Question about Cameras
My camera says that the disk is full. There are no pictures on the memory card. The camera will let me take one picture and then I get the disk full message. Is there an internal memory? If so, how can I clear it? My camera is a 7.2 mega pixels Exilim.
  • centennial h Sep 04, 2008
    Fast and accurate information.  The directions sent fixed my problem and was sent in under an hour.
    Champion:
  • 203 Answers
If there is a internal memory-which there proably is-remove card and hit playback and see if there are pics-if so either download or see if you can copy onto mem card inside camera through a copy function in playback menu-simply hit delete all or find format in menu and that wil clear internal
Posted on Sep 04, 2008
  • Robert Vandenberg Sep 04, 2008
    thanks for the kinds words-glad it worked out!
My 2gb san disk gets 'system error' after just two pictures. Works fine with the 16mb disk that came with the camera, so I figured it was just the 2gb disk that was damaged. All the san disks currently on...
Download any pictures you have on the "new" memory card to the computer. I'm sure the card memory lock us in the unlock position or you wouldn't have got this far.
Anyway once the pictures have been downloaded to the computer hard drive do a proper disconnect or eject, safely remove device (different computers use different language for the same darn thing) in short shut off the link before disconnecting the memory card from the computer. Once this has been done and the memory card is back into the camera format the card. Formatting is necessary for any new card to program it to the camera it is going to be used in. Also after each download of pictures from a memory card to the computer eject (properly shut it off) and then format the card again. This give the camera a clean medium to perform at it's optimum and place clean new pictures on the memory card. Okay for the larger cards I ran into this with my pro camera and needed to connect to the manufactures web site and download updated firmware once that was done I was able to feed 8gig card into my camera. I full suspect that if you go to Konica/Minolta web site that you will be able to download camera firmware updates. It's just amazing what this will do for the performance of the camera pro or consumer type. Have fun hope this was a help
Jan 05, 2011 | Konica Minolta DiMAGE Z6 Digital Camera
When I try to take a picture, it says memory full. But, when I try to look at the memory it says no file. I tried using the disk, installing software, formatting it.. Nothing works. The SD memory card is...
Format the SD card make sure the camera is set to place the new files on the SD card and not go to the internal memory. What I fully expect is the camera has defaulted to using the internal memory which is now full of files/pictures and needs to be set back to SD card. To get the pictures from the internal memory to your computer you need to load the pictures one by one from the internal memory to the SD card. Then take them from the SD card ether to a card reader to the computer or download them from the camera to the computer.
Dec 25, 2010 | Vivitar ViviCam 8025 Digital Camera
C142 kODAK DIGITAL CAMERA. ADVISING INTERNAL MEMORY IS FULL. I HAVE PURCHASED A NEW MEMORY DISK BUT STILL GETTINGTHE SAME MESSAGE AND WILL NOT ALLOW ME TO TAKE PICTURES.
The internal memory is not the same as the memory card memory. The camera needs some elbowroom in the internal memory to work at all. It can't use the card memory while the internal memory is full. You need to delete some pictures from the internal memory, then insert the memory card, and it should work (assuming it is formatted correctly and is otherwise compatible).
Dec 20, 2010 | Cameras
How to download internal memory
Follow the instructions on this page of the user guide to transfer pictures from internal memory to memory card. Then you can download the pictures from the card as usual.
Feb 13, 2010 | Kodak Easyshare M753 Digital Camera
Did this camera come with a disk for my computer? It is my kids and I don't know.... I purchased a memory card and it still says.. memory full please insert card. can you take pictures w/no memory card?
Here is a link to the user's manual for your camera:
http://vivitar.com/products/13/VC8025%20User%20Manual.pdf
It mentions a CD with a program you can use to manage your programs, but to me, it doesn't sound necessary to be able to get photos off your card.
If it is a brand new card, look at it before you put it into the camera to see if you might have accidentally put it in locked mode. If it is unlocked, see if you can format the card from within the camera (refer to p. 23-24 of the manual).
If it is not a new card, connect the camera to a computer and see if you can download any pictures already on the camera, and clear the card out.
And no, you will not be able to take pictures without a memory card.
Good luck, and feel free to ask for more help.
Feb 03, 2010 | Vivitar ViviCam 8025 Digital Camera
My memory card is full and I want to transfer to my computer. I tried to transfer to internal memory but it says there isn't enough space. Anyway to transfer all at once instead of tagging individual...
Connect you camera to the computer using the USB cable. It will be shown as a removable drive(If the autorun is enabled windows should list the option to transfer pictures.Choose this option if it does so). Open the drive and and transfer the pictures to your computer.
Hope this helps,
Sai.
Dec 24, 2009 | Kodak ZD710 Digital Camera
The camera says disk full .I can't take any pictures and don't know what to do
Download the pictures to your computer, format your card and take more pictures!
Apr 13, 2009 | Canon PowerShot A95 Digital Camera
Internal memory is full, how do I transfer these pictures to a SD
Plug your camera into your computer. You will have two removable drives. One for the internal memory of your camera as well as the memory card. If you press My computer in Windows you will see two removeable drive devices.
Feb 17, 2009 | Kodak EasyShare C875 Digital Camera
No Pictures but full card
Sometimes when you edit pictures on your memory stick, it will transfer the files to a different folder. Then the card will seem blank to the camera. Format the memory card using the PC to clean it for good.
Nov 12, 2008 | Sony Cyber-Shot DSC-W5 Digital Camera
My memory card says full!
Try opening your My Computer screen, connect the camera to the computer and watch for the new removable disk to show up. Depending on the camera there may be two that show up. Right click on the removable disk/disks and choose format, click start and click okay. This should fully reformat the memory and you'll be able to take pictures again.
May 26, 2008 | Fuji FinePix A360 Digital Camera
Cameras Logo
332 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
