Question about GE JVM1350BW/WW/AW/SY Microwave Oven
Instructions for replacing door handle on JVM1350BW02 Microwave
I have a GE Space Saver, Over-the-range, microwave, model number JVM1350BW-002 that has a broken door handle that needs to be replaced. I can see how to detach/attach the top of the handle, but not the bottom. I am afraid to order the part unless I am sure that I can replace it. Could you pleas tell me how to do this or show me where to get instructions to do this? Thanks.
Joel
  • kny2 Sep 06, 2008
    I have a similar model, JVM130G001, and the diagram looks like it. I already figured out that I need to snap off the plastic back. Now, where can I find a replacement handle?
  • GE Master
  • 9,086 Answers
You may have to rotate and pull the handle once the top screw is removed.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 06, 2008
WHAT IS THE CUBIC FEET OF JVM1339WB-002 GE MICROWAVE SPACE SAVER?
Determining the cubic feet of any given appliance, Microwave, Oven, Freezer or Refrigerator is quite simple.
Follow these steps.
Open the door of your microwave and measure the length, width and height in inches of the interior cavity.
Multiply the length by the width by the height using a calculator to get the total in cubic inches.
Divide the cubic inches by 1,728, which is the volume of a cubic foot. The resulting number will be your microwave's measurement in cubic feet. You can also use an online conversion calculator to simplify matters
Hope that helps
Sep 12, 2014 | General Electric Microwave Ovens
Replaced handle on ge space saver microwave now light stays on
Check to make sure the door properly positioned, if yes! one of the door latch switches is defective and will need to be replaced.
Mar 05, 2012 | Microwave Ovens
Problem with the GE JVM1350BW/WW/AW/SY Microwave Oven The handle broke off completely. Can it be replaced? Doesn't look like there is way to get back of door off to replace/repair handle.
The inner plastic ring has to be removed. That WIDE ring is called the choke. Use a flat bladed screwdriver and a knife blade to get it free. It has tabs on the inner side and the outside that have to be unlatched. Once the choke ring is free you will have access to the screws.
See this video:
Sep 24, 2011 | GE JVM1350BW/WW/AW/SY Microwave Oven
Ge Model JVM1350BW 002 turns on when door is closed or on it's own
If "F3" is appearing on the display, then you have shorted membrane keypad.
If this is the case, the keypad is no longer available and the oven would have to be scrapped.
Otherwise, I would suspect a bad door switch or door switch mount, which are usually pretty easy to fix. See our file here.
You can find links to helpful exploded view diagrams and other part ordering help here. Enter your model number as "JVM1350BW02".
I'd recommend that your bookmark this link to your favorites.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once that's off, the switches are easy to get to.
Feb 09, 2010 | GE JVM1350BW/WW/AW/SY Microwave Oven
The door handle broke off my GE microwave
Actually the door handle CAN be replaced at a cost much less than pruchasing an entire new microwave oven. And, YOU can repair this yourself and save the cost of a service call. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
If the model number is correct, the part number is WB15X322. The cost is about $40. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you
Dec 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile Spacemaker XL Sensor Mod # JVM 1350AW 02 Microwave oven. How do I replace the door assembly? Is there a danger of elecrical shock involved?
You're usually better off just replacing the bad parts instead of the whole door.
If so, you can separate the door panels (as shown in the attached photo) then you can replace separate parts.
You can't remove the handle without doing this.
You can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Oct 09, 2009 | GE JVM1350BW/WW/AW/SY Microwave Oven
Jvm1350ww 002 Handle broken
The handle part number is WB15X335 and is available from a number of sources online. You can replace the handle alone, but you need to take the inside door panel off to get at the screws. It's been too long since I've worked on a GE to remember if you need any special tools (some ovens have security screws holding things together).
Apr 01, 2009 | GE JVM1350BW/WW/AW/SY Microwave Oven
GE Handle replacement
The handle is part number WB15X335 and you can find it online from several sources. You can replace the handle alone. You do have to remove the door inner panel to get to the handle screws.
Jan 27, 2009 | GE JVM1350BW/WW/AW/SY Microwave Oven
Microwave Will not work
This is usually a bad door swithc or loose or broken door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 10, 2007 | GE JVM1350BW/WW/AW/SY Microwave Oven
GE JVM1350BW/WW/AW/SY Microwave Oven Logo
804 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
