My acer laptop won't turn on.. - Computers & Internet
  • Anonymous Mar 02, 2009
    I have a acer aspire one laptop and when I turn it on it always goes to
    the black screen where it says it has an inconvenience. Then after it switched fast to a blue screen where it's too fast to read. It keeps doing that. I can't get it to start.
    Help?
    Sergeant:
  • 264 Answers
I am giving you a step which you should try once and see if it makes any difference.
Method (Power cycle)
You need to remove the battery, adapter and any other device connected to the computer (May be any additional cards or any wires as for Ethernet or speakers or external mouse/keyboard).
Nothing should be connected at all.
Now Press and hold the power button for 25 seconds (It wont show anything). This is a step to release any static charges developed, which may surely caused the kind of issue you are facing.
Now connect the battery and the adapter and check whether it works or not.
If this does not work. Check the Adaptor.
Hope this should help
Regards
Sammy
Posted on Sep 04, 2008
Monitor won't come on when power on
Try unplugging it and then plugging in again, and make sure the monitor is turned on.
Apr 20, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer aspire m5 won't charge
it sounds like one of three things:
1. Battery itself no longer functions
2. Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
If the problem is the motherboard, you can try to have it repaired but I don't trust many companies to do this kind of work. I outsource my motherboard jobs to a company called Laptop Rescue (http://www.laptoprescue.com/laptop-repair-2/). Coincidentally, they also sell laptop chargers in case that's the problem. Hopefully it's just a charger or battery issue and not a motherboard.
http://www.aurabuy.com/cheap-4400mah-battery-for-acer-travelmate-4740-4740g-4740z-4750-5335g-5335z-5340g-5542g-6495tg-8473g-8472t-tm5740-paypal.html
Apr 06, 2013 | Acer Aspire One PC Notebook
My Acer KAV60 laptop won't turn on. When I push the power botton, it blinks green once then nothing.
Has the laptop been damaged? Dropped? Same on battery? Remove battery, try AC only. Try another cord/charger with the EXACT same power specs. Reseat Memory mods. Test the DC volt output, at the laptop plug in, with a multimeter. Power issues are difficult to diagnose long distance.
Jan 31, 2013 | Acer Aspire One PC Notebook
When I turn on my acer aspire 6920 laptop it will not start up. I have the power lead plugged in but it won't turn on.
you mite have a conflict in the start up program. go into start up settings and see if theres a problem . if not try the acer recovery that should sort it out.
Jan 27, 2013 | Computers & Internet
Acer aspire 5736z-4460 won't turn on
tried to remove the battery and then re attached, turn on the pc laptop check if it works.
Aug 03, 2012 | Acer Aspire 5736z 4460 Laptop
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Laptop just keeps shutting down and won't turn on
it may be one of the causes, but the main reason for it is the power supply keeps on fluctuating. You may call Acer for a possible replacement for it..
Jun 19, 2011 | Acer Aspire 5315 15.4-inch Notebook PC
Computers & Internet Logo
2,500 people viewed this question
David Payne
David Payne
