Hey! have you tried any data recovery software to retrieve your file? If not then try a data recovery software to recover your data. If any other help is needed tell me.
Files on a flash drive canbe corrupted if it is not removed from the USB port properly. Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove. To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive. If you need the data on the flash drive these WEB sites may help: - Data and Digital Photo Recovery www.artplus.hr/adapps/eng/dpr.htmwww.CardRecovery.com
Chances are that some files have been corrupted or the hard drive is corrupted. If you are lucky the hard drive is OK and you may have lost a few files. Connect the hard drive to your computer and check your data. If the hard drive is corrupted, you may have to format it to get it operating again and you will lose your data.
Files on a flash drive can be corrupted if it is not removed from the USB port properly. Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove. To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive. If you need the data on the flash drive these WEB sites may help: - Data and Digital Photo Recovery www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
Files on a flash drive can be corrupted if it is not removed from the USB port properly. Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove. To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive. If you need the data on the flash drive these WEB sites may help: - Data and Digital Photo Recovery www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
Files on a flash drive can be corrupted if it is not removed from the USB port properly. Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove. To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive. If you need the data on the flash drive this program may help: - Digital Photo Recovery www.artplus.hr/adapps/eng/dpr.htm
hi, your folder has been secured by a virus. donot format the drive or you will lose the info. look for a data recovery software and run data recovery on that partition of the disk to recover the corrupted files thanks
