Question about Sony KP-43T90 43" Rear Projection Television
Sony KP-43T90 43 in TV only works with DVD but not with cable or antenna
  • engineer_ric Sep 04, 2008
    What is the part number for the tuner board?
  • 10,594 Answers
Connect cable at RF input and please perform Auto Search in TV Menu to search available TV channels transmission and still no signal reception means Tuner is defective in TV.
Posted on Sep 04, 2008
  • Shahid Electronics
    Shahid Electronics Sep 04, 2008
    Your tv has 2 tuners, main TU151 and sub TU152. Parts numbers are as follows..
    8-598-542-50 TUNER, FSS BTF-WA412 (TU151)
    8-598-430-50 TUNER, FSS BTF-FA401 (TU152)
    Both are mounted on A board and part number of A board is..
    A-1299-423-A A BOARD, COMPLETE
    Picture of Tuner schematic is also pasted here.
    Please post back if you need further help.
Our screen says video 1 with no picture
This is usually an easy fix. Depending how your tv is connected. Most probably it is the input you are on, or not on. Get your Sony remote look for a SOURCE or INPUT button. Press it and go to each input, for example, HDMI-1 2, INPUT-1,2 VID-1.2.etc.. Also check to see if your cables in the back is loose or out. Hope this helps
Aug 07, 2010 | Sony KP-51WS510 51" Rear Projection...
Hi! just need to know if my tv is ready for digital tv i have the sony kp-57ws520. i've hooked up my antenna and i still dont get a picture thanks for any info.
Your Sony KP-57WS520 television has an analog tuner, so you may need a digital tuner or a converter box to continue to receive over-the-air programming.
If you subscribe to a cable or satellite service, your television viewing should not be affected by the June 12, 2009, cut-off date for full-power analog broadcasting. Please contact your service provider for complete information.
Go here for more info:
http://esupport.sony.com/US/perl/model-home.pl?mdl=KP57WS520&LOC=3
Jul 07, 2009 | Sony KP-57WS520 57" Rear Projection...
There are wavy colored lines an the screen all the
A problem like yours is NORMALLY NOT the TV set's fault....it's the Cable.
I'll bet you see thin lines moving across the entire picture...they are slanted like this >> \ \ \ \
That's generally caused by a bad ground on the antenna cable OR it can be the cable box's MODULATOR.
Try using your VIDEO OUTPUT off of your Cable box and see if the wavy lines are still present. If they are the Cable box needs swapped with a good unit.
You can also verify this problem by checking your TV with a DVD player...no lines indicate the TV is fine.
If you have problems with the DVD player's picture, then you must have dried out filtering capacitors on the Video board IN the TV set...
And THAT is not an easy fix if you do see lines with your DVD player.
Mar 27, 2009 | Sony KP-51WS500 51" Rear Projection...
No TV Reception
Sony Technician confirmed that that the TV has an analog tuner
2 options - outdoor antenna with digital converter --- or cable service
Jan 16, 2009 | Sony KP-53V75 53" Rear Projection...
JUMPING VERTICAL WHITE LINES
UNPLUGGED TV FOR OVER NIGHT(WAS TOLD 4 HRS) STILL HAD PROBLEM. TOOK ALL CABLES OUT CABLE BOX,DVD,2 VCRS,AMP,SATELLITE, AND FM AMPLIFIER. OPENED BACK VACUUMED ALL BOARDS WITH SOFT BRUSH ,CLEANED LENSES ,MIRROW,FIRST TIME IN 10 YRS. TV LOOKS VERY SHARP!!!!!!!!!!!!!!!!! I THINK IT MAY HAVE BEEN THE FM BOSTER AMP TRANSFORMER GOING BAD CREATING INTERFEARANCE. JUST A GUSS.. COULD NOT HAVE BEEN THE DIRTY LENSES I DONT THINK THAT WOULD HAVE CAUSED INCONSIST CONSENT JUMPING LINES.ENERY THING RECONECTED (NO FM BOSTER AMP) TV LOOKS GREAT. THANKS FOR YOU GUYS GIVING ME THE CONVDENCE TO GET IN THAT PROGECT. KEEPING FINGERS CROSED.......THANKS TV IS A SONY KP-61XBR300 NOT A KP-57WS500 57 IN.
Nov 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-53V80 53 in. Rear...
It's not a digital hi-def tv, so you either need a cable/sat box..or a converter once hi-def goes in and analog stops.
Mar 31, 2008 | Sony KP-53V80 53" Rear Projection...
Sony Trinitron KV-20VM40
You can't. Best solution = buy a universal programmable SONY
remote for about 12.00.................................T.
Nov 18, 2007 | Sony KP-44PX3 44" Rear Projection...
Sony KP-43T90 43" Rear Projection Television Logo
336 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
