Question about ElectroVoice http://www.electrovoice.com/products/70.html Amplifier
Ev eliminator 1 18 sub
How do you replace a speaker in these cabs without being triple jointed
  • 1,512 Answers
Hi steves-music
Being triple jointed, or having a third extra thin flexible arm will help!! lol. I have not done one before my self, but it sports the same design as the Peavey subcompact bin, and I have done a few of them. You will have remove the front grill, to go in through the front, and unscrew/bolt the driver using a 1/4 inch ratchet drive with an extension will help get the back screws. Use of a mirror will help you sight the screws for removal and replacement. Not an easy job, but doable.
regards
robotek
Posted on Sep 06, 2008
Telex EV SonicXS Computer Speakers Not turning on
Hello harisoza, check for power amps, and fluctuation on that room. or entire home, . sometimes this lead to this kind of problems.
Carl
Jun 21, 2012 | Sonic EV SonicXS 4.1 Computer Speakers
I use a Mackie 1604vlz board. I have Passive EV Speakers that I use a QSC power amp for. I want to add one Powered Subwoofer to this. How can I hook up without buying a crossover? Can I run out frome the...
You can, but I would not suggest it. Depending upon the input design of the powered sub, the highs might not get filtered out. Many subs assume that they are only receiving the lows. You are better off using a crossover between the mixer and the amp for highs and the powered sub for the lows. Please note that the crossover will give you much more control over the sound quality.
Dan
Mar 29, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
What you use to hook them up? i dont know how to hook them up to my pc or tv
you connect all the speakers to the amp sub woofer and run a single or multiple jack plug lead into the back of the pc
Mar 05, 2011 | Sonic EV SonicXS 4.1 Computer Speakers
Wiring diagram for horns in a speaker ev eliminator i dual 15's
hi can you please tell me on a ev elimenator horn which out of the wires is the live?
Nov 02, 2009 | Audio Players & Recorders
No sound from EV SH-1502 ER 15" driver
Either the 15" speaker is dead, or the passive crossover inside the unit. The simplest way to identify your problem is to remover the speaker that isn't working from the enclosure, and exchange it with the speaker that is working. If there's no sound still, it's the speaker itself that is the problem. If it works in the other cabinet, then put the "working" speaker in the cabinet you took the "bad" speaker out of, and if it doesn't work, then there's a problem with the crossover in the first cabinet. I believe you can buy a replacement crossover from EV. If it's your speaker, do a google search for "speaker re-coning" in your area - it's cheaper to re-cone the speaker than buy a new one.
Jun 18, 2009 | ElectroVoice . Speaker
No sound on EV SonicXS 4.1
Good day Idn2000
you may check also in the manual your actual conection, and see if is the right, then check on control panel and speaker setup, for 4.1 setting. if the speakers don't work,at back, something is bad inside the controller, on sub. be carefull opening and moving things inside, but you can check that .
Nov 28, 2007 | Sonic EV SonicXS 4.1 Computer Speakers
EV sonic XS 4.1 computer speakers and amp
Hi CarrieBeth
depending on the brand of your speakers (creativelabs) etc, have different models, but some of them have problems with AMP, and subwofers. Send me your brand or model, to help you out more direct, or depending on the brand, some models lile 5600 from CL. have problems on the AMP module on the sub. have to change or fix the AMP chip.
hope I can help
Carl
Nov 16, 2007 | Sonic EV SonicXS 4.1 Computer Speakers
Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Oct 28, 2007 | Cerwin Vega VE-28S Subwoofer
ElectroVoice http://www.electrovoice.com/products/70.html Amplifier Logo
544 people viewed this question
Top ElectroVoice Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
 Grubhead
Grubhead
Are you an ElectroVoice Audio Player and Recorder Expert? Answer questions, earn points and help others
