Question about Palm Treo 650 Handheld
Treo 650 common prublems
If you just got your Cingular Treo 650 and are experiencing problems such as resets, corrupt voicemail number, and other stability issues, read this post to quickly take care of the known issues of the Cingular Treo 650. If your phone continues to misbehave after trying some of the fixes suggested here, consider returning your phone as you may have a defective unit. I have tried to compile the most widely reported problems and fixes in one document to allow you to test out and determine the stability of your Treo 650 in the minimum amount of time with the minimum amount of hassle. However, some of the steps explained here require reinstallation of software and testing in a precise sequence which may seem tedious at times, but necessary to determine whether your unit is defective or not. Hope this helps the newbies!!!!
    Problem Solver:
  • 16 Answers
Http://discussion.brighthand.com/palmhandhelds/showthread.php?s=3e3a9f0f6818b3260add857c81b65a99&threadid=75197
Posted on Sep 15, 2005
Instructions on how to unlock the IMEI code for a palm treo 650? Just need the steps.
There are some unlocking sites for Treo but most of them have charges.
Hope this site can help:
http://www.chrisdiclerico.com/2006/03/31/how-to-unlock-your-cingular-treo-650-for-use-with-another-provider/
Feb 22, 2010 | Palm Treo 650 Handheld
Unlocked Treo 650 wont send text messages
I have the same problem using an unlocked Treo 650 on O2(UK).
One thing you need to do is make sure that the Message Centre Number is set correctly for the SIM network you are using. Get the MCN from the internet, then on the Treo Messaging > Menu > Options > Preferences > Network > Manual > Edit to check/set the MCN.
Oct 01, 2009 | Palm Treo 650 Smartphone
Palm treo 650 wont get service
If the phone is new to you, (different story if it was working on cingular before .. let me know if it was)
It sounds like it is sim locked, the phone needs unlocking.
If you can contact the previous owner and ask them what network it was on and borrow a sim card from that network it will verify the phone isn't faulty or blocked
The previous owner may be able to get it unlocked for you via there provider else somewhere like www.650unlock.com will do it for about $15 (I'm not recommending them, just one of the first in a search) Its worth googleing "treo 650 unlock" and shopping around also check 650 forums for recommendations
Best of luck
Jun 08, 2008 | Palm Treo 650 Handheld
Palm Treo 650
Ihave a PALM TREO butIT IS not a phone and I had the same thing happen to me.
What worked for me was # 2
If you have not tried it yet try this!
1). Press the reset set button on the back of the Palm.
2)This is a little bit more memory destructive and you might want to back up you data cause it will wipe out everything!
hold down the power key and press the reset button!
May 26, 2008 | Palm Treo 650 Handheld
TREO 650 Phone won't work
I experienced the same problem while traveling this weekend. The green phone button and anything associated to the phone all of a sudden stopped working. No call out and none in. I hotsync'd and also did a "hard reset" except I said yes and then went in and hotsync'd again. Phone now works again and all data is back
May 04, 2008 | Palm Treo 650 Handheld
Help please
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
Mar 17, 2008 | Palm Treo 650 Handheld
Please help!!!!!!
The phone may not be compatible with cingular service.
Unlock code for palm treo 650
sign up at mytreo.net I was able to get an unlock code program for my treo 600 there
Jan 06, 2008 | Palm Treo 650 Handheld
MY TREO 650 KEEPS TRYING TO HOTSYNC(and its not connected to computer)
Did it actually reset when you did a hard reset ..or does it stay powered up?
Dec 31, 2007 | Palm Treo 680 Smartphone
Synching treo 650 with 600
In a nutshell, make sure you have a recent synch to your PC of the 600. Install the Treo 650 desktop software Synch to the username of the 600 Your are done. You should rename the Treo 600 or hard reset it (you will get data corruption if you synch two devices with the same username to one PC). If you are paranoid, you can make a backup copy of your c:\program files\palm\ folder to begin with. This contains most of your settings and extra software on the 600. As you are an Outlook user, your personal data is probably in a PST file or it is stored in Exchange.
Sep 11, 2005 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
522 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
