Question about JVC GR-D350 Mini DV Digital Camcorder
Firewire connected Camcorder not seen by XP
My JVC GR-DV3000 camcorder suddenly is no longer recognized by firewire connection in XP Pro SP2.I can not upload my mini DV tapes to hardisc.It worked OK until one day when I plugged in the camera and it was not 'detected'.There were no obvious recent changes in  hardware but I have loaded one or two new unrelated software progs. I tried reinstalling the Drivers and updating them.Device manager shows the FW controller as working properly and drivers installed. Unfortunately I do not have another FW device or FW lead to test out to track the problem but will somehow get them if have no luck elsewhere. Is there anything else I can do to locate and fix the problem? Thanks Sam i dont have the drivers to connect the camcoder to my PC
Not is resposting for to me to see you see me ´n going
Posted on Sep 11, 2008
How to connect JVC GR-D820E camcorder to PC
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | JVC GR-D370 Mini DV Digital Camcorder
JVC GR-D50 not seen by PC or Mac via Firewire
Could it be a bad cable or a bent/broken pin where the cable is connected to?
Nov 11, 2008 | JVC GR-D50 Mini DV Digital Camcorder
I have jvc GR d720 dv camcorder but unable to connect .. driver required ... i have firewire send me in khairnar.abhijeet@gmail.com
No driver required for Windows XP. I simply plugged in the camera via FireWire. Windows automatically recognizes it as a digital video device. Then I started up Windows Movie Maker and followed the wizard to capture the movie from my digital video device. It was really easy.
Oct 24, 2008 | JVC GR-D720 Mini DV Digital Camcorder
My computer no longer recognizes my JVC GR-D70U mini DV cam when I plug it into a usb port.
Hi, I am not sure. But I believe the camcorder has to be on when you connect to the computer. and I assume you use firewire for this particular camcorder.
I too once had this problem when I used Windows Vista. If you too use Vista, try it with Windows XP.
cheers,
Sep 19, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
JVC CAMCORDER DRIVERS
its true that normally you don't need to download the driver, however when it does pop up, i'd say go here http://members.driverguide.com/driver/detail.php?driverid=87522 and just download the zip file for the drivers.
Jun 02, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Problem connecting JVC GR D370U
I have JVC GR-D270 cam how I can copy my video from tap to my Laptop
Sep 27, 2007 | JVC GR-D370 Mini DV Digital Camcorder
JVC GR-D275 not seen as connected to computer
Many Camcorder users have faced problems while connecting their camcorder to their PC. One of the most common problems is ?no activity? after connecting the camcorder to the PC. The found new hardware wizard does not run and fails to detect the camcorder. This can mean two things. Either the DV port on the Camcorder is not working or the FireWire cable is faulty. Try using a different FireWire cable. If the camera is still not detected by the PC, try connecting it to a different PC. If the Camcorder is still not detected, then your camcorders DV port is most likely at fault. Confirming that the FireWire Port on you PC is working fine You can check the status of the FireWire port from under Device Manager. To access the Device Manager, Right Click on My Computer and then click on Properties. Select the Hardware tab and click on Device Manager. If you cannot see the FireWire port in the list, then it is not inserted properly into the motherboard. If you see a Yellow exclamation mark, then you need to install the drivers, which are usually bundled with a Floppy or CD with the FireWire card.
Dec 21, 2005 | JVC GR-D275 Mini DV Digital Camcorder
JVC GR-DVF31 - How to transfer MiniDV to PC?
buy that wire, check ur camcorder if it has 6pin or 4pin for firewire then check ur pc if it has firewire card...if not you have to purchase the ieee1394card. install it then connect your camcorder to pc through firewire and that will be it.. u also need to have a software for video capturing and editing like adobe, roxio, pinnacle , etc...hope that helps.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
JVC GR-D350 Mini DV Digital Camcorder Logo
158 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
