Question about Maytag 24 in. MDB9750AW Dishwasher
Control Panel On the control panel there is a light right next to the "Heated Dry" button that is on. It looks like a "3". It's lit up - and never has been before, and I can't get the dishwasher to start. How do I make it go away?????
  • 2 more comments
  • ctdance Sep 04, 2008
    This answer did not help me at all - but I found the answer on the Maytag official website.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    I didn't charge you, and if you look at the information posted, I also did not provide you with a solution. I merely asked you for clarifying information in an attempt to try to help you. You did not provide any feedback except to say you found your answer elsewhere. I agree with you. If someone charged your account, you deserve a refund if the service was not provided to you. You will need to contact Fixya staff if you aren't satisfied with the service you provided. I don't work for Fixya. I'm a consumer just like you that tries to assist others in providing FREE advice to those that need it.
  • Jeff Rockwell
    Just so we're clear, I did not post this recommendation to do simply to get jump on a question and attempt to provide you with a quick answer with no thought process. As all dishwashers are not alike, so are the fault symptoms they exhibit. Sometimes the answer(s) to your problem is right under your nose if you look for them. Many answers to common problems are provided in the technical data the manufacturer provides with the appliance. That's why I suggested you reference the tech sheet, first. This not only has the potential to provide you with direct answers, but also avoids the cost of a service call. This is a troubleshooting forum. Sometimes it takes a discussion of trading questions and answers in order to solve these problems. Although, I am happy for you that you were able to find a solution to your problem, I'm sorry that I was unable to help you at all. My apologies if you thought this was a waste of time.
  • Jeff Rockwell
    Remove the panel directly under the door. There is usually a tech sheet either behind the panel, or along the interior cabinet wall that explains all the error codes. Most manufacturers place techincal documentation, along with troubleshooting tips for the repairman. As all dishwashers are not alike, it is often difficult to assume or predict what the code may mean with referring to this documentation. If the sheet is not there, it is also sometimes places behind the door interior facing.
I did not use your service to fix my problem - I found the answer on Maytag.com. But you charged me anyway - so I would like that money refunded.
Posted on Sep 05, 2008
How do I cancel the control lock
It would help if you gave the brand and model number of your dishwasher, but the answer is basically the same. Look carefully at your dishwasher control panel. You probably have a little lock symbol that is lit up (or a light inside the symbol is lit). And usually this lock symbol is located near (usually above) a button that is usually used for another purpose. Most often this is the Heated-Dry key or button. Press and hold this key for 3 to 5 seconds until the lock symbol light goes out. And it's just that easy! But if you press the key, and nothing happens, then you may have a bad control console that will have to be replaced.
Feb 25, 2015 | Dishwashers
Lighted "3" shows, dishwasher won't start
PRESS AND HOLD THE BUTTON NEXT THE LOCK3 LIGHT FOR 3 SECONDS TO UNLOCK THE CONTROL PANEL. TO RELOCK THE CONTROL PANEL PRESS THE SAME BUTTON FOR 3 SECONDS. THANKS AGAIN
Apr 20, 2014 | Maytag MDB7100AWB Dishwasher
Refresh control panel
Instructions
    • 1
      Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
    • 2
      Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
    • 3
      Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
    • 4
      Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
      Hope this will be of help to you
      Have an awesome day
Feb 08, 2012 | Kenmore Dishwashers
Error 1 on kenwood dishwasher
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 05, 2011 | Kenwood KDW243A Builtin Dishwasher
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a maytag quiet series 300 dishwasher. On the control panel there is a green light on next to a picture of what appears to be a lock with a number 3 in the middle of it. I am not able to use my...
press and hold the heated dry button 3 seconds it will unlock the dishwasher. That 3 with the lock around it show you that the dishwasher has been locked out to keep buttons from being able to be pushed. You can lock it and unlock it by holding the heated dry button 3 seconds.
Feb 07, 2011 | Maytag Dishwashers
My maytag 200 quiet series dishwasher has a button with the number 3 next to the start/cancel button and will not start. The 3 flashes but won't start? Any idea what that means?
The control panel has bee locked. Press and hold the heated dry button for 3 seconds until the light next to the lock "3" button goes off. This feature is to prevent small children from starting it. Locking the controls works the same way, hold the heated dry button for 3 seconds will turn it back on.
Dec 13, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
We have a dishwasher that flashes clean light on front panel and will not allow a new cleaning cycle. Mod GU3200XTPS3 TYPE 577-0
Make sure the control panel is not locked. If you press any pad while your dishwasher is locked, the light flashes 3 times and the selection is ignored. If the lock symbol is lit, press and hold HEATED DRY for 4 seconds. The light turns off.
If the control panel is not locked and the problem still occurs press the Cancel/Drain button to drain all water and clear all indicators. (It might take 2 minutes to complete this action.)
Jul 08, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Maytag Quiet Series 300 Will not work at all, only the lock feature is lit.
I had the same problem. The lock button light was on, nothing happened when pressing start, cancel, etc. I also tried holding the heated dry button (lock) for 3 seconds and no luck UNTIL holding down for three seconds while also pressing the cancel button. I was then able to start cycle as normal.
Apr 18, 2008 | Dishwashers
Maytag 24 in. MDB9750AW Dishwasher Logo
128 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
