Question about Canon PowerShot SD850 IS Digital Camera
Camera fallen down from my hand
Hi My camera canon Power shot sd 850 is fallen from my hand.
Can you please assist me how to check whether the camera is working fine or not.
I tested by taking some snaps its working fine.
Posted on Sep 05, 2008
In the shutter counter of canon t3i,,,how many numbers of shot can I make,,,
Hi
There are several points here. The number of shots available at any time is dependant upon :-
1. The state of charge of the battery
2. The use or non-use of the flash
3. The size of the SD card used for recording the pictures.
The number of shots left is given on the bottom right hand corner of the LCD screen and should presumably take these things into account from past history. Otherwise the number may just reflect the space left on the SD card. In terms of continuous shooting, it takes about 3.7 shots per second whilst the shutter button is held down, presumably until the battery runs out, or the SD card is full. All the above details are available in the camera User Guide which can be downloaded and saved from here:-
http://gdlp01.c-wss.com/gds/7/0300008087/03/EOS_600D_Instruction_Manual_EN.pdf
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 10, 2014 | Canon EOS 600D Rebel T3i Digital Camera...
How do I recover pictures back to my power shot sd card
If your computer has a built in card reader you can put any photo back on the card from your computer by dragging and dropping the file to the drive letter that is your SD card. If you're trying to recover lost photos from a SD card Google "card recovery pro". It's a free program that will read your SD card and restore as many photo's as it can.
Sep 23, 2014 | Canon Powershot Power Shot A70 A 70 3.2 Mp...
I have a black screen put power to camera is on .this is a canon powershot sd 850 is
Try the steps in the link below and it should help you fix it.
Click here - > Canon Camera Troubleshooting
Regards,
Suhail
May 16, 2012 | Canon PowerShot SD800 IS / IXUS 850 IS...
My Canon Power Shot A590s card is locked and I have absolutely no clue how to unlock it. Please help
Take out your SD card. SD cards have a small sliding switch on the side of the card. The switch moves up and down and is probably in the lock position. 5748d99.jpg
Sep 04, 2010 | Canon PowerShot A590 IS Digital Camera
I cant download video files from my Canon IXUS 850 IS
Use a separate card reader to transfer the video to a folder you create on your desktop. Try using Quicktime to open it.
Apr 11, 2010 | Canon PowerShot SD800 IS / IXUS 850 IS...
When I put the memory card in and turn on the camera, it keeps saying memory card error.
If camera show Memory Card Error, Check whether the card is inserted properly or not. For SD card, check out the card lock switch is in the correct position and not stuck in between.
You can Format the memory card in the camera using the Setup Menu option (Format). Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data.
If after formatting the card do not clear the error, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Rating the solution is highly appriciated...Good Luck
Mar 03, 2010 | Canon Power-shot S1 IS Lens Converter
Canon 10D works fine after impact but overexposes now.
HI I AM SAGHA A CAMERA REPAIRER FROM MUMBAI,YOU SAID YOUR CAMERA WAS FALLEN ON THE FACE WITH LENS THEN STARTS OVR EXPOSING PICTURES THEN FIRST CHECK YOUR LENS'S APERTURE IS WORKING FINE OR NOT.ATTACH ANOTHER LENS TO YOUR CAMERA & THEN CHECK THE EXPOSURE THEN IT WILL BE CLEAR WHETHER YOUR CAMERA IS DEFECTIVE OR LENS IS DAMAGED INTERNALLY.REPLY ME ABOUT IT.THANK YOU & ALL THE BEST
Aug 02, 2009 | Canon PowerShot SD1000 Digital Camera
Canon SD 850 says lens error,
There could be a number of reasons for the lens error. ie. . sand in camera, impact damage etc. Typically the lens can be dissasembled and repaired by a competent camera repair technician. If you are certain that you did not damage the camera in any way I would send it back to canon for a warranty repair. If you however think you could have damaged it you are probably looking at around $100 to repair the camera. Hope this helps!
Jun 09, 2008 | Canon PowerShot SD850 IS Digital Camera
E 18 problem
broken lens on Powershot SD600
Feb 17, 2008 | Cameras
Canon PowerShot SD850 IS Digital Camera Logo
41 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
