it will cost u more than ur buying price.when u plan to buy ur next projector, make sure u buy a new one as it will come with a fresh lamp & manufaturers warranty on the unit & at 4000 / 5000 hours of projector usage is guaranteed!
Jan 05, 2009 | Dell 3100MP Multimedia Projector
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Sharp xr-11xc only displays black & white
Sounds like your connection is bad, check ur connections on ur cables
Oct 25, 2008 | Sharp XR-11XC Multimedia Projector
Bright yellow
I can't imagine a setting that would cause this - It sound more like some sort of fault with the projector's blue LCD panel. (The image is created from a mix of red, green and blue light. If you loose the blue, everything will look yellow.)
Is it capable of showing any shades of blue?
Using any graphics or photo-editing software, create a solid blue image (R=0, G=0, B=255 in your colour settings) and if possible, display this full-screen. Is there any output from the projector at all when you do?
If not, it sounds like it need a professional repair.
Matt
Feb 26, 2008 | NEC VT676 Multimedia Projector
Benq 7220 display wrong color
It sounds a lot like a bad color wheel if it was a DLP. IF it is a LCD then i would say one of the LCD panels is bad or possibly a connection problem that drives the panel or the connection that hooks up to the projector is suspect. Let me know if that helped you at all.It is strange that the bottom shows white though. Jay
Jan 30, 2008 | Office Equipment & Supplies
Sharp Notevision XG-C50X Multimedia Projector Logo
356 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
