Question about Dell Dimension 3000 PC Desktop
No ethernet response.
I just had cable installed and the person doing it told me that the cable highspeed coudlnt be turned own do to a faulty ethernet hook up. How do I fix it? It doesnt lite up at all? No response! Can someone please save me from hthe perils of dialup?!?!?!?!?!
    Scholar:
  • 141 Answers
Assuming you are talking about the onboard ethernet..... First make sure it is enabled in the system bios, and make sure it is working in the device manager (control panel). If the device manager indicates a problem with your network card, you have to sort this out first.
If this is all fine, open a command prompt in windows and type "Ping 127.0.0.1" and see if you get a response. If you get a response, then your network card is okay, and you may just have a bad network cable, which is quite common. If you don't get a response from this command, then your network card is bad and you need to replace it. If it is onboard, just disable it in bios and install a PCI network card.
If the ping command gives you a response from the card, replace the cable first. Otherwise, it could be a router, if you have one, or the modem.
Posted on Sep 04, 2008
Wont read ethernet cable
i guess what you are saying is that the ethernet cable doesn't bring you any connectivity. try to replace the cable (maybe it's faulty or a crossover cable and your router/switch doesn't have audo mdx option)
also check if your ethernet card is installed (drivers) and enabled
Mar 09, 2012 | Computers & Internet
A need help
you can set your playstation 3 online by two ways, 1- by a wired connection, and 2- Wireless,
1-Wired Connection: Plug an ethernet cable from your highspeed modem to the back ethernet input on your ps3 system, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wired Connection. and follow steps
2- Wireless Connection: You must have a Router connecting ethernet cable from your intenet modem to the router, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wireless Connection and follow steps,
hope this helped you on setting up your ps3 connection :)
Apr 13, 2010 | Sony Playstation 3 (PS3) Console
Adding a PCI ethernet card?
One port on the router is an "Ethernet" port -- look closely to see the 8 wires in the socket.
You'll need a similar 8-wire connector on your computer,
and an "Ethernet-cable" that has 8 strands of wire.
Adding-in the PCI Ethernet card will add an 8-wire connector,
so that the Ethernet-cable can be connected.
Be sure to buy a 'PCI' Ethernet adapter, not 'PCI-E', and not 'ISA'.
It may come with a CD-ROM containing software to be installed.
Don't pay more than $20. Or, find a "computer-geek" -- he/she probably will have one or more "spare" PCI Ethernet cards to give to you.
Nov 18, 2009 | Dell Dimension 4400 PC Desktop
Compaq Preario SR 1208AN ethernet connector faulty
Have you spent about $5 and tried a different Ethernet cable?
Look at: http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00251993/c00251993.pdf
For your desktop computer, the Ethernet adapter is integrated into the motherboard. So, to replace the connector, you will have to replace the motherboard, costing over $200, unless your computer is still eligible for service via the HP warranty.
It would be much easier & cheaper (under $20) to purchase a PCI Ethernet card, install it into an empty PCI slot, install the software from the CD-ROM that came with the card, and connect the Ethernet cable to this card, rather than to the integrated socket.
Oct 22, 2009 | Computers & Internet
Laptop doesnt find connection to cable modem
download setup wizard to find connection from windows
Feb 12, 2009 | Acer Aspire One PC Notebook
My Optiplex GX280 just stopped connecting to the internet.
try buying a cheap ethernet card so if it isnt that, that you dont wast any money. but remember when you do it remember to unplug all the cable from the computer.
Dec 06, 2008 | Dell OptiPlex GX280 PC Desktop
Need Ethernet port on PC
If you have a wireless router then the ethernet cable will go between the modem and the router. Then you need a wireless LAN card to connect the PC to the router
What model router and modem do you have?
PC wireless card
Jul 03, 2008 | D-Link DFE-530TX+ Fast Ethernet PCI...
Computer needs ethernet card for highspeed internet
It depends on your computer and your operating system, but generally if you have USB ports with a Windows-based machine, then you can use a USB ethernet adapter. You plug the adaptor into your USB port, then the ethernet cable into the adapter.
Almost any electronics supply store ie Circuit City, Best Buy, plus Walmart and other big discount stores carry USB Ethernet Adapters. You can also try your local mom 'n' pop computer supply store.
http://www.dlink.com/products/?pid=133
I'm posting a link to a DLink adapter as an example *only.* There are other brand names out there that would probably do just as well.
Hope this helps!
Apr 03, 2008 | Dell Dimension 4600 PC Desktop
Internet promplems
for dial up simply a modem .... on laptops if you do not have a builtin modem you can purchase a pc-card modem that goes into your pcmcia slot ... for highspeed either a ethernet (same option as modem) but almost all modern laptops have a built in ethernet ... or usb ... also I highly recommend a router if you are going highspeed ... even if you only have one computer ... a router will protect your system because it provides a NAT firewall. If you go with a router make sure to set up the internet connection on the router do not tunnel through the router with a PPPoE connection
Mar 30, 2008 | Computers & Internet
Dell Dimension 3000 PC Desktop Logo
77 people viewed this question
Alun Cox
