Question about Car Audio & Video
Jeep cherokee infinity amplifier
My caar, jeep cherokee 2000 has an Infinity Mdel #36670, serial # 56007653AD and the front speakers have quick working except for one tweeter. Are the amp or speaker problems easy to fix
  • 52 Answers
Yes, you have a few options. Chances are, its your amp.
1st I would test the speakers - find the amp under the back seat, then test which wires go to the front speakers and use a AA battery to check if the speaker pops with those two wires and the battery.  If it does pop, its your amp needing replaced.  You can switch out that infinity amp for an aftermarket one very easy. Just use a testlight, or voltmeter to test the wires, and switch them to a new 4-channel amp.
if you need the wiring diagram, let me know...and dont forget to rate me! or ask for more help!
Posted on Sep 04, 2008
I have very similiar problem. I have a 2003 grand cherokee. front speakers are very low, mostly just bass from them. So I switched them out with brand new sonys. wasnt the problem. I put in all new speakers head unit and amplifier and my front speakers still are very low sounding. any help?
Posted on Jan 29, 2010
2000 jeep grand cherokee wiring diagram
You have to cut the factory speaker wires on both sides of the amp and solder them together.(bypass the amp) Pull out the factory radio so you can identify the color of the speaker wires or look at the wire colors on the back of the factory speakers.
Dec 09, 2013 | Car Audio & Video
Just removed stock front speakers from 2000 Jeep Grand Cherokee with premium sound. Speakers were working, but my son wanted new ones. Installed Infinity 9632cf speakers and we're barely getting any...
A lot of companies are using 2 ohm speakers for stock speakers. This means they are more efficient (sounds strange that a stock speaker is efficient). The stock amp may not be able to put enough power out for these to sound good. You may end up needing a new system.
Sep 01, 2011 | Infinity 9632CF 6" x 9" Coaxial Car...
Back speakers can't handle bass
you need to replace all the speakers in the truck except the front tweeters if you have them. I replaced all four with new infinitys from futureshop. Installed it was near 500 dollars. You need to get 2 ohm to match the infinity deck if yours is infinity. Most other systems are 4 ohm, these are 2 x 2 ohms for 2 and 4 ohm use. the factory's are garbage and use paper cones. The rears have plastic caps holding the tweeters in. On all four the paper was ripped away from the magnet and it caused them to vibrate and shake, once replaced with 180 watt infinitys...great sound.
Jul 06, 2010 | 1997 Jeep Grand Cherokee
Why does both of the front door speakers sound so low? I have a 2000 jeep grand cherokee with a infinity gold soung system with a amp under the rear seats.
THE DOOR SPEAKERS ARE MADE TO SOUND LOW FREQUENCY THROUGH THE AMP,(60HZ-500HZ). THIS IS NORMAL. THE REST OF THE SOUND WAVES (500HZ -8000HZ) COME FROM YOUR 2 TOP SPEAKERS ON DASH NEAR WINDSHIELD, 2" TWEETERS.
Jan 22, 2010 | 2000 Jeep Grand Cherokee
Is there an in-line amplifier for the speakers in a 96 jeep grand cherokee limited w/ infinity gold audio system
Yes, the Infinity Gold series audio systems have a separate amplifier. In my '97 the amplifier is located under the drivers side rear seat.
Note that the amplifier is set to have speaker level inputs as opposed to regular level inputs. Both the amplifier and the speakers are NOT easily mixed and matched with after market components.
Nov 13, 2009 | 1996 Jeep Grand Cherokee
Where can I find a left side infinity replacement speaker for my 2000 dodge ram?
I bought my jeep cherokee infinity tweeters off an individual in Ebay. The speakers were brand new in a box, OEM and a lot less expensive that through the dealer.
Hope this helps... Good luck!
Oct 13, 2009 | 2000 Dodge Ram 1500 Truck
1999 jeep cherokee front speakers not working
Chrysler in their goal to make a buck put splices inside the rubber tube between the door and the a pillar on later Cherokee's. This is to spit the harness between the main door speakers and optional tweeters.The plugs for the tweeters will be there no matter if you have them or not. These connectors make the wires more susceptible to breakage. Have a stereo shop rewire your front speakers.
Jul 22, 2009 | 1994 Jeep Grand Cherokee
2001 cherokee front speakers not working
well your deck might be bad, you could have a lose connection in your wiring to your speakers, you might not have a connection to your speakers, or your speakers could be bad.
Jun 28, 2009 | 2000 Jeep Grand Cherokee
Car Audio & Video Logo
1,752 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
