Question about Nikon D80 Body Only Digital Camera
Flash In auto mode of my D80 how to turn off flash
    President:
  • 1,114 Answers
Hi - You can download the manual by clicking the link underlined in blue below:
D80
See page 41:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 05, 2008
How do I turn off the flash on my D80
The Flash Mode button is at the side of the camera with the mode dial wheel.
If you look from there towards the lens you will find a small button with the typical arc icon.
Press the Flash Mode button until the display shows the flash icon with a line across it.
You may find more help in the Owner's Manual which you can find here:
http://www.nikonusa.com/pdf/manuals/dslr/D80_en.pdf
May 10, 2014 | Nikon D80 Digital Camera with 18-135mm...
How do you turn off automatic flash manually on Nikon d80?
Assuming you're in one of the point&shoot modes (any mode other than the PSAM modes), press and hold the flash button on the front of the camera and turn the main command dial on the back to cycle through the available flash modes. To turn flash off, select the lightning bolt in a circle with a slash through it.
In the PSAM modes the flash will not pop up on its own.
Aug 22, 2010 | Nikon D80 Digital Camera with 18-135mm...
On auto my flash wont pop up and it keeps cumming up ro6
In Auto the flash won't pop up unless the camera decides it needs it. Try the P mode.
The r06 isn't an error. It's simply telling you how many more pics you can take in a burst before the buffer fills up.
Dec 05, 2009 | Nikon D80 Digital Camera with 18-135mm...
My nikon D80 built-in flash not work in TTL mode
It may be sensing enough light at your location so the flash does not fire. If you want to force it to fire, make sure the flash icon is selected and also use Auto mode to test
Nov 27, 2009 | Nikon D80 Digital Camera with 18-135mm...
D80 SLR lens /flash prob lem
What are your other lenses? If they're not AF lenses, you're not going to get autofocus or metering.
Is your flash not working when popped up? Remember that the flash won't pop up automatically in Manual mode.
Oct 24, 2009 | Nikon D80 Digital Camera with 18-135mm...
Won't flash when connected to my Nikon D80???
Set the settings to TTL for both the camera and the flash
Jun 27, 2009 | Sunpak Auto 555 TTL Flash
My flash will not turn on. It says flash off in function.
call 305-653-7355 Service Center, ask for Zack
he can assist you
Apr 15, 2009 | Cameras
In built Flash
In Shutter, Aperture, Program and Manual modes the auto feature does not function. Only in auto mode.
Mar 06, 2009 | Nikon D80 Digital Camera with 18-135mm...
Dark Picture
I am assuming the following two things.
1. The part was indoors.
2. You are using the 18-135 mm lens with the Nikon D80.
The problem with shooting indoors is that not enough light goes in through the lens to the filter. Solutions:
1. Use the flash with every shot. In case there is not flashlight available, use the on board flash. Press the top button behind the barrel on the camera. It has a lighting icon. It will pop open the flash. If you are in 'P', 'A', 'S' mode, the camera will sync the shutter speed with flash. If the camera is on auto mode (The green camera icon) the flash will pop up and fire by itself.
2. Use the lens with with lowest f stop, i.e. with bigger aperture.
3. Increase ISO. You ought to get usable photographs right up to 800. To change ISO, press the button on the back of the camera which says 'ISO' (Second button from bottom) and turn the primary command dial simultaneously to change ISO setting. Higher ISO speed = Lower shutter speed (But less clarity too).
Hope it helps.
Satdeep
Jun 15, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 takes picture but wont set off flash
This could be a faulty unit.  Take it back to where you bought it and hopefully you are still under you warranty.
Mar 09, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Body Only Digital Camera Logo
74 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
