Question about Maytag MZD2752G Side by Side Refrigerator
Refrigerator not cooling at all
I had it setting in a garage for a year went to plug it in and it is not cooling at all freezer or refrigator section, everything seems to be working.
Thanks for your help
  • 51 Answers
I would lean towards a freon leak. You can check compressor with a clamp on amp meter to see if the amps are proper if they are low it would show low freon
Posted on Sep 08, 2008
I have model number PDE18LZRBB. Freezer works fine; refrigerator section will not cool properly.
Your problem is usually caused by poor air circulation. The only way the refrig section gets cold is from the fan in the freezer blowing cold air into the refrig section. The fan should be behind the back wall of the freezer and should be running at the same time the complete refrigerator is running. No fan run---no cold in the fresh food section.
Apr 01, 2015 | GE Refrigerators
Refrig. Won't keep food cold but the freezer works fine. Milk spoils after 3 days in the refrigerator. What's wrong? The thermastat was supposely changed?
If the thermostat has been replaced, then I would take a look at the dampers between the refrigerator and the freezer. Here is why....
All the cooling takes place in the freezer section of the unit, there are passageways with dampers that connect the freezer section to the refrigerator section. If these dampers get stuck in a certain position you will either have not enough cooling or to much cooling. This sounds like it is your issue. Hope this helps.
May 07, 2010 | Refrigerators
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
The freezer is cold but the refrigerator section is not getting cold...it is not warm but not cold according to the dial settings
check the operation of the damper door between the freezer/refrigerator section which lets cold from freezer into refrige compartment for ice build-up which will cause damper door to not open fully and cool the refrige compartment,if this is the problem,unplug the door ans remove and let thaw then replace and try it then
Jan 09, 2010 | Kenmore 64802 Top Freezer Refrigerator
I have 36'' Heartland refrige Model #3100. Every year or so refrige section stops cooling. I unplug for about 1 day after transfering food plug it back in and its fine. Any help would be greatly...
your frezer unit need to be check what you actualy do is defrost the unit every year :) but the problem is in your freezer unit that might be the heater unit / your fan.
Dec 30, 2009 | Refrigerators
Cold but not frozen
23 years old ? That thing was costing you more than a new unit would cost for the past 5 years!
Assuming your airflows are good, Its time for a new refrigerator.
Aug 29, 2009 | Refrigerators
ED25PQDW01 side by side refrig -freezer is inconsistent. Need to have full cold to maintain freezer temp. cleaned coils, but still an issue.
Do you see a light coat of frost in freezer section about 12 inches up (defrost problem indication) ? Has the icemaker slowed down a bit in ice production ? What is the refrigerator control set on ? When you turn the freezer up completely , it cuts off the cold air flow which cools the refrig section . If refrig control is set mid way , turn it up higher , so refrig will run longer , but lower the freezer setting so some cold air will enter the refrig section . Also check to see if the freezer fan is working .
Aug 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Maytag MZD2752G Side by Side Refrigerator Logo
109 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
