Question about Samsung Prostar 824 Keyset Telephone
Phone dont ring
How did you get your phone to ring after the power outage
  • Anonymous Sep 10, 2008
    Having problems after a power outage. I'm assuming the system has to be reprogrammed but no directions in the user manual.
    President:
  • 860 Answers
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished. hope that helps
Posted on Feb 13, 2009
Power outage now you have to select a line manually instead of just picking up phone and it's taking awhile before it starts ringing
What usually happens after a power outage is the system defaults because the backup battery in the memory card is dead. That means 2 lines only on every phone, pulse dialing, and all phones ring. If your system looks like that, it's time to call the Nortel repair tech. He can replace the battery or software module with a new one and reprogram the system.
Carl
Aug 17, 2010 | NorStar M7324 Corded Phone
Samsung Prostar 816
Did you try unplugging power cord for five minutes? often this fix the problem.
Aug 12, 2008 | Samsung Prostar 816 Phone
Panasonic cordless phone no dial tone changed batteries -no help other functions work--menu light doesn't lite when phone rings
electricity went out for 10 hrs
decided to switch phones around----not phone problem
phone ok in all phone outlets in wall
it was plugged into fax machine--maybe electric power outage hurt fax phone connection for phone line
fax works fine, just can't work as did before with phone line into fax
will call brother #775 monday
all was plugged into power surge
maybe have to adjust something on fax or buy new one because of power outage????????????????
Nov 22, 2009 | Panasonic Lands Phones
Since power outage phone lines do not ring - only to receptionist
Your system lost its programming. It will need to be reprogrammed completely. The lines are ringing on the extensions where I voicemail is, unplug voicemail and at least lines will ring in correctly.
Jun 15, 2009 | Avaya Lands Phones
ATT/Lucent 854 ringing after power outage
Press PROGRAM
Press *
Press #
Enter 2 digits (11 through 22)
Press INTERCOM
This should work.
Mar 22, 2009 | AT&T ATT-974 Corded Phone
Comdial Executech 6414 won't ring
DX-80 Comdial After power outage only Phone # 1 rings, i turned off for 1 min but no luck, any ideas?
Feb 24, 2009 | Comdial Executech 6414 Corded Phone
No ring for some phones after power outage- dks 930 phones
Press feature key then dial #* password 000000 next, go to sets, hit show, hit next till ringing assingment is display hit show and change from n to y on line ringing assingment. do this for each set and line that need to ring.
Dec 24, 2008 | Southwestern Bell Landmark DKS930 Corded...
Samsung Prostar 816
The battery is dead and will not maintain system programing after a power outage. If the battery is not replaced this problem will occur everytime the power goes out.
Mar 19, 2008 | Samsung Prostar 816 Phone
We had a power outage and have lost ringing on every phone appart from 1. We have had this before and program codes had to be put back in. Where can we get a copy of these codes to program?
You need to know which phone system you have. Your Norstar phone can work on a few different Norstar phone systems that all set up and program differently.
Once you determine which system you have you need a "Programming and Installation" manual for the system NOT a "user guide"
Feb 06, 2008 | NorStar M7310 Corded Phone
Phone ringer has turned off following a power outage.
I am assuming you have a Strata VIe system with this phone. I added a website below with all the program manuals. If you have a DK system please look at program 81 to get ringing back. I dont know the programming very well on the Strata VIE systems.
http://www.wedophones.com/ToshibaManualsLead.htm
Dec 07, 2007 | Toshiba EKT6520SD Phone
Samsung Prostar 824 Keyset Telephone Logo
246 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
