Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Drive limits on my chamberlain wont register
I was closing my garage and stopped it halfway as i only wanted it to stay half open to allow ventillation. It made a horrible noise. now the drive limits got erased. I've tried to adjust the limits with the screws but it is not registering.
    Champion:
  • 244 Answers
Have NO IDEA what you are saying. Do you mean you adjust limits and chain moves too far? Or is chain not moving. Bad gears. Toss unit unless you are handy and can rebuild gears.
Posted on Jan 14, 2009
My garage door is a chamberlain lift master. We had to pull the latch and manually close it last week. When I opened it, my super-strength:) threw it open too fast and I think I threw off the main drive...
No need to - the unit has adjustments to control where the door stops on closing. You need to back off a tad on the closing setting so that the door stays closed.
Jul 04, 2017 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door wont go completely up
on the machine there will be a couple mini dials to be turned, these are the ones used during installation to get the correct distance for closing and opening, they should be labled, but not all are. one is for open adjustment, and other is for close adjustment. carefull, they can be verry touchy, meaning the slightest turn can make it move alot. a general way to adjust them is a half turn is equivlent to about 2" door movement.
good luck
Jan 01, 2011 | liftmaster Chamberlain Garage Door Opener...
The garage door opens halfway and then stops; it will close completely however
COULD BE A BROKEN SPRING
COULD BE A SENSITIVITY ADJUSTMENT.
HOW DOES THE DOOR WORK MANUALLY - IF YOU CAN'T LIFT IT NEITHER CAN THE OPENER.
ALSO COULD BE BAD DRIVE GEARS - BUT MOST OFTEN A SPRING 2ND WOULD BE OPERATOR ADJUSTMENT
Jun 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain hd900d garage door opener
You will have to open the unit and look inside it. Unplug it first. It should have 6-8 screws to take off. You will see 3 white plastic adjustment screws. There is a carriage they sit in. Make sure they are in this carriage. If you would like stay back a bit and plug it in and watch it run to see how it works. It is a direct contact system, so when the middle screw touches the copper limit of the limit screw it stops. Thanks BB
May 20, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Installed garage door opener and the door opens then closes on its on
The down limit switch could be set to low. Try moving the screw clockwise to raise the stop point.
Dec 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do I reset my garage door opener. It is a Coromaster 2000 motor. The closing and opening setting are out and the motor only stops due to resistance.
The Coromaster 2000 does not operate off limit switches. It has a quarter-revolution optical pulse counter. To re-program the open and close limits do the following: Ensure that the door is open at least a couple of feet. Press the reset button once or twice Short out pushbutton and common and hold until close limit and then release. Door should stop at your new close limit. Wait 5 seconds. Short out pushbutton and common and door will open. Hold the short until open limit and then release. Limits should now be set.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door closes and then automatically opens half way
ADJUST THE DOWN LIMIT IT THINKS THERE IS AN OBSTRUCTION AND IS REVERSING LIKE IT SHOULD.
TURN THE LIMIT ABOUT 1/4 TURN AT A TIME.
HOPE THIS HELPS
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener doesnt close all the way.
The motor is probably either stalling because the door is too stiff, or you have a beam break detector that is being triggered when the door is halfway down.
Nov 23, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Won't Close
Remove power from the opener. Then, pull the red release rope and manually lift open the door. It should move with little effort. Next, pull the door halfway down and let go. The door should stay where you left it. If it fails either test, the door lift springs need replacement or adjustment. If it works ok, follow the proceedure in the owners manual for adjusting the up and down limit sensors, and the emergency reverse adjustment.
Jul 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
120 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
