Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Does simple tech 250 drive need an external power source?
Hi there.
I just "inherited" a Simple Tech 250GB drive. Have USB cabled it into both a PowerMac and a PC desktop and it does not show up on either. There is a red light that glows steady and a blue one that flashes then goes out on the drive.
Do I need driver software? or an external power source for the drive to make it work. (I see a very small power port on the back of the drive.)
  • 22 Answers
Yes, you need a power supply. I have several USB peripherals that, in a similar way, APPEAR to be on when you plug them into USB. But that interface cannot supply enough power to actually run the machine. The maximum is 0.5 A * 5 V = 2.5 W. The wee portable drives can run on that power, but a normal desktop drive, such as is inside a full-size desktop external enclosure, use ~ 8 W.
So you need a DC power supply! I bet SimpleTech can tell you what the correct current, voltage, and polarity is. Good luck.
Posted on Sep 04, 2008
How do I copy the files on a Simple Tech 250GB USB2.0 External IDE Hard Drive to a new 500GB USB2.0 IDE External Hard drive?
If you have them hooked up to the same machine, you should be able to drag and drop easily. Just find them under "Computer" like any other external drive
Nov 16, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple tech 320 gb not spinning
Try a new usb cable or a different usb enclosure.
Also try and remove the drive from it's enclosure and connect direct to a sata port on a desktop pc.
Aug 23, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
I need the dc power supply for SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Your solution is a 12 volt 1.5amp chord. With a negative outside/ positive inside plug tip polarity. Simple Tech model and part number: SYS1298-1812-W2
Jan 08, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
I just recently bout a 250gb simple tech external drive. I came home installed but it wont show in my computer
You might try a different cable or use a USB "Y" cable to supply enough powere for the drive to work, as some computers have difficulty providing enough power from a single port. If you need more help, please call HitachiGST Tech Support M-F 8AM to 6PM PST at 1.888.426.5214 and a technician will be happy to help you.
Feb 02, 2011 | SimpleTech Signature Mini 160GB External...
Simple tech is running but the light is not on and it does not show up on my computer
I need data connedtion type
If it is USB then you should not use a usb HUB
If it is a din connector then the drive may be faulty and you need to reveiw the warranty on the equipment
Oct 18, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
How can I lock my simple tech hard drive from other users
there are many softwares that you can use. Tryb the following link. it's very user friendly.
http://www.newsoftwares.net/folderlock/
Mar 24, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech hard drive not working
I have that problem similiar to yours. My simple tech stopped working for like two years so i decided to open up my simple tech and removed my HD away from the old enclosure so I can try building my own external hard drive for the first time. I bought another new 3.5 enclosure, IDE/ATA for the old HD. I put it in the new enclosure and it worked!
It's the only solution you can have. No need to retrieve data or re-format your HD. You can leave it the way you like...if you wanna reformat it...up to you.
Jan 27, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple tech problem
windows 2000 detects the driver for plug n play drives for it self and if it doesnt then try driverguide.com for drivers of the disk.
Nov 08, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
693 people viewed this question
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Phil Whisenant
Phil Whisenant
Steve Allison
Steve Allison
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
