Question about Canon MP970 Photo All-In-One InkJet Printer
Canon MP970 Streaks!
Hello
I just purchased a Canon mp 970 and on my color photos you can see streaks or lines going across the whole page. This is not noticeable in black documents, mainly just full color pieces.
I have done all the cleaning and head alignment that is offered. I have replaced two low cartridge and still have the same problem.
Any Suggestions????
  • 1 more comment
  • Anonymous Nov 20, 2008
    The same problem!
  • d2j2flanders Feb 20, 2009
    I have the same problem.  Streaks run through all photos I print from my digital camera.  Document printing come out fine.
  • vw57sports May 10, 2009
    I've had my Canon MP970 and I'm disappointed in the pictures it prints. The pictures have been downloaded from my camera to my computer and I try to print them and they have lines through them. Even images I print from website come out with lines through them. I'm beginning to think I made a mistake with this purchase & wish I had my old HP back.
    Problem Solver:
  • 4 Answers
The colered pictures may be illegal to print like school pictures if you scan and then print them they will have a line threw them.
Posted on Dec 12, 2008
Color streaks after gradation
sounds like you need a new magenta drum
Jan 14, 2014 | Canon imageRUNNER C3200 Copier
Streaks or lines
Vertical streaks:
Check,which color/s streaks are appearing on print out,remove that cartridge/s check on drum surface for streaks.. if found replace that cartridge/s..check.
Horizontal streaks:
This problem appears when the cartridge/s image drum not rotating properly. Resit the cartridges properly, print 20nos of blank pages, then check.... replace the cartridge..
Dec 29, 2012 | HP Color LaserJet 2600n Printer
Getting streaks across the page s9000
you can align the ink cartridges using it software then print some noozle check to see what color is not functioning well, here go to printer & fax right click on your printer then printing preferences ,maintenance ,,
Aug 03, 2011 | Canon i950 InkJet Photo Printer
MP970 Photo All-In-One InkJet Printer: The printer head alignment is off. I have tried to...
  1. Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Rear Tray or Cassette.
  2. Open the Paper Output Tray, and then open the Output Tray Extension. (1) Put your finger in the center of the top of the Paper Output Tray and open it gently. (2) Open the Output Tray Extension.
  3. Press the Paper Feed Switch to select the paper source where you have loaded paper.
  4. Print the print head alignment pattern. (A) Press the HOME button. (B) Select Settings , then press the OK button. (C) Select Maintenance , then press the OK button. (D) Select Manual head align , then press the OK button. (E) Select Yes , then press the OK button. (F) When " Did the patterns print correctly? " is displayed, confirm that the pattern is printed correctly, select Yes , then press the OK button.The input screen for the head position adjustment values is displayed.
  5. Note:If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
  6. Look at the first printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column A that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish i nputting the pattern number for columns B to F, then press the OK button. (C) Confirm the displayed message and press the OK button.
  7. Note: If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
  8. Look at the second printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column G that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish inputting the pattern number for columns H to K, then press the OK button. For column K, the best pattern will be smooth and have no streaks in the border indicated by the arrow. (C) Confirm the displayed message and press the OK button.
  9. Look at the third printout, and then adjust the print head position. Check the printed patterns, and use the or button to input the number of the pattern in columns L and M that has the least noticeable horizontal streaks, then press the OK button.
Source
May 16, 2010 | Canon MP970 Photo All-In-One InkJet...
Clp-500. toner streaking the paper.
I have the same streaks problem. Any solutions?
Nov 14, 2009 | Samsung CLP-500 Laser Printer
Hp 7310 printing with color horizontal streaks across. parts of the artwork are fine, then strirated lines down whole page. changed cartridge color and b/w and says it's installed fine. test page is...
usually when there is a defect on printing out while you have changed the cartridges , you will need to consider changing the printheads of that printer.
Aug 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Streaks in darker colors HELP.....
This can be caused by an incorrect paper type set for the printer. Go into the printer menu and select "Quality & Media" change the setting to the correct type of paper you are using. If this is not the issue you could use the maintenance menu for the printer e.g. clean the printer nozzles, paper alignment etc, Also see if there are driver or software updates from Canon's website for your printer.
Jul 18, 2009 | Canon MP970 Photo All-In-One InkJet...
Pictures scanned with Canon 4200f show streaks
when scanning photos and especially magazines, don't go to low on the dpi (at least 300) and select DESCREEN as well as grain correction: HIGH
Dec 31, 2008 | Canon CanoScan 4200F Flatbed Scanner
Streaking
Hi there it will be either the drum unit for the color streaks you are getting or the fuser unit. Check the drum units for the streaks on them also check the fuser but the clue is when you have the streaks in different places. Most likely to be the drum units. You will need to replace.
Thanks J
Oct 30, 2007 | Ricoh Aficio CL7000 Laser Printer
My Canon i960 printer is printing red streaks on the pages
It's possible that the heads need to be replaced. That's one disadvantage to the printers that don't have the heads contained within the cartridge.
Feb 26, 2007 | Canon I960 InkJet Photo Printer
Canon MP970 Photo All-In-One InkJet Printer Logo
361 people viewed this question
old marine
old marine
