Question about Mitsubishi WS-55807 TV
Mitsubishi WS-55807 turns on but then powers back down after a few seconds
My Mitsubishi WS-55807 will turn on, but within a few seconds will turn back off. I did the self test (holding the input and menu) and got 2-2, meaning that it was a short protect. As you described I tested the F9A04 and F9A05 fuses. Both fuses tested bad (open). According to your posted solution this means the output circuit is suspect. Is there anyway to test that? Or do I just need to get an entire board? I'm just not sure where to take it from here. Any assistance would be appreciated.
  • 927 Answers
Good Day;
The fuses tell you that circuit has failed and was drawing too much current. No other test is needed.
Good Luck, big Irish.
Posted on Sep 18, 2008
MY WS-55807 TURNS ON FOR THREE SECONDS AND THEN IT TURNS OFF. I UNPLUGGED IT FOR A WHILE AND STILL THE SAME. I DID AN ERROR CODE OPERATIONAL CHECK AND I CAME UP WITH TWELVE WHICH MEANS NO ERROR IF I AM...
if you unplugged it you will only get the no error code 1,2.
Plug back and turn on, when light on power goes out try it again--if power light goes out there will be a error code.
SD TECH
Sep 13, 2010 | Mitsubishi WS-55807 TV
IT COMES ON FOR THREE SECONDS THEN CLICKS AND TURNS BACK OFF. ANY TIPS?
hold the input and menu button down on the front of the set for 5 seconds then release. The power light should start blinking a code. 2-2 is a convergance chip problem
Feb 04, 2010 | Mitsubishi WS-55807 TV
My mitsubishi 1080 WS-55807 has lost the picture
Unplug the set, remove all other audio/video components, go open front door, and roll it out to the curb.
Nov 24, 2008 | Mitsubishi WS-55807 TV
Dm board (power supply) for mitsubishi rear projection tv (ws-55807)
Good day,
mohiuddin;
If the indicator stays on then you may have an DM PCB problem and to correct this do the the folowing:
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Jul 22, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
WS-55807 power up problem
If you are handy with a multimeter you can check all of the pico fuses the little green 5 amp fuses. Most likley you will find one of those shorted F95A01 most likley but could be another. You will need to change this and also your convergence amps. These three parts are most likely shorted in your set. You are looking at about 250-350 from a competent repair shop.
Feb 04, 2008 | Mitsubishi WS-55807 TV
WON'T STAY ON
That is a typical problem in the power supply. It could be a switching regulator that has i think 7 pins, but it gets the power supply up and running with around 157VDC. If that is missing the set won't power up at all. Where are you located. I'm in Louisville Kentucky. Let me know if that works for you. Keep in mind there are quite a few fuses in there too. so check those. I think on that model there is 7 or 9 fuses to check. Talk to you soon. Jay
Jan 14, 2008 | Mitsubishi WS-55807 TV
Mitsubishi ws-55807 tv
call a repair man not much else  you can do, try and unplug for a few min
Oct 17, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV Logo
164 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
