2007 Toyota Sienna Logo
Posted on Sep 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2001 Toyota Sienna AC stops at idle.
The AC stops running at idle speed, but starts working fine as soon as you start to accelerate. I've been told by KWIK KAR that AC system needs to be totally replaced. Cost for service at KWIK KAR $107.00.
Anonymous
Level 3:
  • Toyota Master 1,861 Answers
  • Posted on Sep 11, 2008
Anonymous
Toyota Master
Level 3:
Answers
1861
Questions
23
Helped
1483532
Points
8422
Tell Kwik-Kar that they are full of ****. The Sienna A/C is virtually bulletproof, and I have NEVER had to "replace" a system. That being said, I would guess that the freon charge is low. Open the hood, turn on the A/C and look at the sight-glass next to the radiator. Do you see any bubbles? If so, the freon charge is low. Get a qualified A/C tech to hook up same A/C gauges & read the high & low sides of the system, that result will give you the avenue to persue.
I have a Vauxhall Astra 2001 and it has started 'chugging' while sitting idle but also continues as you're driving. The engine management light has just started appearing which stays solid...
You have an engine cylinder misfiring, run a fault code test with a scanner to see what cylinder is misfiring. Misfire codes look like this P0301 is cylinder number (last digit of fault code) one and so on.
2001 Toyota Sienna stalls out when first started. What could cause this.
this happens to me a bit when the weather changes or rains i just floor it and take off u have to get going quickly told my mechanic but it started for him no problem if i make short trips after starting out it stalls on me so i leave it running when i run into store or bank works for me
2001 toyota sienna ce, runs good at idle, takes long time to get up to speed (1 mile to get to 40mph), when at 50 and going up bridge, it will slow down 10-15 mph. if accelerated quickly then it will seem...
I would change the transmission filter.if clogged it will slip and loose power on steep upgrades try that it is inexpensive. If that don't help you may need a new transmission.
My Sienna starts and revs the RPM's up to 2000 then idles at about 1200. It will constantly surge while driving at speeds under 55. Could this be the fuel pressure regulator?
Yes could be... also the engine should only idle at about 600 when warmed up and 1200 on cold start up so get it checked out a any good garage...
12helpful
2answers
1helpful
2answers
My 2000 Toyota Sienna cannot start in the morning/cold engine
the crank position sensor and map sensor is malfunctioning
3helpful
2000 sienna stalls, loses power and engine sounds muffled when I accelerate. idles at only 500 rpm at stop sign and runs rough
After about 100K + miles the idle air control valve (IAC) begins to collect carbon deposits that interfere with the movement of the spring-loaded valve. You will not be able to clean this without removal and dissembly of the IAC body. Use an emory cloth or fine sandpaper to remove the build up around the valve. This should free it up to rotate without binding. This is a temporary fix, of course, and will either require cleaning again or replacement of the valve. Getting to the IAC requires removal of most of the intake upto, but not including, the intake manifold. Total time is approximately 3-4 hours, but worth it. Good luck, and I hope this helps.
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
